    Custom Gui - How to hide the label?
    33 Posts 0 Posters 19.6k Views
      On 09/01/2015 at 09:00, xxxxxxxx wrote:
      Cinema 4D Version:   R15,R16
      How can you hide the Label of a Parameter in the Attributes Manager for your Custom Gui? Like the
      Button Gui, it displays the name on the Button itself and the label to the left is hidden. I want this
      for my Custom Gui, too. How can I do it?
      Thanks in advance
      Niklas
        On 09/01/2015 at 09:13, xxxxxxxx wrote:
        Hi Niklas,
        not completely sure, yet. But as I won't have the time to look into it any deeper today, I thought, I'd post nevertheless.
        I think, the label is part of the user data part and does not belong to your custom gui. For example, if yopu add your custom gui to a GeDialog, there will be no label. Using a space (an empty string is not possible) for the name and unchecking "Animateable" may be a workaround.
          On 09/01/2015 at 09:32, xxxxxxxx wrote:
          Hello Andreas,
          thanks for your (very) quick reply. Unfortunately, it's not as easy as to just turn off animateable
          and make the name a whitespace. See below
          I thought it must be possible because there are no options that you have to specify for the Button
          to work this way. And I think I have seen some plugins that use a banner in their descriptions which
          don't have this problem either.
          Best
          Niklas
            On 09/01/2015 at 09:34, xxxxxxxx wrote:
            I'll look into it more deeply, as soon as I find a minute.
              On 09/01/2015 at 10:09, xxxxxxxx wrote:
              Stupid question... how did you get that button in user data? Or is it part of your custom gui?
                On 09/01/2015 at 10:22, xxxxxxxx wrote:
                You can add buttons to User Data since R16 (due to the new message() callback in Python Tags and
                Generators and the Interaction Tag). Before R15, it was possible to create a User Data button from
                Python code. 🙂 (but not really register the press)
                  On 09/01/2015 at 11:23, xxxxxxxx wrote:
                  And me stupid an R15 open...
                    On 09/01/2015 at 13:24, xxxxxxxx wrote:
                    Can you try to use ## for the name of your custom gui user data?
                    I know, this is still not the final solution.
                    I'm only slowly getting there...
                    It's got something to do withDescriptionCustomGui[URL-REMOVED]
                    In theDESCRIPTION_CUSTOMGUISETTINGS[URL-REMOVED] there's a DESCRIPTION_SHOWTITLE flag, which I guess will do the trick in the end.
                    If it weren't you, I wouldn't have posted such an incomplete clutter, but I thought, you may want to have something to chew on for the weekend 😉
                      On 09/01/2015 at 14:29, xxxxxxxx wrote:
                      Thanks Andreas, I'm going to try that. Don't worry, I really welcome even small hints, because it might
                      help me already to find a solution. 🙂
                      Btw, just a small question which is sort of  related: How do you specify Custom GUI properties in a
                      description resource file? It doesn't work if I do it like this:
                      LONG MYBANNER { ICON_ID 1232024; BGCOLOR_ID 1001; CUSTOMGUI BANNER; }
                      nor
                      LONG MYBANNER {CUSTOMGUI BANNER { ICON_ID 1232024; BGCOLOR_ID 1001; }; }
                      Niklas
                      Update:  Regarding the original question, it seems like it is as simple as to put the item into its own
                      group and not give it a name at all (which is not possible with user data). It would still nice to be able
                      to make it similar to the Button Gui, without the need to encapsule it into a Group.
                      Update :
                      It's got something to do with DescriptionCustomGui
                      In the DESCRIPTION_CUSTOMGUISETTINGS there's a DESCRIPTION_SHOWTITLE flag, which I guess will do the trick in the end.
                      I think that these flags are only for the DescriptionCustomGui, which is the Custom Gui to display a
                      complete Description of a node (ie. the complete Attributes Manager is a DescriptionCustomGui) and
                      a CustomGui plugin has probably no influence on these settings, and if it would, it would have
                      global effects for all parameters displayed.
