    Custom Gui - How to hide the label?
    33 Posts 0 Posters 20.6k Views
      On 15/01/2015 at 18:19, xxxxxxxx wrote:
      Thanks Andreas! Not only to you is it confusing. I don't even want't to tell how much time I had
      to invest to get around the CustomGui and CustomDataType stuff. It's poorly documented/explained.
      One idea came up while I read your reply: Maybe it doesn't work because the ID of my property
      conflicts with an existing ID? BANNERGUI_ICONID for instance has the ID 1000. I'm gonna check
      this tomorrow. 🙂
        On 23/01/2015 at 07:02, xxxxxxxx wrote:
        That wasn't it. The obvious solution was to make a CustomDataTypeClass plugin that exposes the
        same custom properties. The settings will be merged in the same BaseContainer that is passed to the
        iCustomGui.
        I have only one problem left, unfortunately. I want one of the custom properties to be a String.
        static CustomProperty BannerGuiProperties[] = {
          { CUSTOMTYPE_LONG,   BANNERGUI_ICONID,         "ICON_ID" },
          { CUSTOMTYPE_LONG,   BANNERGUI_BGCOLOR_ID,     "BGCOLOR_ID" },
          { CUSTOMTYPE_VECTOR, BANNERGUI_BGCOLOR_VECTOR, "BGCOLOR_VECTOR" },
          { CUSTOMTYPE_FLAG,   BANNERGUI_TRANSPARENT,    "TRANSPARENT" },
          **{ CUSTOMTYPE_STRING, BANNERGUI_HALIGN,         "ALIGN_H" },**
          { CUSTOMTYPE_LONG,   BANNERGUI_WIDTH,          "WIDTH" },
          { CUSTOMTYPE_LONG,   BANNERGUI_HEIGHT,         "HEIGHT" },
          { CUSTOMTYPE_FLAG,   BANNERGUI_LOCKSCALE,      "LOCKSCALE" },
          { CUSTOMTYPE_END, 0, "" },
        But when the property is specified in the Description resource, the entry in the settings container I
        get in the iCustomGui is empty (DA_NIL). If the property is left out, I get the default value that I
        initialized in CustomDataTypeClass::GetDefaultProperties() (which is fine).
                GROUP {
                    BANNER TEST { ICON_ID 5159; WIDTH 16; ALIGN_H "center"; LOCKSCALE; TRANSPARENT; }
        class BannerGuiDataType : public CustomDataTypeClass {
          typedef CustomDataTypeClass super;
          // CustomDataTypeClass
          virtual Int32 GetId() override
            return CUSTOMDATATYPE_BANNER;
          virtual CustomDataType* AllocData() override
            return NewObjClear(CustomDataType);
          virtual void FreeData(CustomDataType* data) override
            DeleteObj(data);
          virtual Bool CopyData(
            const CustomDataType* src, CustomDataType* dest, AliasTrans* at)
            override
            return true;
          virtual Int32 Compare(const CustomDataType* d1, const CustomDataType* d2)
            override
            return -1;
          virtual Bool WriteData(const CustomDataType* data, HyperFile* hf) override
            return true;
          virtual Bool ReadData(CustomDataType* data, HyperFile* hf, Int32 level)
            override
            return true;
          virtual const Char* GetResourceSym() override
            return "BANNER";
          virtual CustomProperty* GetProperties() override
            return ::BannerGuiProperties;
          virtual void GetDefaultProperties(BaseContainer& data) override
            data.SetInt32(BANNERGUI_ICONID, 0);
            data.SetInt32(BANNERGUI_BGCOLOR_ID, -1);
            data.SetVector(BANNERGUI_BGCOLOR_VECTOR, Vector(0, 0, 0));
            data.SetBool(BANNERGUI_TRANSPARENT, false);
            data.SetString(BANNERGUI_HALIGN, "LEFT");
            data.SetInt32(BANNERGUI_WIDTH, -1);
            data.SetInt32(BANNERGUI_HEIGHT, -1);
            data.SetBool(BANNERGUI_LOCKSCALE, false);
            data.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF);
            data.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_BANNER);
        BannerGui::BannerGui(
          const BaseContainer& bc, CUSTOMGUIPLUGIN* plugin)
          : super(bc, plugin), iconData(), ownsBitmap(false)
          this->ua = NewObjClear(BannerGuiUserArea, this);
          this->iconId = bc.GetInt32(BANNERGUI_ICONID, 0);
          this->transparent = bc.GetBool(BANNERGUI_TRANSPARENT);
          if (bc.GetInt32(BANNERGUI_BGCOLOR_ID, -1) < 0) {
            this->bgColor = bc.GetVector(BANNERGUI_BGCOLOR_VECTOR);
          else {
            this->bgColor = bc.GetInt32(BANNERGUI_BGCOLOR_ID);
          const String alignMode = bc.GetString(BANNERGUI_HALIGN).ToLower();
          if (alignMode == "right") {
            this->alignH = BANNERGUI_HALIGN_RIGHT;
          else if (alignMode == "center") {
            this->alignH = BANNERGUI_HALIGN_CENTER;
          else if (alignMode == "left" || true) {
            this->alignH = BANNERGUI_HALIGN_LEFT;
          this->width = bc.GetInt32(BANNERGUI_WIDTH, -1);
          this->height = bc.GetInt32(BANNERGUI_HEIGHT, -1);
          this->lockScale = bc.GetBool(BANNERGUI_LOCKSCALE, false);
          GePrint("HALIGN Dtype: " + String::IntToString(bc.GetType(BANNERGUI_HALIGN)));
          GePrint("Icon ID: " + String::IntToString(this->iconId));
          GePrint("alignMode: " + alignMode);
          GePrint("Width: " + String::IntToString(this->width));
          GePrint("Height: " + String::IntToString(this->height));
          GePrint("LockScale: " + String::IntToString(this->lockScale));
        An idea where the problem could be? Thanks!
