    Loading external scene / no materials problem
    15 Posts 0 Posters 2.0k Views
      On 02/11/2014 at 10:30, xxxxxxxx wrote:
      Hi Glenn,
      it seems to me, that you forgot to assign the materials to the corresponding texture tags:
      obj = your highpoly object
      mat = the corresponding material
        TexTag=obj.GetTag(c4d.Ttexture)
        TexTag[c4d.TEXTURETAG_MATERIAL] = mat
      Best wishes
      Martin
        On 02/11/2014 at 10:49, xxxxxxxx wrote:
        Hi Martin,
        Still having trouble - this is a script I'm running on a simple file with a single cube with 1 material on it.
        It loads the cube - but still the texture tag with question mark.
            path = "/Applications/MAXON/box.c4d"
            fO = LoadDocument(path, c4d.SCENEFILTER_OBJECTS)
            fM = LoadDocument(path, c4d.SCENEFILTER_MATERIALS)
            #Find the specific object in the file
            obj = fO.SearchObject("Cube")
            mats = fM.GetMaterials()
            mat = mats[0]
              #Make a copy of it in memory
            clone = obj.GetClone()
            doc.InsertObject(clone, None, None)
          On 02/11/2014 at 10:55, xxxxxxxx wrote:
          here's the scene file if it helps
          https://drive.google.com/file/d/0B_WlfEtsbLpJQkFOUWIzellDUUU/view?usp=sharing
            On 02/11/2014 at 11:07, xxxxxxxx wrote:
            you need to insert the material, too and relink it to the object after insertion, like:
              path = "/Users/monkeytack/Desktop/box/box.c4d"
              fO = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_OBJECTS)
              fM = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_MATERIALS)
              mat = mats[0]
              doc.InsertMaterial(mat, checknames=True)
              TexTag=clone.GetTag(c4d.Ttexture)
            Martin
              On 02/11/2014 at 11:21, xxxxxxxx wrote:
              Hurahhh! Thank you!
                On 02/11/2014 at 13:40, xxxxxxxx wrote:
                ohhh there's always something else,
                in my actual scene - there's hundreds of objects, differently coloured using several materials.  It seems when I load in the objects - they don't know which material was originally assigned to the texture tag.  It's just empty.  I could manually somehow write a function to fix all this and match them up again - but seems a lot of uncessary work.  I thought loading a scene would keep all the material and texture data intact.
                  On 02/11/2014 at 13:54, xxxxxxxx wrote:
                  i'm thinking - because it does load in the name of the texture tag name string - i could use this when creating and saving the scene to store the material name it belongs to - then write a function when loading which could search the scene materials and match each object up this way.
                    On 02/11/2014 at 14:24, xxxxxxxx wrote:
                    yeah that worked 👏
                      On 03/11/2014 at 08:39, xxxxxxxx wrote:
                      Hi Glenn,
                      a much simpler approach:
                      concatenate your material and object flags inside the load document function.
                      ask the object for it´s tag assignment and insert the corresponding material.
                      Be sure to ask the original object not the cloned one.
                        fO = c4d.documents.LoadDocument(path, c4d.SCENEFILTER_OBJECTS|c4d.SCENEFILTER_MATERIALS)
                        obj = fO.SearchObject("Cube.1")
                        mat= TexTag[c4d.TEXTURETAG_MATERIAL]
                      Best wishes
                      Martin
                        On 03/11/2014 at 09:14, xxxxxxxx wrote:
                        Thanks Martin, that's a bit more elegant..
                          On 03/11/2014 at 13:44, xxxxxxxx wrote:
                          it's nearly working... I need to iterate through the list of objects - it seems to just manage as far as the number count of the materials - so if I have a hundred objects and 3 materials - it will only assign up to 3 objects..
                          olist = fO.SearchObject("Vecfield Final").GetChildren()
                          for obj in olist:
                                  mat = TexTag[c4d.TEXTURETAG_MATERIAL]
                            On 03/11/2014 at 15:37, xxxxxxxx wrote:
                            I see the problem now.
                            If you insert the material with only one linked object it remains in this status.
                            A maybe not that elegant but working solution is this:
                            store all connections in a list and assign it after insertion.
                            If someone has a better idea I´ll be interested.
                              olist = fO.SearchObject("Vectorfield").GetChildren()
                              #set up an assignment list to associate the object with the material
                              AssList=[]
                              for obj in olist:
                                  AssList.append([obj,mat])
                              #insert all materials
                              mats=fO.GetMaterials()
                              for mat in mats:
                                  doc.InsertMaterial(mat, checknames=False)
                              #insert all objects and assign the corresponding material
                              for om in AssList:
                                  clone = om[0].GetClone()
                                  TexTag[c4d.TEXTURETAG_MATERIAL] = om[1]
                            Best wishes
                            Martin
                              On 03/11/2014 at 15:50, xxxxxxxx wrote:
                              Thanks very much for this Martin, I'll try it out.