                      But thanks 🙂
                        On 12/01/2015 at 03:28, xxxxxxxx wrote:
                        Hi Niklas,
                        regarding DescriptionCustomGui you are right. I got carried away by the DESCRIPTION_SHOWTITLE flag...
                        What I don't understand is your group workaround... I thought your question was about using the custom gui in user data. Now, your screenshot seems to show a tag with its own description resource. Where on my side, there never was a problematic label...
                        Custom GUI properties:
                        My first thought was CustomGuiData and implementing all needed properties in there. On the other hand, I think, I learned this from one of your examples... so I'm probably wrong again.
                        To be honest, I have no idea, if there's an automatic mechanism making properties of custom guis propagate through other customguis, where they are used in.
                          On 12/01/2015 at 05:35, xxxxxxxx wrote:
                          Hello Andreas,
                          Yes, it seems to work fine in descriptions by putting it into a group. It would still be nice if the Custom
                          Gui would function the same in User Data.
                          Also, what I have not yet mentioned, is that I had posted a very similar question in the beta forums
                          months ago where I was trying to implement my own Button Custom Gui. There is the problematic
                          label again. I will send you the link in a private message as I don't know whether I am allowed to post
                          it here or not, even though non-beta users won't have access.
                          About Custom Gui Properties : I think you can set them in a dialog resource, but I have not found
                          out how you can specify them in description resources, apart from manually creating the custom GUI
                          in NodeData::GetDDescription() (which would not be available for Python, and this custom GUI should
                          be used for a Python plugin.
                            On 13/01/2015 at 08:01, xxxxxxxx wrote:
                            Andreas, were you gather more information or ask the developers?
                            And should I start a separate topic about the Custom GUI Properties in Description Files?
                              On 13/01/2015 at 08:29, xxxxxxxx wrote:
                              Hello Niklas,
                              yes, I have had some time to read the code and also get some developer feedback, but I was lacking the time to answer...
                              And you won't like the answer... the behavior of the normal button in user data is hard coded. And so is the behavior for other custom guis. There's currently no way to emulate the behavior of the button with a custom gui. Sorry.
                              So there's currently no option in the implementation of a custom gui to hide the label of a custom gui in user data. Only option is to name the user data (short name) ##. Then the label will be hidden.
                              Regarding the Custom GUI Properties in description resource files, I did some research as well. I have not found any place this is done in C4D. May be an indicator, this is not possible either. I'll discuss this with the rest of the team tomorrow. Until then there's no need to open another topic.
                                On 13/01/2015 at 09:29, xxxxxxxx wrote:
                                Hello Andreas,
                                I highly appreciate the time you have invested on finding answers, thank you.
                                This was my biggest fear. Well, one must admit that parts of Cinema are very old that might have been
                                designed different by today. It would be nice if such old, even seemingly small things, would be adjusted
                                any time in the future. 🙂
                                Sorry I haven't tested it before, and I still had hope it could be configurable from the plugin, but this
                                is a solution and that is fine. 🙂 Wondering where this is documented though?
                                This would be highly unfortunate. The only way to bring custom user interfaces to the Attributes
                                Manager is via Custom GUIs. Now, if you can not specify their properties in description resources,
                                the only way to configure  them is via GetDDescription(). And this is all not possible from Python.
                                Kind regards
                                Niklas
                                  On 15/01/2015 at 09:33, xxxxxxxx wrote:
                                  Hi Niklas,
                                  forget what I wrote before about CustomGUI properties. It's done all over the place, I simply didn't recognize.
                                  For example a slider:
                                  LONG myID { CUSTOMGUI LONGSLIDER; MINSLIDER 1; MAXSLIDER 1000;}
                                  I think, the problem in your case is, that you expect such properties to propagate through. You'd like to set the properties of a BITMAPBUTTON CustomGUI, which is embedded in your own CustomGUI BANNER. And this won't work.
