    Custom Gui - How to hide the label?
    33 Posts 0 Posters 20.8k Views
      On 12/01/2015 at 03:28, xxxxxxxx wrote:
      Hi Niklas,
      regarding DescriptionCustomGui you are right. I got carried away by the DESCRIPTION_SHOWTITLE flag...
      What I don't understand is your group workaround... I thought your question was about using the custom gui in user data. Now, your screenshot seems to show a tag with its own description resource. Where on my side, there never was a problematic label...
      Custom GUI properties:
      My first thought was CustomGuiData and implementing all needed properties in there. On the other hand, I think, I learned this from one of your examples... so I'm probably wrong again.
      To be honest, I have no idea, if there's an automatic mechanism making properties of custom guis propagate through other customguis, where they are used in.
        On 12/01/2015 at 05:35, xxxxxxxx wrote:
        Hello Andreas,
        Yes, it seems to work fine in descriptions by putting it into a group. It would still be nice if the Custom
        Gui would function the same in User Data.
        Also, what I have not yet mentioned, is that I had posted a very similar question in the beta forums
        months ago where I was trying to implement my own Button Custom Gui. There is the problematic
        label again. I will send you the link in a private message as I don't know whether I am allowed to post
        it here or not, even though non-beta users won't have access.
        About Custom Gui Properties : I think you can set them in a dialog resource, but I have not found
        out how you can specify them in description resources, apart from manually creating the custom GUI
        in NodeData::GetDDescription() (which would not be available for Python, and this custom GUI should
        be used for a Python plugin.
          On 13/01/2015 at 08:01, xxxxxxxx wrote:
          Andreas, were you gather more information or ask the developers?
          And should I start a separate topic about the Custom GUI Properties in Description Files?
            On 13/01/2015 at 08:29, xxxxxxxx wrote:
            Hello Niklas,
            yes, I have had some time to read the code and also get some developer feedback, but I was lacking the time to answer...
            And you won't like the answer... the behavior of the normal button in user data is hard coded. And so is the behavior for other custom guis. There's currently no way to emulate the behavior of the button with a custom gui. Sorry.
            So there's currently no option in the implementation of a custom gui to hide the label of a custom gui in user data. Only option is to name the user data (short name) ##. Then the label will be hidden.
            Regarding the Custom GUI Properties in description resource files, I did some research as well. I have not found any place this is done in C4D. May be an indicator, this is not possible either. I'll discuss this with the rest of the team tomorrow. Until then there's no need to open another topic.
              On 13/01/2015 at 09:29, xxxxxxxx wrote:
              Hello Andreas,
              I highly appreciate the time you have invested on finding answers, thank you.
              This was my biggest fear. Well, one must admit that parts of Cinema are very old that might have been
              designed different by today. It would be nice if such old, even seemingly small things, would be adjusted
              any time in the future. 🙂
              Sorry I haven't tested it before, and I still had hope it could be configurable from the plugin, but this
              is a solution and that is fine. 🙂 Wondering where this is documented though?
              This would be highly unfortunate. The only way to bring custom user interfaces to the Attributes
              Manager is via Custom GUIs. Now, if you can not specify their properties in description resources,
              the only way to configure  them is via GetDDescription(). And this is all not possible from Python.
              Kind regards
              Niklas
                On 15/01/2015 at 09:33, xxxxxxxx wrote:
                Hi Niklas,
                forget what I wrote before about CustomGUI properties. It's done all over the place, I simply didn't recognize.
                For example a slider:
                LONG myID { CUSTOMGUI LONGSLIDER; MINSLIDER 1; MAXSLIDER 1000;}
                I think, the problem in your case is, that you expect such properties to propagate through. You'd like to set the properties of a BITMAPBUTTON CustomGUI, which is embedded in your own CustomGUI BANNER. And this won't work.
                You will have to implement CustomGuiData for your BANNER and define the needed properties in there. And then you will have to use these to configure the embedded BITMAPBUTTON.
                Sorry, for the confusion and that this took a bit longer. I needed some time to unravel the knots in my head.
                  On 15/01/2015 at 10:45, xxxxxxxx wrote:
                  Hello Andreas,
                  Are you sure these properties are not part of the datatype instead of the Custom GUI? I think MINSLIDER and MAXSLIDER sare part of the **  LONG** datatype, implemented in CustomDataTypeClass::GetProperties(). When creating user-data, you can specify these values not in the "Details" Tab (where the properties are listed) but in the "Properties" Tab (where you change the datatype of the parameter, etc. [Yes, confusing]).
