    GetClone gets confused by Materials ?
    4 Posts 0 Posters 696 Views
      On 03/01/2003 at 13:35, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      I just finished my Bone to PLA converter Plugin and it works fine, as long as the obj has no TextureTag.if it has one ( or more) my plugin gets confused because the GetClone(NO_HERARCHY) generates not only one clone but another one ( a null-obj only with the clones Texturetags)witch has another clone as child!
      Can anyone help me?
      Greetings, Nico
        On 08/01/2003 at 00:58, xxxxxxxx wrote:
        I assume you mean that you call GetClone(CL_NO_HIERARCHY) on an object with a TextureTag. I cannot reproduce the error you describe. This, very dangerous, expression manages just fine to clone objects with TextureTags:
            var t;
            main(doc,op)
              if (!t)
                doc->InsertObject(op->GetClone(CL_NO_HIERARCHY), NULL, NULL);
                GeEventAdd();
                t = TRUE;
        Apply it to an object with a TextureTag, and a few children if you want, and see that it copies the object wihtout its children just fine.
        Could you post some of your code that triggers the error?
          On 08/01/2003 at 08:17, xxxxxxxx wrote:
          my code is quite the same you wrote.
          I tested some different objects and as long as there is no TextureTag assigned. With a texturetag i always get the nullobj describet above.
          greetings,nico
            On 11/01/2003 at 06:34, xxxxxxxx wrote:
            I still cannot reproduce it. Can anyone else here get this behaviour?