                                  You will have to implement CustomGuiData for your BANNER and define the needed properties in there. And then you will have to use these to configure the embedded BITMAPBUTTON.
                                  Sorry, for the confusion and that this took a bit longer. I needed some time to unravel the knots in my head.
                                    On 15/01/2015 at 10:45, xxxxxxxx wrote:
                                    Hello Andreas,
                                    Are you sure these properties are not part of the datatype instead of the Custom GUI? I think MINSLIDER and MAXSLIDER sare part of the **  LONG** datatype, implemented in CustomDataTypeClass::GetProperties(). When creating user-data, you can specify these values not in the "Details" Tab (where the properties are listed) but in the "Properties" Tab (where you change the datatype of the parameter, etc. [Yes, confusing]).
                                    Actually, no. I only have a GeUserArea in my CustomGui dialog and I define the properties in the CustomGuiData subclass.
                                    class BannerGuiCustomGuiData : public CustomGuiData
                                      typedef CustomGuiData super;
                                      // CustomGuiData Overrides
                                      virtual Int32 GetId() override
                                        return CUSTOMGUI_BANNER;
                                      virtual CDialog* Alloc(const BaseContainer& settings) override
                                        BannerGui* dlg = NewObj(BannerGui, settings, this->GetPlugin());
                                        if (dlg) {
                                          return dlg->Get();
                                        return nullptr;
                                      virtual void Free(CDialog* dlg, void* userdata) override
                                        if (userdata) {
                                          BannerGui* gui = static_cast<BannerGui*>(userdata);
                                          DeleteObj(gui);
                                      virtual const Char* GetResourceSym() override
                                        return "BANNER";
                                      virtual CustomProperty* GetProperties() override
                                        static CustomProperty props[] = {
                                          { CUSTOMTYPE_LONG,   BANNERGUI_ICONID,         "ICON_ID" },
                                          { CUSTOMTYPE_LONG,   BANNERGUI_BGCOLOR_ID,     "BGCOLOR_ID" },
                                          { CUSTOMTYPE_VECTOR, BANNERGUI_BGCOLOR_VECTOR, "BGCOLOR_VECTOR" },
                                          { CUSTOMTYPE_FLAG,   BANNERGUI_TRANSPARENT,    "TRANSPARENT" },
                                          { CUSTOMTYPE_STRING, BANNERGUI_HALIGN,         "ALIGN_H" },
                                          { CUSTOMTYPE_LONG,   BANNERGUI_WIDTH,          "WIDTH" },
                                          { CUSTOMTYPE_LONG,   BANNERGUI_HEIGHT,         "HEIGHT" },
                                          { CUSTOMTYPE_FLAG,   BANNERGUI_LOCKSCALE,      "LOCKSCALE" },
                                          { CUSTOMTYPE_END, 0, "" },
                                        return props;
                                      virtual Int32 GetResourceDataType(Int32*& table) override
                                        static Int32 _table[] = { DA_LONG, DA_LLONG, DA_STRING, DA_FILENAME };
                                        table = _table;
                                        return 4;
                                    Best,
                                    Niklas
                                      On 15/01/2015 at 13:02, xxxxxxxx wrote:
                                      To be honest, I'm not sure at all. 😉
                                      This entire CustomGUI/CustomDataType/resource description/dialog description/dynamic description stuff confused and is still confusing me. No promises made, but sometime I will write an article for the SDK docs, to get this sorted.
                                      On the other hand I tried it here in one of my private plugins.
                                      I just double checked (the plugin contains indeed a CustomDataType as well).
