    Creating Library problem [SOLVED]
    27 Posts 0 Posters 16.9k Views
      On 08/09/2014 at 09:53, xxxxxxxx wrote:
      This is not an instance allocation but a forward declaration of the class.
      And no, a scene hook cannot be allocated (it itself has no allocation functions) because it can only be available once! And this instance I get via FindSceneHook. The function pointers should then call the according member functions of that instance. They are just pointers in the end.
        On 08/09/2014 at 09:58, xxxxxxxx wrote:
        you got me wrong, I didn't mean the first line "which is a forward declaration I know"
        I meant the last 2 lines, Alloc function and Free function, they simply create an instance of the class "which you should create first", after that you can call the function pointer to get the member data of that allocated class
          On 08/09/2014 at 10:04, xxxxxxxx wrote:
          A scene hook cannot be allocated!!! It is only allocated once by Cinema 4D once my module is registered. The call itself comes from the outside (hence the library).
          And even if it was an allocateable class, if I didn't want the user to be able to create an instance of it on his own, I wouldn't need to include it. And that's the case (and no, these two do not allocate an instance, they allow the user to allocate an instance on his own and call the according alloc/free functions of the exposed class). Still, in my understanding this shouldn't change if or how the function pointers operate; which operate on the instance received by FindSceneHook (THAT points to the instance...owned by C4D).
            On 08/09/2014 at 10:15, xxxxxxxx wrote:
            I've created a working version of the example in the SDK for both a class library.
            It works fine. And it returns the correct values. But I'm also not using a scene hook to make it work.
            My custom library gets placed in the plugins folder.
            And to use it I do this in the plugin that uses the library:
                AutoAlloc<MyVector> myVect;
            //Values for the library's methods are set here locally in the plugin using the library's class
              myVect->SetX(5.0);
              myVect->SetY(25.0);
              myVect->SetZ(0.0);
              Real vX = myVect->GetX();
              Real vY = myVect->GetY();
              Real vZ = myVect->GetZ();
              GePrint( RealToString(vX) + " " + RealToString(vY) + " " + RealToString(vZ) );
            If you just want a working version of the example in the SDK. I can send it to you if you like.
            But if you're trying to do something different. Like using a scene hook to use your custom library. Then I can't help.
              On 08/09/2014 at 10:17, xxxxxxxx wrote:
              Hi Scott,
              I already did that example (it was the first I started with) and it worked for me as well. Unfortunately my Hook example doesn't (it's kind of a different situation, where I want to access data that is already available and allocated by C4D internally, while the SDK example is just a data structure class that can (and is supposed to) be allocated anywhere). 😕 Thanks anyway.
                On 08/09/2014 at 10:28, xxxxxxxx wrote:
                well I understand your point, but what I sense is that you should have an instance of the class somewhere, so:
                myclassFunction() {myclass mC; /* .....some stuff */ ; return mC.privateMember;}
                other than that, when doing something similar in a DLL for an API, just giving the user a function is fine as long as this function will create its own work
                other than that I think it is out of my knowledge
                  On 08/09/2014 at 10:45, xxxxxxxx wrote:
                  The class is instanced! The scene hook "MyHook" is implemented in my plugin (and the library from above as well), compiled as: myhook.cdl64.
                  So whenever a user opens a scene in C4D an instance of that hook is allocated by Cinema 4D! This instance is retrieved by using "FindSceneHook" as shown above.
                  The purpose however is that the user can load the library headers into his own c4d plugin project (for example compiling into: myplugin.cdl64).  He should then also be able to use FindSceneHook (see my first posting, second code) and cast it to MyHook_mirror* (That's also how the Thinking Particles library does it btw to retrieve the TP_MasterSystem Scene hook...check out the docs for TP_MasterSystem).
                  When he then calls the function MyHook_mirror::get_value in his plugin project, the function pointer will instead "jump" to the original member function of that hook provided by the library (myhook.cdl64), so granting him outside access to the other dll.
                    On 08/09/2014 at 10:59, xxxxxxxx wrote:
                    ops, well sorry for my previous posts then 😊
                      On 08/09/2014 at 11:26, xxxxxxxx wrote:
                      No problem. It's good to discuss this stuff (also for me it's a proof reading of my own understanding...and apparently I am not right about something). Still hopefully someone out there can shed some light on what I am doing wrong or what I am missing or even what I got wrong here? 😞
                        On 09/09/2014 at 08:22, xxxxxxxx wrote:
                        Hi Katachi, the following works for me (tested on Mac R15 only).
                        You can download the four files from here.