        Niklas
          On 26/01/2015 at 10:55, xxxxxxxx wrote:
          ">I'm not sure where the problem could be!! "I usually get problems with .res files "I like C++ functions more""
          what I did in my custom data type class and it worked
          virtual Bool _GetDescription(const CustomDataType* data, Description& desc, DESCFLAGS_DESC& flags, const BaseContainer& parentdescription, DescID* singledescid)
          	//won't read res file!!
          	//edited the code
          	DescID cid = DescLevel( **/* your ID here, same as the ID used in GetParameter() */ YOURID** , DTYPE_STRING, 0);
          	if (!singleid || cid.IsPartOf(*singledescid, nullptr)) // important to check for speedup c4d!
          		BaseContainer mstring = GetCustomDataTypeDefault(DTYPE_STRING);
          		mstring .SetString(BANNERGUI_HALIGN, "left");
          		if (!desc.SetParameter(cid, mstring, DescLevel(0)))
          			return true;
          	return SUPER::_GetDescription(data, desc, flags, parentdescription, singledescid);
            On 29/01/2015 at 10:13, xxxxxxxx wrote:
                    GROUP {
            Hmm, not sure if that's the problem but get rid of the "":
                        BANNER TEST { ICON_ID 5159; WIDTH 16; ALIGN_H center; LOCKSCALE; TRANSPARENT; }
            Also, you shouldn't require a custom datatype to get the settings. At least it works here with a custom gui finely.
              On 11/03/2015 at 12:04, xxxxxxxx wrote:
              Niklas,
              have you been able to get it working?
                On 22/05/2015 at 06:00, xxxxxxxx wrote:
                No unfortunately not. But I had an idea: Could it be that String  custom property can not be a hardcoded
                string inside the description resource, but must instead be a resource symbol that will be loaded from the
                stringtable? I'll try it out as soon as I can.
                  On 22/05/2015 at 06:14, xxxxxxxx wrote:
                  Hmm, I don't think so. The above way does not work for you?
                  In my custom gui I get the string in the constructor with
                  m_unit = settings.GetString(MY_UNIT);
                  and in my description resource it looks like this
                  REAL ELEMENT_ID { MIN 0; MAX 100; CUSTOMGUI FXUNIT; MY_UNIT SQR_METER; }
                  then I get a string from the stringtable with
                  if(m_unit.Compare("SQR_METER")==0)
                  unit_str = GeLoadString(DPIT_SQR);
                  works all fine here.
                    On 22/05/2015 at 06:23, xxxxxxxx wrote:
                    Katachi, that is actually what I meant in my previous post. 🙂 And right now I see in the SDK, the
                    documentation of CUSTOMTYPE_STRING says: "String data. (An ID from the string table.)".
                    So, to use it, it must be set up like this?
                    mydescription.res
                    CONTAINER mydescription {
                        GROUP {
                            BANNER MY_BANNER { TITLE MY_BANNER_TITLE; }
                    mydescription.str
                    STRINGTABLE mydescription {
                        MY_BANNER_TITLE "The string to be passed to the TITLE property here";
                    I thought I could use it to write in-line strings into the description. I wanted to use it to specify the
                    alignment of the banner image using the words "left", "center" and "right" instead of using integers
                    like -1, 0 and 1 respectively.