                                      Here's my code:
                                      Int32 ColorHarmonyCustomGuiData::GetId() { return CUSTOMGUI_HARMONY; }
                                      CDialog* ColorHarmonyCustomGuiData::Alloc(const BaseContainer& settings)
                                        m_pDlg = NewObj(ColorHarmonyCustomGuiWheel, settings, GetPlugin());
                                        if (!m_pDlg) {
                                          return nullptr;
                                        return m_pDlg->Get();
                                      void ColorHarmonyCustomGuiData::Free(CDialog* dlg, void* ud)
                                        if (dlg) {
                                          DeleteObj((GeDialog*&)dlg);
                                      const Char* ColorHarmonyCustomGuiData::GetResourceSym()
                                        return "HARMONY";
                                      CustomProperty g_cpHarmonyWheelProps[] =
                                        { CUSTOMTYPE_LONG, HARMONY_RGB_FIRST, "NUM_HARMONIES" }, // SDK Support Test
                                        { CUSTOMTYPE_END, 0, nullptr }
                                      CustomProperty* ColorHarmonyCustomGuiData::GetProperties()
                                        return g_cpHarmonyWheelProps;
                                      Int32 ColorHarmonyCustomGuiData::GetResourceDataType(Int32*& table)
                                        static Int32 l_table[] = { DTYPE_COLOR, CUSTOMDATATYPE_GRADIENT, CUSTOMDATATYPE_HARMONY };
                                        table = l_table;
                                        return sizeof(l_table);
                                      And in a test resource file, I used:
                                      COLOR ID_TESTOBJECT_HARMONY { FIT_H; SCALE_H; ANIM OFF; CUSTOMGUI HARMONY; NUM_HARMONIES 5; }
                                      I'll double check the LONG datatype tomorrow.
                                        On 15/01/2015 at 18:19, xxxxxxxx wrote:
                                        Thanks Andreas! Not only to you is it confusing. I don't even want't to tell how much time I had
                                        to invest to get around the CustomGui and CustomDataType stuff. It's poorly documented/explained.
                                        One idea came up while I read your reply: Maybe it doesn't work because the ID of my property
                                        conflicts with an existing ID? BANNERGUI_ICONID for instance has the ID 1000. I'm gonna check
                                        this tomorrow. 🙂
                                          On 23/01/2015 at 07:02, xxxxxxxx wrote:
                                          That wasn't it. The obvious solution was to make a CustomDataTypeClass plugin that exposes the
                                          same custom properties. The settings will be merged in the same BaseContainer that is passed to the
                                          iCustomGui.
                                          I have only one problem left, unfortunately. I want one of the custom properties to be a String.
                                          static CustomProperty BannerGuiProperties[] = {
                                            **{ CUSTOMTYPE_STRING, BANNERGUI_HALIGN,         "ALIGN_H" },**
                                          But when the property is specified in the Description resource, the entry in the settings container I
                                          get in the iCustomGui is empty (DA_NIL). If the property is left out, I get the default value that I
                                          initialized in CustomDataTypeClass::GetDefaultProperties() (which is fine).
                                                  GROUP {
                                                      BANNER TEST { ICON_ID 5159; WIDTH 16; ALIGN_H "center"; LOCKSCALE; TRANSPARENT; }
                                          class BannerGuiDataType : public CustomDataTypeClass {
                                            typedef CustomDataTypeClass super;
                                            // CustomDataTypeClass
                                              return CUSTOMDATATYPE_BANNER;
                                            virtual CustomDataType* AllocData() override
                                              return NewObjClear(CustomDataType);
                                            virtual void FreeData(CustomDataType* data) override
                                              DeleteObj(data);
                                            virtual Bool CopyData(
                                              const CustomDataType* src, CustomDataType* dest, AliasTrans* at)
                                              override
                                              return true;
                                            virtual Int32 Compare(const CustomDataType* d1, const CustomDataType* d2)
                                              override
                                              return -1;
                                            virtual Bool WriteData(const CustomDataType* data, HyperFile* hf) override
                                              return true;
