    Creating Library problem [SOLVED]
    27 Posts 0 Posters 16.9k Views
      On 08/09/2014 at 08:17, xxxxxxxx wrote:
      Namespace doesn't seem to have any effect (just tried putting it into the global namespace...same outcome).
      Btw. this is how I call this:
      MyHook_mirror* hookihook = static_cast<MyHook_mirror*>(doc->FindSceneHook(HOOK_ID));
      if(!hookihook || hookihook->GetType() != HOOK_ID){ GePrint("Hook not found");} else GePrint(LongToString(hookihook->get_value())); //this get_value call correctly jumps into MyHook::get_value()!
        On 08/09/2014 at 08:30, xxxxxxxx wrote:
        I'm imagining the problem, so what I will say may be wrong, but may lead you to the correct solution
        the problem lies in: you didn't create an instance of the class, you just instanced the function (that's why you can call it, the function is returning some "relative" address to it , not sure if it will return non zero values in release mode (confirm it))
        try to change it to be:
        //Hook that needs to be exposed
        class MyHook : public SceneHookData
         private: int value;
         public: int get_value() const { return value; } //Correctly jumping in here but value returns 0 although it should be 1
        Bool RegisterHookLib()
            ClearMem(&hooklib, sizeof(hooklib));
          hooklib.mHook            = &MyHook; //here we get the class
            return InstallLibrary(LIBID, &hooklib, 1000, sizeof(hooklib));
        //In the library file
        namespace TESTLIB
           class MyHook_mirror : public BaseSceneHook
             private: MyHook_mirror(); ~MyHook_mirror();
             public: int get_value() const //This implementation is actually in a cpp
                 MyHookLib \*lib = CheckHookLib(LIBOFFSET(MyHookLib , mHook)); //now this should get the class
                 if (!lib || !lib->mHook) return NULL;
                 return ((MyHookLib\* )this)->(lib->mHook.get_value()); //not sure about this line
           //INTERNAL
           struct MyHookLib : public C4DLibrary
                MyHook mHook;
          On 08/09/2014 at 08:49, xxxxxxxx wrote:
          No I cannot create an instance of MyHook. MyHook is NOT visible to the user (that's the whole point of the library and mirroring of the class. Otherwise I wouldn't need a library in the first place). Also it makes no real sense as I want the available hook to be accessed. The C4DLibrary structure works by providing function pointers. Check out the SDK docs (and the libraries in the C4D API)
            On 08/09/2014 at 09:04, xxxxxxxx wrote:
            Is maybe a wrapper class (as shown in the sdk example) mandatory? Does anybody know? Is the sdk support somewhere?
              On 08/09/2014 at 09:28, xxxxxxxx wrote:
              Well, apparently something is wrong, otherwise it would work I assume. But I cannot figure out what it is. Sigh...what am I missing here.. 😕
                On 08/09/2014 at 09:32, xxxxxxxx wrote:
                yea I told you it may be wrong, but the idea is you need a class!!
                I have read the example in the SDK help, you did a mistake!! , you didn't allocate an instance of your class
                class iMy1DVector;
                  struct My1DVectorLib : public C4DLibrary
                    Float (iMy1DVector::*GetX)() const;
                    void (iMy1DVector::*SetX)(Float x);
                    iMy1DVector* (*Alloc)();
                    void (*Free)(iMy1DVector*& p);
                you will need to create an instance of your class no matter what, as I told you before you have a function without a class, so it will not return the class member
                  On 08/09/2014 at 09:53, xxxxxxxx wrote:
                  This is not an instance allocation but a forward declaration of the class.
                  And no, a scene hook cannot be allocated (it itself has no allocation functions) because it can only be available once! And this instance I get via FindSceneHook. The function pointers should then call the according member functions of that instance. They are just pointers in the end.