                  Actually, no. I only have a GeUserArea in my CustomGui dialog and I define the properties in the CustomGuiData subclass.
                  class BannerGuiCustomGuiData : public CustomGuiData
                    typedef CustomGuiData super;
                    // CustomGuiData Overrides
                    virtual Int32 GetId() override
                      return CUSTOMGUI_BANNER;
                    virtual CDialog* Alloc(const BaseContainer& settings) override
                      BannerGui* dlg = NewObj(BannerGui, settings, this->GetPlugin());
                      if (dlg) {
                        return dlg->Get();
                      return nullptr;
                    virtual void Free(CDialog* dlg, void* userdata) override
                      if (userdata) {
                        BannerGui* gui = static_cast<BannerGui*>(userdata);
                        DeleteObj(gui);
                    virtual const Char* GetResourceSym() override
                      return "BANNER";
                    virtual CustomProperty* GetProperties() override
                      static CustomProperty props[] = {
                        { CUSTOMTYPE_LONG,   BANNERGUI_ICONID,         "ICON_ID" },
                        { CUSTOMTYPE_LONG,   BANNERGUI_BGCOLOR_ID,     "BGCOLOR_ID" },
                        { CUSTOMTYPE_VECTOR, BANNERGUI_BGCOLOR_VECTOR, "BGCOLOR_VECTOR" },
                        { CUSTOMTYPE_FLAG,   BANNERGUI_TRANSPARENT,    "TRANSPARENT" },
                        { CUSTOMTYPE_STRING, BANNERGUI_HALIGN,         "ALIGN_H" },
                        { CUSTOMTYPE_LONG,   BANNERGUI_WIDTH,          "WIDTH" },
                        { CUSTOMTYPE_LONG,   BANNERGUI_HEIGHT,         "HEIGHT" },
                        { CUSTOMTYPE_FLAG,   BANNERGUI_LOCKSCALE,      "LOCKSCALE" },
                        { CUSTOMTYPE_END, 0, "" },
                      return props;
                    virtual Int32 GetResourceDataType(Int32*& table) override
                      static Int32 _table[] = { DA_LONG, DA_LLONG, DA_STRING, DA_FILENAME };
                      table = _table;
                      return 4;
                  Best,
                  Niklas
                    On 15/01/2015 at 13:02, xxxxxxxx wrote:
                    To be honest, I'm not sure at all. 😉
                    This entire CustomGUI/CustomDataType/resource description/dialog description/dynamic description stuff confused and is still confusing me. No promises made, but sometime I will write an article for the SDK docs, to get this sorted.
                    On the other hand I tried it here in one of my private plugins.
                    I just double checked (the plugin contains indeed a CustomDataType as well).
                    Here's my code:
                    Int32 ColorHarmonyCustomGuiData::GetId() { return CUSTOMGUI_HARMONY; }
                    CDialog* ColorHarmonyCustomGuiData::Alloc(const BaseContainer& settings)
                      m_pDlg = NewObj(ColorHarmonyCustomGuiWheel, settings, GetPlugin());
                      if (!m_pDlg) {
                        return nullptr;
                      return m_pDlg->Get();
                    void ColorHarmonyCustomGuiData::Free(CDialog* dlg, void* ud)
                      if (dlg) {
                        DeleteObj((GeDialog*&)dlg);
                    const Char* ColorHarmonyCustomGuiData::GetResourceSym()
                      return "HARMONY";
                    CustomProperty g_cpHarmonyWheelProps[] =
                      { CUSTOMTYPE_LONG, HARMONY_RGB_FIRST, "NUM_HARMONIES" }, // SDK Support Test
                      { CUSTOMTYPE_END, 0, nullptr }
                    CustomProperty* ColorHarmonyCustomGuiData::GetProperties()
                      return g_cpHarmonyWheelProps;
                    Int32 ColorHarmonyCustomGuiData::GetResourceDataType(Int32*& table)
                      static Int32 l_table[] = { DTYPE_COLOR, CUSTOMDATATYPE_GRADIENT, CUSTOMDATATYPE_HARMONY };
                      table = l_table;
                      return sizeof(l_table);
                    And in a test resource file, I used:
                    COLOR ID_TESTOBJECT_HARMONY { FIT_H; SCALE_H; ANIM OFF; CUSTOMGUI HARMONY; NUM_HARMONIES 5; }
                    I'll double check the LONG datatype tomorrow.
                      On 15/01/2015 at 18:19, xxxxxxxx wrote:
                      Thanks Andreas! Not only to you is it confusing. I don't even want't to tell how much time I had
                      to invest to get around the CustomGui and CustomDataType stuff. It's poorly documented/explained.