                                            virtual Bool ReadData(CustomDataType* data, HyperFile* hf, Int32 level)
                                              override
                                              return true;
                                              return "BANNER";
                                              return ::BannerGuiProperties;
                                            virtual void GetDefaultProperties(BaseContainer& data) override
                                              data.SetInt32(BANNERGUI_ICONID, 0);
                                              data.SetInt32(BANNERGUI_BGCOLOR_ID, -1);
                                              data.SetVector(BANNERGUI_BGCOLOR_VECTOR, Vector(0, 0, 0));
                                              data.SetBool(BANNERGUI_TRANSPARENT, false);
                                              data.SetString(BANNERGUI_HALIGN, "LEFT");
                                              data.SetInt32(BANNERGUI_WIDTH, -1);
                                              data.SetInt32(BANNERGUI_HEIGHT, -1);
                                              data.SetBool(BANNERGUI_LOCKSCALE, false);
                                              data.SetInt32(DESC_ANIMATE, DESC_ANIMATE_OFF);
                                              data.SetInt32(DESC_CUSTOMGUI, CUSTOMGUI_BANNER);
                                          BannerGui::BannerGui(
                                            const BaseContainer& bc, CUSTOMGUIPLUGIN* plugin)
                                            : super(bc, plugin), iconData(), ownsBitmap(false)
                                            this->ua = NewObjClear(BannerGuiUserArea, this);
                                            this->iconId = bc.GetInt32(BANNERGUI_ICONID, 0);
                                            this->transparent = bc.GetBool(BANNERGUI_TRANSPARENT);
                                            if (bc.GetInt32(BANNERGUI_BGCOLOR_ID, -1) < 0) {
                                              this->bgColor = bc.GetVector(BANNERGUI_BGCOLOR_VECTOR);
                                            else {
                                              this->bgColor = bc.GetInt32(BANNERGUI_BGCOLOR_ID);
                                            const String alignMode = bc.GetString(BANNERGUI_HALIGN).ToLower();
                                            if (alignMode == "right") {
                                              this->alignH = BANNERGUI_HALIGN_RIGHT;
                                            else if (alignMode == "center") {
                                              this->alignH = BANNERGUI_HALIGN_CENTER;
                                            else if (alignMode == "left" || true) {
                                              this->alignH = BANNERGUI_HALIGN_LEFT;
                                            this->width = bc.GetInt32(BANNERGUI_WIDTH, -1);
                                            this->height = bc.GetInt32(BANNERGUI_HEIGHT, -1);
                                            this->lockScale = bc.GetBool(BANNERGUI_LOCKSCALE, false);
                                            GePrint("HALIGN Dtype: " + String::IntToString(bc.GetType(BANNERGUI_HALIGN)));
                                            GePrint("Icon ID: " + String::IntToString(this->iconId));
                                            GePrint("alignMode: " + alignMode);
                                            GePrint("Width: " + String::IntToString(this->width));
                                            GePrint("Height: " + String::IntToString(this->height));
                                            GePrint("LockScale: " + String::IntToString(this->lockScale));
                                          An idea where the problem could be? Thanks!
                                          Niklas
                                            On 26/01/2015 at 10:55, xxxxxxxx wrote:
                                            ">I'm not sure where the problem could be!! "I usually get problems with .res files "I like C++ functions more""
                                            what I did in my custom data type class and it worked
                                            virtual Bool _GetDescription(const CustomDataType* data, Description& desc, DESCFLAGS_DESC& flags, const BaseContainer& parentdescription, DescID* singledescid)
                                            	//won't read res file!!
                                            	//edited the code
                                            	DescID cid = DescLevel( **/* your ID here, same as the ID used in GetParameter() */ YOURID** , DTYPE_STRING, 0);
                                            	if (!singleid || cid.IsPartOf(*singledescid, nullptr)) // important to check for speedup c4d!
                                            		BaseContainer mstring = GetCustomDataTypeDefault(DTYPE_STRING);
                                            		mstring .SetString(BANNERGUI_HALIGN, "left");
                                            		if (!desc.SetParameter(cid, mstring, DescLevel(0)))
                                            			return true;
                                            	return SUPER::_GetDescription(data, desc, flags, parentdescription, singledescid);