                    On 08/09/2014 at 09:58, xxxxxxxx wrote:
                    you got me wrong, I didn't mean the first line "which is a forward declaration I know"
                    I meant the last 2 lines, Alloc function and Free function, they simply create an instance of the class "which you should create first", after that you can call the function pointer to get the member data of that allocated class
                      On 08/09/2014 at 10:04, xxxxxxxx wrote:
                      A scene hook cannot be allocated!!! It is only allocated once by Cinema 4D once my module is registered. The call itself comes from the outside (hence the library).
                      And even if it was an allocateable class, if I didn't want the user to be able to create an instance of it on his own, I wouldn't need to include it. And that's the case (and no, these two do not allocate an instance, they allow the user to allocate an instance on his own and call the according alloc/free functions of the exposed class). Still, in my understanding this shouldn't change if or how the function pointers operate; which operate on the instance received by FindSceneHook (THAT points to the instance...owned by C4D).
                        On 08/09/2014 at 10:15, xxxxxxxx wrote:
                        I've created a working version of the example in the SDK for both a class library.
                        It works fine. And it returns the correct values. But I'm also not using a scene hook to make it work.
                        My custom library gets placed in the plugins folder.
                        And to use it I do this in the plugin that uses the library:
                            AutoAlloc<MyVector> myVect;
                        //Values for the library's methods are set here locally in the plugin using the library's class
                          myVect->SetX(5.0);
                          myVect->SetY(25.0);
                          myVect->SetZ(0.0);
                          Real vX = myVect->GetX();
                          Real vY = myVect->GetY();
                          Real vZ = myVect->GetZ();
                          GePrint( RealToString(vX) + " " + RealToString(vY) + " " + RealToString(vZ) );
                        If you just want a working version of the example in the SDK. I can send it to you if you like.
                        But if you're trying to do something different. Like using a scene hook to use your custom library. Then I can't help.
                          On 08/09/2014 at 10:17, xxxxxxxx wrote:
                          Hi Scott,
                          I already did that example (it was the first I started with) and it worked for me as well. Unfortunately my Hook example doesn't (it's kind of a different situation, where I want to access data that is already available and allocated by C4D internally, while the SDK example is just a data structure class that can (and is supposed to) be allocated anywhere). 😕 Thanks anyway.
                            On 08/09/2014 at 10:28, xxxxxxxx wrote:
                            well I understand your point, but what I sense is that you should have an instance of the class somewhere, so:
                            myclassFunction() {myclass mC; /* .....some stuff */ ; return mC.privateMember;}
                            other than that, when doing something similar in a DLL for an API, just giving the user a function is fine as long as this function will create its own work
                            other than that I think it is out of my knowledge
                              On 08/09/2014 at 10:45, xxxxxxxx wrote:
                              The class is instanced! The scene hook "MyHook" is implemented in my plugin (and the library from above as well), compiled as: myhook.cdl64.
                              So whenever a user opens a scene in C4D an instance of that hook is allocated by Cinema 4D! This instance is retrieved by using "FindSceneHook" as shown above.
                              The purpose however is that the user can load the library headers into his own c4d plugin project (for example compiling into: myplugin.cdl64).  He should then also be able to use FindSceneHook (see my first posting, second code) and cast it to MyHook_mirror* (That's also how the Thinking Particles library does it btw to retrieve the TP_MasterSystem Scene hook...check out the docs for TP_MasterSystem).
                              When he then calls the function MyHook_mirror::get_value in his plugin project, the function pointer will instead "jump" to the original member function of that hook provided by the library (myhook.cdl64), so granting him outside access to the other dll.
                                On 08/09/2014 at 10:59, xxxxxxxx wrote:
                                ops, well sorry for my previous posts then 😊
                                  On 08/09/2014 at 11:26, xxxxxxxx wrote:
                                  No problem. It's good to discuss this stuff (also for me it's a proof reading of my own understanding...and apparently I am not right about something). Still hopefully someone out there can shed some light on what I am doing wrong or what I am missing or even what I got wrong here? 😞
                                    On 09/09/2014 at 08:22, xxxxxxxx wrote:
                                    Hi Katachi, the following works for me (tested on Mac R15 only).