                        main.cpp
                        /* Copyright (C) 2014  Niklas Rosenstein
                         * All rights reserved. */
                        #include "c4d.h"
                        #include "library.h"
                        extern Bool RegisterTestHook();
                        class TestCommand : public CommandData
                          virtual Bool Execute(BaseDocument* doc)
                            TestSceneHook* hook = TestSceneHook::Get(doc);
                            if (!hook)
                              GePrint("No TestSceneHook found in the document.");
                              return true;
                            Int value = hook->GetValue();
                            GePrint("TestSceneHook::GetValue() returned " + String::IntToString(value));
                            return true;
                        Bool PluginStart()
                          if (!RegisterTestHook())
                            GePrint("Failed to register Test Scene Hook.");
                          if (!RegisterCommandPlugin(
                            1000009, "Test Scene Hook Command", 0, nullptr, "",
                            NewObj(TestCommand)))
                            GePrint("Failed to register Test Scene Hook Command.");
                          return true;
                        Bool PluginMessage(Int32 type, void* pData)
                          switch (type)
                            case C4DPL_INIT_SYS:
                              return ::resource.Init();
                          return true;
                        void PluginEnd()
                        library.h
                        #pragma once
                        #include "c4d.h"
                        static const Int32 ID_LIBRARY_TEST = 1000005; // Test ID
                        static const Int32 ID_SCENEHOOK_TEST = 1000007; // Test ID
                        struct TestLibrary : public C4DLibrary
                          Int (*TestSceneHook_GetValue)(const BaseSceneHook* );
                        TestLibrary* GetTestLibrary(Int offset);
                        #ifdef TESTLIB_CALL_MACROS
                          #define CallTestLibR(func) \n    TestLibrary* _lib_ = GetTestLibrary(LIBOFFSET(TestLibrary, func)); \n    if (_lib_ && _lib_->func) \n      return _lib_->func
                        #endif
                        class TestSceneHook : public BaseSceneHook
                          TestSceneHook();
                          ~TestSceneHook();
                          Int GetValue() const;
                          static TestSceneHook* Get(BaseDocument* doc);
                        library.cpp
                        #define TESTLIB_CALL_MACROS
                          static C4DLibrary* cache = nullptr;
                          return static_cast<TestLibrary*>(
                            CheckLib(ID_LIBRARY_TEST, offset, &cache));
                        Int TestSceneHook::GetValue() const
                          CallTestLibR(TestSceneHook_GetValue)(this);
                          return -1;
                        TestSceneHook* TestSceneHook::Get(BaseDocument* doc)
                          return static_cast<TestSceneHook*>(doc->FindSceneHook(ID_SCENEHOOK_TEST));
                        internal.cpp
                        #include "c4d.h"
                        class TestSceneHookData : public SceneHookData
                          Int m_value;
                          static NodeData* Alloc() { return NewObj(TestSceneHookData); }
                          TestSceneHookData() : SceneHookData(), m_value(42) { }
                          Int GetValue() const { return m_value; }
                        Int TestSceneHook_GetValue(const BaseSceneHook* hook)
                          TestSceneHookData* data =
                            static_cast<TestSceneHookData*>(hook->GetNodeData());
                          if (!data) return -1;
                          return data->GetValue();
                          static TestLibrary lib;
                          ClearMem(&lib, sizeof(lib));
                          lib.TestSceneHook_GetValue = &TestSceneHook_GetValue;
                          Bool success = InstallLibrary(ID_LIBRARY_TEST, &lib, 1000, sizeof(lib));
                          if (!success) return false;
                          success = RegisterSceneHookPlugin(
                            ID_SCENEHOOK_TEST, "Test Scene Hook", 0, TestSceneHookData::Alloc,
                            0, 0, nullptr);
                          return success;
                        Best,
                        -Niklas
                          On 09/09/2014 at 12:52, xxxxxxxx wrote:
                          Niklas, using a function layer taking the hook directly...thanks! So obvious but it was so hidden to me. 🙂 You made my day! Appreciate the help, this gets me going.
                            On 09/09/2014 at 14:08, xxxxxxxx wrote:
                            You're welcome. 🙂
                            Btw, I think to make your original example work, you were indeed doing something
                            wrong with calling the pointer-to-member function.
                            Especially this looks strange to me:  lib->mHook.get_value()
                            I think the right code would be something like this:
                            class MyHookLib : public C4DLibrary
                              int ( **SceneHookData** ::*get_value)() const;
                            class MyHookMirror : public BaseSceneHook
                              int get_value() const
                                SceneHookData* data = static_cast<SceneHookData*>(GetNodeData());
                                MyHookLib* lib = CheckLib(...);
                                if (data && lib && lib->get_value)
                                  return **(data- >*lib->get_value)();**
                                return -1;
                            Note that it's using a pointer-to-member function of a SceneHookData class as your own
                            SceneHookData subclass will not be visible to users of your library (and it should work
                            though!).
                            See also: http://www.parashift.com/c++-faq-lite/pointers-to-members.html
                            Best,
                            -Niklas
                              On 09/09/2014 at 14:55, xxxxxxxx wrote:
                              You're welcome. 🙂
                              return (data- >*lib->get_value)();
                              Thanks, but that was not my code but the changed code of Mohamed. My code is the one in the initial thread posting (and does already as you suggest) 🙂
                                int ( SceneHookData ::*get_value)() const;
                                though!).
