    Loading external scene / no materials problem
    15 Posts 0 Posters 2.0k Views
      On 02/11/2014 at 10:13, xxxxxxxx wrote:
      the texture tags on the loaded object have a question mark on them - if thats helpful info..
        On 02/11/2014 at 10:30, xxxxxxxx wrote:
        Hi Glenn,
        it seems to me, that you forgot to assign the materials to the corresponding texture tags:
        obj = your highpoly object
        mat = the corresponding material
          TexTag=obj.GetTag(c4d.Ttexture)
          TexTag[c4d.TEXTURETAG_MATERIAL] = mat
        Best wishes
        Martin
          On 02/11/2014 at 10:49, xxxxxxxx wrote:
          Hi Martin,
          Still having trouble - this is a script I'm running on a simple file with a single cube with 1 material on it.
          It loads the cube - but still the texture tag with question mark.
              path = "/Applications/MAXON/box.c4d"
              fO = LoadDocument(path, c4d.SCENEFILTER_OBJECTS)
              fM = LoadDocument(path, c4d.SCENEFILTER_MATERIALS)
              #Find the specific object in the file
              obj = fO.SearchObject("Cube")
              mats = fM.GetMaterials()
              mat = mats[0]
                #Make a copy of it in memory
              clone = obj.GetClone()
              doc.InsertObject(clone, None, None)
            On 02/11/2014 at 10:55, xxxxxxxx wrote:
            here's the scene file if it helps
            https://drive.google.com/file/d/0B_WlfEtsbLpJQkFOUWIzellDUUU/view?usp=sharing
              On 02/11/2014 at 11:07, xxxxxxxx wrote:
              you need to insert the material, too and relink it to the object after insertion, like:
                path = "/Users/monkeytack/Desktop/box/box.c4d"
                fO = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_OBJECTS)
                fM = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_MATERIALS)
                mat = mats[0]
                doc.InsertMaterial(mat, checknames=True)
                TexTag=clone.GetTag(c4d.Ttexture)
              Martin
                On 02/11/2014 at 11:21, xxxxxxxx wrote:
                Hurahhh! Thank you!
                  On 02/11/2014 at 13:40, xxxxxxxx wrote:
                  ohhh there's always something else,
                  in my actual scene - there's hundreds of objects, differently coloured using several materials.  It seems when I load in the objects - they don't know which material was originally assigned to the texture tag.  It's just empty.  I could manually somehow write a function to fix all this and match them up again - but seems a lot of uncessary work.  I thought loading a scene would keep all the material and texture data intact.
                    On 02/11/2014 at 13:54, xxxxxxxx wrote:
                    i'm thinking - because it does load in the name of the texture tag name string - i could use this when creating and saving the scene to store the material name it belongs to - then write a function when loading which could search the scene materials and match each object up this way.
                      On 02/11/2014 at 14:24, xxxxxxxx wrote:
                      yeah that worked 👏
                        On 03/11/2014 at 08:39, xxxxxxxx wrote:
                        Hi Glenn,
                        a much simpler approach:
                        concatenate your material and object flags inside the load document function.
                        ask the object for it´s tag assignment and insert the corresponding material.
                        Be sure to ask the original object not the cloned one.
                          fO = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_OBJECTS|c4d.SCENEFILTER_MATERIALS)
                          obj = fO.SearchObject("Cube.1")
                          mat= TexTag[c4d.TEXTURETAG_MATERIAL]
                        Best wishes
                        Martin
                          On 03/11/2014 at 09:14, xxxxxxxx wrote:
                          Thanks Martin, that's a bit more elegant..
                            On 03/11/2014 at 13:44, xxxxxxxx wrote:
                            it's nearly working... I need to iterate through the list of objects - it seems to just manage as far as the number count of the materials - so if I have a hundred objects and 3 materials - it will only assign up to 3 objects..
                            olist = fO.SearchObject("Vecfield Final").GetChildren()
                            for obj in olist:
                                    mat = TexTag[c4d.TEXTURETAG_MATERIAL]
                              On 03/11/2014 at 15:37, xxxxxxxx wrote:
                              I see the problem now.
                              If you insert the material with only one linked object it remains in this status.
                              A maybe not that elegant but working solution is this:
                              store all connections in a list and assign it after insertion.
                              If someone has a better idea I´ll be interested.
                                olist = fO.SearchObject("Vectorfield").GetChildren()
                                #set up an assignment list to associate the object with the material
                                AssList=[]
                                for obj in olist:
                                    AssList.append([obj,mat])
                                #insert all materials
                                mats=fO.GetMaterials()
                                for mat in mats:
                                    doc.InsertMaterial(mat, checknames=False)
                                #insert all objects and assign the corresponding material
                                for om in AssList:
                                    clone = om[0].GetClone()
                                    TexTag[c4d.TEXTURETAG_MATERIAL] = om[1]
                              Best wishes
                              Martin
                                On 03/11/2014 at 15:50, xxxxxxxx wrote:
                                Thanks very much for this Martin, I'll try it out.