                      One idea came up while I read your reply: Maybe it doesn't work because the ID of my property
                      conflicts with an existing ID? BANNERGUI_ICONID for instance has the ID 1000. I'm gonna check
                      this tomorrow. 🙂
                        On 23/01/2015 at 07:02, xxxxxxxx wrote:
                        That wasn't it. The obvious solution was to make a CustomDataTypeClass plugin that exposes the
                        same custom properties. The settings will be merged in the same BaseContainer that is passed to the
                        iCustomGui.
                        I have only one problem left, unfortunately. I want one of the custom properties to be a String.
                        static CustomProperty BannerGuiProperties[] = {
                          **{ CUSTOMTYPE_STRING, BANNERGUI_HALIGN,         "ALIGN_H" },**
                        But when the property is specified in the Description resource, the entry in the settings container I
                        get in the iCustomGui is empty (DA_NIL). If the property is left out, I get the default value that I
                        initialized in CustomDataTypeClass::GetDefaultProperties() (which is fine).
                                GROUP {
                                    BANNER TEST { ICON_ID 5159; WIDTH 16; ALIGN_H "center"; LOCKSCALE; TRANSPARENT; }
                        class BannerGuiDataType : public CustomDataTypeClass {
                          typedef CustomDataTypeClass super;
                          // CustomDataTypeClass
                            return CUSTOMDATATYPE_BANNER;
                          virtual CustomDataType* AllocData() override
                            return NewObjClear(CustomDataType);
                          virtual void FreeData(CustomDataType* data) override
                            DeleteObj(data);
                          virtual Bool CopyData(
                            const CustomDataType* src, CustomDataType* dest, AliasTrans* at)
                            override
                            return true;
                          virtual Int32 Compare(const CustomDataType* d1, const CustomDataType* d2)
                            override
                            return -1;
                          virtual Bool WriteData(const CustomDataType* data, HyperFile* hf) override
                            return true;
                          virtual Bool ReadData(CustomDataType* data, HyperFile* hf, Int32 level)
                            override
                            return true;
                            return "BANNER";
                            return ::BannerGuiProperties;
                          virtual void GetDefaultProperties(BaseContainer& data) override
                            data.SetInt32(BANNERGUI_ICONID, 0);
                            data.SetInt32(BANNERGUI_BGCOLOR_ID, -1);
                            data.SetVector(BANNERGUI_BGCOLOR_VECTOR, Vector(0, 0, 0));
                            data.SetBool(BANNERGUI_TRANSPARENT, false);
                            data.SetString(BANNERGUI_HALIGN, "LEFT");
                            data.SetInt32(BANNERGUI_WIDTH, -1);
                            data.SetInt32(BANNERGUI_HEIGHT, -1);
                            data.SetBool(BANNERGUI_LOCKSCALE, false);
                            data.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF);
                            data.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_BANNER);
                        BannerGui::BannerGui(
                          const BaseContainer& bc, CUSTOMGUIPLUGIN* plugin)
                          : super(bc, plugin), iconData(), ownsBitmap(false)
                          this->ua = NewObjClear(BannerGuiUserArea, this);
                          this->iconId = bc.GetInt32(BANNERGUI_ICONID, 0);
                          this->transparent = bc.GetBool(BANNERGUI_TRANSPARENT);
                          if (bc.GetInt32(BANNERGUI_BGCOLOR_ID, -1) < 0) {
                            this->bgColor = bc.GetVector(BANNERGUI_BGCOLOR_VECTOR);
                          else {
                            this->bgColor = bc.GetInt32(BANNERGUI_BGCOLOR_ID);
                          const String alignMode = bc.GetString(BANNERGUI_HALIGN).ToLower();
                          if (alignMode == "right") {
                            this->alignH = BANNERGUI_HALIGN_RIGHT;
                          else if (alignMode == "center") {
                            this->alignH = BANNERGUI_HALIGN_CENTER;
                          else if (alignMode == "left" || true) {
                            this->alignH = BANNERGUI_HALIGN_LEFT;
                          this->width = bc.GetInt32(BANNERGUI_WIDTH, -1);
                          this->height = bc.GetInt32(BANNERGUI_HEIGHT, -1);
                          this->lockScale = bc.GetBool(BANNERGUI_LOCKSCALE, false);
                          GePrint("HALIGN Dtype: " + String::IntToString(bc.GetType(BANNERGUI_HALIGN)));
                          GePrint("Icon ID: " + String::IntToString(this->iconId));
                          GePrint("alignMode: " + alignMode);
                          GePrint("Width: " + String::IntToString(this->width));
                          GePrint("Height: " + String::IntToString(this->height));
                          GePrint("LockScale: " + String::IntToString(this->lockScale));
                        An idea where the problem could be? Thanks!