                                So you are saying that when I am using (MyHook::*get_value) instead of its base class it won't work? I will read up on this link tommorrow (unbelievably tired..), but that would be a bummer. (I mean it would be great if that was the issue, I am all for anything that fixes my problem..hehe)
                                My thoughts were that I can forward declare the class to use for the pointer-to-member function declaration (just as it is done with the iMy1DVector taking the SDK example as refernce). imo that should work. Really must read up on that link. This feels strange (especially as get_value is not defined in SceneHookData).. 🙂 But I'll try it out.
                                  You're welcome. 🙂
                                  Oh sorry, you are right 🙂 But  (((MyHook* )this)->*(lib->get_value))();  is not right either.
                                  this is not MyHook (SceneHookData subclass) but MyHook_mirror (BaseSceneHook subclass), it
                                  is therefore undefined to cast it into a MyHook pointer. 🙂
                                  though!).
                                  I'm not sure what you're trying to say, so I'll try to clarify what I meant: I think that you usually
                                  don't expose the SceneHookData subclass declaration to the third party that uses the functionality
                                  of your plugin provided by your C4DLibrary. The MyHook class will therefore not be defined at this
                                  point in the code.
                                  The syntax is confusing. For pointer-to-member functions you have to declare the type of the
                                  object that you will call the function for. The part after :: does not need to be a member of
                                  the class, but it is the name of the declaration (variable or typedef name).
                                  typedef int (*some_func_t)(FooClass* );
                                  typedef int (FooClass::*some_member_func_t);
                                  some_func_t           func        = &SomeGlobalFunction;
                                  some_member_func_t    member_func = &FooClass::SomeFunction;
                                  Best,
                                  -Niklas
                                    On 10/09/2014 at 00:47, xxxxxxxx wrote:
                                    Hey Niklas!
                                    This should be a pointer to the class (http://www.parashift.com/c++-faq-lite/dotstar-vs-arrowstar.html).
                                    Hmm, then I don't understand the libs used in the C4D API (and the SDK example for creating a library is wrong then?). For example, check out lib_batchrender:
                                    class BatchRender
                                    	private:
                                    		BatchRender();
                                    		~BatchRender();
                                    		Bool Open(void);
                                    //	---INTERNAL STUFF
                                    class iBatchRender; //Forward Declaration!
                                    struct BatchRenderLibrary : public C4DLibrary
                                     Bool					(iBatchRender::\*Open)
                                    Here iBatchRender is forward declared and still used for defining the according member function call. It is also not visible to the third party (me in this case 😄 ) but is simply forward declared in order to make the definition. This is the classic C++ class layering to me.
                                    and check out how the lib now does the library call:
                                    Bool BatchRender::Open()
                                    	BatchRenderLibrary \*lib = CheckBatchRenderLib(LIBOFFSET(BatchRenderLibrary, Open));
                                    	if (!lib || !lib->Open) return FALSE;
                                    	return (((iBatchRender\* )this)->\*(lib->Open))();
                                    It uses iBatchRender here as well (though it's not defined).
                                    To me this looks fine (as forward declared) and should still point correctly to the member function. Can you elaborate a bit more? Thanks!
                                    However, I have definetly not taken into the account the GetNodeData call as you have it. This is a potential gap in my code!!
                                    Thanks!
                                    point in the code.
                                    Yeah, although true, what I mean is that the definition does not need to be available at this point but only at the point when I assign the member function pointer (which happens in the internal.cpp to stay with your code example file names).
                                    Just like with any other forward declaration of classes, as long as I don't call member functions of the pointer (etc.), I can easily use it's declaration in my code even if the class is not yet defined). As all I need here is a pointer-to-class if you want so (since all object pointers are of same size, the compiler shouldn't care).
                                    thanks for this one, I wasn't aware of that actually (or misinterpreted that is was only a declaration name). This is still nightmare syntax and I hate C++ for it as it confuses me 😠 😂
                                      Thanks!
                                      Yes, yes, yes! Thanks so much Niklas. This little thingy seems to have been the culprit!! If I change the code to
                                      (((const MyHook\* )this->GetNodeData())->\*(vlib->get_value))();
                                      then it works!! I now get the correct value :) Of course it then works. It was stupid of me to cast directly to the SceneHookData without using GetNodeData...sigh, I need more sleep!
                                      I will change the other code of mine and see if this works for the other member functions I have as well, but you definetly deserve a beer (was trinkt man bei euch so?)! ;)
                                      I report back if everything works now as expected
                                        On 10/09/2014 at 04:24, xxxxxxxx wrote:
                                        Yep, now it all works like a charm. 👍 it was well worth the discussion!
                                        Sigh, such a minor mistake of mine cost me 3 days...always the same with this coding 😄
