    ShowPopUp with Details? [SOLVED]
    11 Posts 0 Posters 1.2k Views
      On 11/01/2015 at 02:31, xxxxxxxx wrote:
      Dear Python Experts.
      I´ve made a plugin which execute the GUI ShowPopUpDialog and populate it with all layer names in the current document. When a names is pressed, the selected objects are added to that layer.
      This works perfect, but i would like to get the layer color indicator into the popup aswell.
      Is this even possible with the gui.showpopupdialog or do i need to go the GeDialog way?
      If i have to go the GeDialog way, can someone push me in the right direction to start of such a custom gui? 🙂
      Looking forward to hear from you !
      Best Regards
      Nicolaj
        On 12/01/2015 at 10:45, xxxxxxxx wrote:
        you can use an icon in the popup menu. Using "& i....&" you can define an icon id that is used for that element:
        menu.SetString(c4d.FIRST_POPUP_ID+99,"&i5119&Something")
        So you could create preview icons and register them using RegisterIcon()[URL-REMOVED]. But I'm not sure if this is a good workflow.
        If you want to draw something in a GeDialog you may use a GeUserArea[URL-REMOVED]. There you can draw whatever you want. You find some code that shows how to use that class in the Py-MemoryViewer.pyp[URL-REMOVED] example.
          On 12/01/2015 at 10:56, xxxxxxxx wrote:
          Hi Sebastian
          Thanks for answer, it seems like a Good solution with the Registericon..
          But is it possible to colorize the icons?
          I wan't grab to the color from each layer and link it to the icon in the PopUp 🙂
          Best Regards
          Nicolaj
            On 13/01/2015 at 00:06, xxxxxxxx wrote:
            when you call RegisterIcon() you register a bitmap. You can fill this bitmap any way you like.
              On 13/01/2015 at 03:16, xxxxxxxx wrote:
              I like to extend the question
              I try the code of
              menu.SetString(19, '&d&i5119& '+group.GetName());
                  menu.SetString(0, "" )
                  menu.SetString(31, 'select')
              - but I can`t get a disable menu item and a icon
              and all following menu item have the same icon
                On 13/01/2015 at 05:11, xxxxxxxx wrote:
                to disable a menu element simply add "&d&"[URL-REMOVED]:
                menu.SetString(c4d.FIRST_POPUP_ID+100,"&i5150&Something Else &d&")
                  On 17/01/2015 at 03:53, xxxxxxxx wrote:
                  Hi Sebastian
                  I´m having trouble finding the right code-snippet for filling a bitmap in python.
                  So far i managed i attach my custom icon to every entry in my popup dialog, but after looking thru the bitmap class, i can´t seem to find anything useful.
                  Best Regards
                  Nicolaj
                    On 19/01/2015 at 01:06, xxxxxxxx wrote:
                    you can set the data of a bitmap using BaseBitmap.SetPixel()[URL-REMOVED]. An example can be found in SculptSaveMask.pyp[URL-REMOVED].
                    A little more comfortable way of filling a bitmap would be to use the GeClipMap[URL-REMOVED] class.
                    geClipMap = c4d.bitmaps.GeClipMap()
                    geClipMap.Init(800,600,32)
                    geClipMap.BeginDraw()
                    geClipMap.SetColor(255,0,0)
                    geClipMap.FillRect(0,0,800,600)
                    geClipMap.EndDraw()
                    bitmap = geClipMap.GetBitmap()
                    filename = c4d.storage.SaveDialog(title="Save image")
                    bitmap.Save(filename,c4d.FILTER_TIF)
                    For questions no longer related to this thread's original topic please open a new thread. Thanks.
                      On 30/01/2015 at 10:44, xxxxxxxx wrote:
                      Hello sortsovs,
                      was your question answered?
                        On 30/01/2015 at 10:52, xxxxxxxx wrote:
                        Hi Sebastian
                        Oh Ya, Sorry! How do i close the topic? 🙂
                          On 02/02/2015 at 03:15, xxxxxxxx wrote:
                          you do not need to close this topic; we will handle this.
