    How to rotate tangents
    11 Posts 0 Posters 2.4k Views
      On 11/12/2002 at 09:50, xxxxxxxx wrote:
      Just treat them as ordinary vectors in object space. How exactly do you want to rotate them?
        On 11/12/2002 at 09:56, xxxxxxxx wrote:
        well, I am calculating a rotationvector from a splinetangent with:
            Vector rot = obj->GetSplineTangent(obj->UniformTonatural(x*(lenght/4)/length),0);
        Now I want to rotate the tangents with this rotationvector.
        I tried this with
            objt[0].vl *= rot;
              objt[0].vr *= rot;
        but that doesn´t work.
          On 11/12/2002 at 11:08, xxxxxxxx wrote:
          Use ^= since vl and vr are vectors not points. And I see no rotation matrix, just a rotation vector. (vector * vector = dot product) Use RotAxisToMatrix() before multiplying.
            On 12/12/2002 at 08:34, xxxxxxxx wrote:
            thanks I will try that. And another question without the need to open a new thread.
            I have a LINK Description for my plugintag, but how to retrieve the dropped object?
            Samir
              On 12/12/2002 at 08:52, xxxxxxxx wrote:
              or of a string field from a STRING description.
              String str = data->GetString(ID); or
              String str; data->GetString(ID,str);
              do both not work.
                On 12/12/2002 at 10:10, xxxxxxxx wrote:
                I tried this but it doesn´t seem to work either. In the doc example there is a t_data instead of my data, but I have no clue what it is good for. Help please...
                Bool DPTransfer::Message(GeListNode *node,LONG type,void *data)
                    if (type == MSG_DESCRIPTION_CHECKDRAGANDDROP)
                      DescriptionCheckDragAndDrop *dcu = static_cast<DescriptionCheckDragAndDrop*>( data ); //t_data??
                      switch (dcu->id[0].id)
                          case DPT_BASE_FOUND:
                          dragged = (BaseObject* )dcu->element;
                  On 12/12/2002 at 10:24, xxxxxxxx wrote:
                  ok sorted it. It works exactly like that. Only my fault. 🙂
                  Thanks anyway for looking. g*
                    On 02/05/2005 at 06:25, xxxxxxxx wrote:
                    Hi All,
                    Works for me to sofar, but here you check for a object hoovering above the Link. It can be used to accept or refuse the hoovering object.
                    Now, how do i find out when the object is finally dropped.
                    There seem to be no message for that.
                      On 03/05/2005 at 02:15, xxxxxxxx wrote:
                      Wouldn't that be an ordinary SetDParameter() call?
                        On 03/05/2005 at 11:21, xxxxxxxx wrote:
                        Hi Mikael,
                        Thanks for your answer but a GePrint("Bingo")  does not appear in my console with the SetDParameter() call.
                        A lot of Bingo's in the tags Message function, listening to MSG_DESCRIPTION_CHECKDRAGANDDROP on hoovering.
                        (i have a Description res Linkbox, its for the AM)
                        What am i doing wrong?
