    access userdata inside userdata group [SOLVED]
    16 Posts 0 Posters 1.8k Views
      On 09/07/2015 at 06:00, xxxxxxxx wrote:
      I get an error message:
      File "scriptmanager", line 11 in ,module.
      TypeError:_setitem_expected int or bool, not None
      Hi
      I test code and simple print to dive in to level
          for id, bc in op.GetUserDataContainer() :
            print bc[c4d.DESC_PARENTGROUP][-1].id
            if bc[c4d.DESC_PARENTGROUP][-1].id == 700:
                op[id] = bc[c4d.DESC_DEFAULT]
      i have id in level = 700.
      Try such, code works for me
        On 09/07/2015 at 06:18, xxxxxxxx wrote:
        I tried your code and still get the same error message.
          On 09/07/2015 at 06:22, xxxxxxxx wrote:
          If I try this code from the Script Manager, it works and only userdata from group 255 is reset but when it is on a Python tag, it doesn't. Any suggestions?
              if bc[c4d.DESC_PARENTGROUP][-1].id == 255:
                  try:
                  except TypeError:
                       #No or invalid default value.
                      pass
            On 09/07/2015 at 08:02, xxxxxxxx wrote:
            For a Python Tag, "op" is the Tag, not the Object. Use the variable "obj" in all places instead of "op" and add "obj = op.GetObject()" beforehand.
              On 09/07/2015 at 10:57, xxxxxxxx wrote:
              Thanks, Niklas, that totally worked! The last thing I need and can't get to work is the switch. Here is what I have:
              ID_RESET_Iceland = 39
                  for id, bc in obj.GetUserDataContainer() :
                          if obj[c4d.ID_USERDATA, ID_RESET_Iceland]:
                              obj[c4d.ID_USERDATA, ID_RESET_Iceland] = False
                              try:
                                  obj[id] = bc[c4d.DESC_DEFAULT]
                              except TypeError:
                                  pass
                On 09/07/2015 at 11:44, xxxxxxxx wrote:
                I now have this but it still doesn't work.
                        if (bc[c4d.DESC_PARENTGROUP][-1].id == 255 and
                        obj[c4d.ID_USERDATA, ID_RESET_Iceland] == False) :
                                try:
                                except TypeError:
                                    pass
                  On 09/07/2015 at 17:10, xxxxxxxx wrote:
                  Try this instead
                      if not obj[c4d.ID_USERDATA, ID_RESET_Iceland]:
                              try:
                              except TypeError:
                                  pass
                  Don't use that __name__ == "__main__" part in a Python Tag
                    On 09/07/2015 at 19:59, xxxxxxxx wrote:
                    It works! You are a genius! Thanks very much for this Niklas. 🙂
                      On 09/07/2015 at 20:19, xxxxxxxx wrote:
                      One problem, the script keeps looping after I activate the reset button. Is there a way to stop it?
                        On 09/07/2015 at 20:23, xxxxxxxx wrote:
                        Figured that out. Moved c4d.EventAdd() out of the for loop. But now it resets regardless of whether or not the reset switch is activated.
                                    try:
                                    except TypeError:
                                        pass
                          On 10/07/2015 at 15:48, xxxxxxxx wrote:
                          Got it working! I had the wrong userdata id number.
                              ID_RESET_Iceland = 121
                              obj = doc.SearchObject("DEEP FREEZE")
                              #obj = op.GetObject()
                                          try:
                                          except TypeError:
                                              pass
                                      if bc[c4d.DESC_PARENTGROUP][-1].id == 277:
                                          try:
                                          except TypeError:
                                              pass
                                      if bc[c4d.DESC_PARENTGROUP][-1].id == 515:
                                          try:
                                          except TypeError:
                                              pass
                                      if bc[c4d.DESC_PARENTGROUP][-1].id == 516:
                                          try:
                                          except TypeError:
                                              pass