                    Solved [x]
                      On 22/05/2015 at 06:38, xxxxxxxx wrote:
                      yes, exactly like that. 🙂 Yeah, directly inline won't work but well you can still use LEFT, RIGHT and CENTER instead of MY_BANNER_TITLE right? You would just add each of them to your .str file like:
                      LEFT "Left";
                      CENTER "Center";
                      RIGHT "Right";
                        On 22/05/2015 at 07:49, xxxxxxxx wrote:
                        But my plugin is a Custom Gui plugin, and the other plugin that makes use of the Custom Gui should
                        not need to add LEFT CENTER and RIGHT to its Stringtable when it wants to use the Custom Gui. 😉
                          On 22/05/2015 at 12:32, xxxxxxxx wrote:
                          It doesn't have to. The other plugin can simply use LEFT, RIGHT and CENTER as well (of course the custom gui must be installed). It doesn't have to redefine them in its stringtable. Or what do you mean?
                            On 22/05/2015 at 23:30, xxxxxxxx wrote:
                            Oh really? In what Stringtable need LEFT,CENTER and RIGHT be defined then?
                              On 23/05/2015 at 01:05, xxxxxxxx wrote:
                              They should be defined in the stringtable of the customgui of yours.
                              Then once that customgui is installed, the description (and its resources) are registered too so any parsing of your customgui by c4d (no matter where in c4d) shall allow to use these flags.
                                On 23/05/2015 at 03:55, xxxxxxxx wrote:
                                I kind of feel like I don't get it. I don't see a way to register a stringtable or description resource with a
                                Custom GUI plugin. And I tried adding it to c4d_strings.str and c4d_symbols.h but I get a message when
                                the description that uses the Custom GUI is loaded "Symbol 'RIGHT' could not be found".
                                Tried both ways, in the plugin that uses the Custom GUI and in the Custom GUI plugin itself.
                                #ifndef C4D_SYMBOLS_H__
                                #define C4D_SYMBOLS_H__
                                enum
                                  LEFT,
                                  RIGHT,
                                  CENTER
                                #endif // C4D_SYMBOLS_H__
                                STRINGTABLE
                                  LEFT "left";
                                  RIGHT "right";
                                  CENTER "center";
                                  On 23/05/2015 at 04:16, xxxxxxxx wrote:
                                  You need to use RegisterDescription (I do it in PluginMessage with C4DPL_INIT_SYS) to have it registered along with your customgui. Then it should work.
                                    On 23/05/2015 at 04:47, xxxxxxxx wrote:
                                    Thanks Katachi, that makes sense to me. 🙂
                                    Edit: Oh well, I fail at doing good test cases. 😂 Actually no, it doesn't really work  with a LONG prop.
                                    It just uses zero as the value when it can't convert the value to a number, and I didn't notice that my
                                    banner image was centered instead of right aligned in my test case (you might ask yourself how you
                                    can not see that immediately..)
                                    Seems like I can't get this to work atm. When I have time next week I'll make a stripped down custom
                                    datatype plugin and test it again. Thanks for your help Katachi!
                                    -Niklas
                                    Unfortunately, it still doesn't work with a CUSTOMTYPE_STRING propety. But it works with a LONG prop!~~
                                    ** nrbannergui.h**
                                    #if 0~~
                                     ~~enum~~
                                     ~~  LEFT = -1,~~
                                     ~~  RIGHT = 1,~~
                                     ~~  CENTER = 0,~~
                                     ~~#endif
                                    The CustomProperty is
                                     { CUSTOMTYPE_LONG,   BANNERGUI_HALIGN,         "HALIGN" }
                                    And handled in the iCustomGui constructor as
                                       Int32 align = bc.GetInt32(BANNERGUI_HALIGN);~~
                                     ~~  if (align  < 0)       this->alignH = BANNERGUI_HALIGN_LEFT;~~
                                     ~~  else if (align == 0) this- >alignH = BANNERGUI_HALIGN_CENTER;~~
                                     ~~  else if (align  > 0)  this->alignH = BANNERGUI_HALIGN_RIGHT;
                                    And since I use the custom property on both the custom GUI and custom datatype, I registered the
                                    description for both.
                                       if (!RegisterDescription(CUSTOMGUI_BANNER, "nrbannergui")) return false;~~
                                     ~~  if (!RegisterDescription(CUSTOMDATATYPE_BANNER, "nrbannergui")) return false;
                                    Now I can use it in my plugin description as
                                       GROUP {~~
                                     ~~    NR_BANNER  MY_BANNER { ICON_ID 1035231; ICON_ID_HOVER 1035232; BUTTON; BGCOLOR_VECTOR 0.157 0.353 0.663; HALIGN RIGHT; }~~
                                    Thanks again!
                                    -Niklas