                        Niklas
                          On 26/01/2015 at 10:55, xxxxxxxx wrote:
                          ">I'm not sure where the problem could be!! "I usually get problems with .res files "I like C++ functions more""
                          what I did in my custom data type class and it worked
                          virtual Bool _GetDescription(const CustomDataType* data, Description& desc, DESCFLAGS_DESC& flags, const BaseContainer& parentdescription, DescID* singledescid)
                          	//won't read res file!!
                          	//edited the code
                          	DescID cid = DescLevel( **/* your ID here, same as the ID used in GetParameter() */ YOURID** , DTYPE_STRING, 0);
                          	if (!singleid || cid.IsPartOf(*singledescid, nullptr)) // important to check for speedup c4d!
                          		BaseContainer mstring = GetCustomDataTypeDefault(DTYPE_STRING);
                          		mstring .SetString(BANNERGUI_HALIGN, "left");
                          		if (!desc.SetParameter(cid, mstring, DescLevel(0)))
                          			return true;
                          	return SUPER::_GetDescription(data, desc, flags, parentdescription, singledescid);
                            On 29/01/2015 at 10:13, xxxxxxxx wrote:
                                    GROUP {
                            Hmm, not sure if that's the problem but get rid of the "":
                                        BANNER TEST { ICON_ID 5159; WIDTH 16; ALIGN_H center; LOCKSCALE; TRANSPARENT; }
                            Also, you shouldn't require a custom datatype to get the settings. At least it works here with a custom gui finely.
                              On 11/03/2015 at 12:04, xxxxxxxx wrote:
                              Niklas,
                              have you been able to get it working?
                                On 22/05/2015 at 06:00, xxxxxxxx wrote:
                                No unfortunately not. But I had an idea: Could it be that String  custom property can not be a hardcoded
                                string inside the description resource, but must instead be a resource symbol that will be loaded from the
                                stringtable? I'll try it out as soon as I can.
                                  On 22/05/2015 at 06:14, xxxxxxxx wrote:
                                  Hmm, I don't think so. The above way does not work for you?
                                  In my custom gui I get the string in the constructor with
                                  m_unit = settings.GetString(MY_UNIT);
                                  and in my description resource it looks like this
                                  REAL ELEMENT_ID { MIN 0; MAX 100; CUSTOMGUI FXUNIT; MY_UNIT SQR_METER; }
                                  then I get a string from the stringtable with
                                  if(m_unit.Compare("SQR_METER")==0)
                                  unit_str = GeLoadString(DPIT_SQR);
                                  works all fine here.
                                    On 22/05/2015 at 06:23, xxxxxxxx wrote:
                                    Katachi, that is actually what I meant in my previous post. 🙂 And right now I see in the SDK, the
                                    documentation of CUSTOMTYPE_STRING says: "String data. (An ID from the string table.)".
                                    So, to use it, it must be set up like this?
                                    mydescription.res
                                    CONTAINER mydescription {
                                        GROUP {
                                            BANNER MY_BANNER { TITLE MY_BANNER_TITLE; }
                                    mydescription.str
                                    STRINGTABLE mydescription {
                                        MY_BANNER_TITLE "The string to be passed to the TITLE property here";
                                    I thought I could use it to write in-line strings into the description. I wanted to use it to specify the
                                    alignment of the banner image using the words "left", "center" and "right" instead of using integers
                                    like -1, 0 and 1 respectively.
                                    Solved [x]
                                      On 22/05/2015 at 06:38, xxxxxxxx wrote:
                                      yes, exactly like that. 🙂 Yeah, directly inline won't work but well you can still use LEFT, RIGHT and CENTER instead of MY_BANNER_TITLE right? You would just add each of them to your .str file like:
                                      LEFT "Left";
                                      CENTER "Center";
                                      RIGHT "Right";
                                        On 22/05/2015 at 07:49, xxxxxxxx wrote:
                                        But my plugin is a Custom Gui plugin, and the other plugin that makes use of the Custom Gui should
                                        not need to add LEFT CENTER and RIGHT to its Stringtable when it wants to use the Custom Gui. 😉
                                          On 22/05/2015 at 12:32, xxxxxxxx wrote:
                                          It doesn't have to. The other plugin can simply use LEFT, RIGHT and CENTER as well (of course the custom gui must be installed). It doesn't have to redefine them in its stringtable. Or what do you mean?
                                            On 22/05/2015 at 23:30, xxxxxxxx wrote:
                                            Oh really? In what Stringtable need LEFT,CENTER and RIGHT be defined then?
