    How to rotate tangents
    11 Posts 0 Posters 2.0k Views
      On 11/12/2002 at 09:26, xxxxxxxx wrote:
      Cinema 4D Version:   8.012
      how can I rotate the tangents of a bezier spline? I don´t know how to handle the tangent[x].vl and .vr vectors. In cinema it´s definetly easier 😉
      Samir
        On 11/12/2002 at 09:50, xxxxxxxx wrote:
        Just treat them as ordinary vectors in object space. How exactly do you want to rotate them?
          On 11/12/2002 at 09:56, xxxxxxxx wrote:
          well, I am calculating a rotationvector from a splinetangent with:
              Vector rot = obj->GetSplineTangent(obj->UniformTonatural(x*(lenght/4)/length),0);
          Now I want to rotate the tangents with this rotationvector.
          I tried this with
              objt[0].vl *= rot;
                objt[0].vr *= rot;
          but that doesn´t work.
            On 11/12/2002 at 11:08, xxxxxxxx wrote:
            Use ^= since vl and vr are vectors not points. And I see no rotation matrix, just a rotation vector. (vector * vector = dot product) Use RotAxisToMatrix() before multiplying.
              On 12/12/2002 at 08:34, xxxxxxxx wrote:
              thanks I will try that. And another question without the need to open a new thread.
              I have a LINK Description for my plugintag, but how to retrieve the dropped object?
              Samir
                On 12/12/2002 at 08:52, xxxxxxxx wrote:
                or of a string field from a STRING description.
                String str = data->GetString(ID); or
                String str; data->GetString(ID,str);
                do both not work.
                  On 12/12/2002 at 10:10, xxxxxxxx wrote:
                  I tried this but it doesn´t seem to work either. In the doc example there is a t_data instead of my data, but I have no clue what it is good for. Help please...
                  Bool DPTransfer::Message(GeListNode *node,LONG type,void *data)
                      if (type == MSG_DESCRIPTION_CHECKDRAGANDDROP)
                        DescriptionCheckDragAndDrop *dcu = static_cast<DescriptionCheckDragAndDrop*>( data ); //t_data??
                        switch (dcu->id[0].id)
                            case DPT_BASE_FOUND:
                            dragged = (BaseObject* )dcu->element;
                    On 12/12/2002 at 10:24, xxxxxxxx wrote:
                    ok sorted it. It works exactly like that. Only my fault. 🙂
                    Thanks anyway for looking. g*
                      On 02/05/2005 at 06:25, xxxxxxxx wrote:
                      Hi All,
                      Works for me to sofar, but here you check for a object hoovering above the Link. It can be used to accept or refuse the hoovering object.
                      Now, how do i find out when the object is finally dropped.
                      There seem to be no message for that.
                        On 03/05/2005 at 02:15, xxxxxxxx wrote:
                        Wouldn't that be an ordinary SetDParameter() call?
                          On 03/05/2005 at 11:21, xxxxxxxx wrote:
                          Hi Mikael,
                          Thanks for your answer but a GePrint("Bingo")  does not appear in my console with the SetDParameter() call.
                          A lot of Bingo's in the tags Message function, listening to MSG_DESCRIPTION_CHECKDRAGANDDROP on hoovering.
                          (i have a Description res Linkbox, its for the AM)
                          What am i doing wrong?