                                    You can download the four files from here.
                                    main.cpp
                                    /* Copyright (C) 2014  Niklas Rosenstein
                                     * All rights reserved. */
                                    #include "c4d.h"
                                    #include "library.h"
                                    extern Bool RegisterTestHook();
                                    class TestCommand : public CommandData
                                      virtual Bool Execute(BaseDocument* doc)
                                        TestSceneHook* hook = TestSceneHook::Get(doc);
                                        if (!hook)
                                          GePrint("No TestSceneHook found in the document.");
                                          return true;
                                        Int value = hook->GetValue();
                                        GePrint("TestSceneHook::GetValue() returned " + String::IntToString(value));
                                        return true;
                                    Bool PluginStart()
                                      if (!RegisterTestHook())
                                        GePrint("Failed to register Test Scene Hook.");
                                      if (!RegisterCommandPlugin(
                                        1000009, "Test Scene Hook Command", 0, nullptr, "",
                                        NewObj(TestCommand)))
                                        GePrint("Failed to register Test Scene Hook Command.");
                                      return true;
                                    Bool PluginMessage(Int32 type, void* pData)
                                      switch (type)
                                        case C4DPL_INIT_SYS:
                                          return ::resource.Init();
                                      return true;
                                    void PluginEnd()
                                    library.h
                                    #pragma once
                                    #include "c4d.h"
                                    static const Int32 ID_LIBRARY_TEST = 1000005; // Test ID
                                    static const Int32 ID_SCENEHOOK_TEST = 1000007; // Test ID
                                    struct TestLibrary : public C4DLibrary
                                      Int (*TestSceneHook_GetValue)(const BaseSceneHook* );
                                    TestLibrary* GetTestLibrary(Int offset);
                                    #ifdef TESTLIB_CALL_MACROS
                                      #define CallTestLibR(func) \n    TestLibrary* _lib_ = GetTestLibrary(LIBOFFSET(TestLibrary, func)); \n    if (_lib_ && _lib_->func) \n      return _lib_->func
                                    #endif
                                    class TestSceneHook : public BaseSceneHook
                                      TestSceneHook();
                                      ~TestSceneHook();
                                      Int GetValue() const;
                                      static TestSceneHook* Get(BaseDocument* doc);
                                    library.cpp
                                    #define TESTLIB_CALL_MACROS
                                      static C4DLibrary* cache = nullptr;
                                      return static_cast<TestLibrary*>(
                                        CheckLib(ID_LIBRARY_TEST, offset, &cache));
                                    Int TestSceneHook::GetValue() const
                                      CallTestLibR(TestSceneHook_GetValue)(this);
                                      return -1;
                                    TestSceneHook* TestSceneHook::Get(BaseDocument* doc)
                                      return static_cast<TestSceneHook*>(doc->FindSceneHook(ID_SCENEHOOK_TEST));
                                    internal.cpp
                                    #include "c4d.h"
                                    class TestSceneHookData : public SceneHookData
                                      Int m_value;
                                      static NodeData* Alloc() { return NewObj(TestSceneHookData); }
                                      TestSceneHookData() : SceneHookData(), m_value(42) { }
                                      Int GetValue() const { return m_value; }
                                    Int TestSceneHook_GetValue(const BaseSceneHook* hook)
                                      TestSceneHookData* data =
                                        static_cast<TestSceneHookData*>(hook->GetNodeData());
                                      if (!data) return -1;
                                      return data->GetValue();
                                      static TestLibrary lib;
                                      ClearMem(&lib, sizeof(lib));
                                      lib.TestSceneHook_GetValue = &TestSceneHook_GetValue;
                                      Bool success = InstallLibrary(ID_LIBRARY_TEST, &lib, 1000, sizeof(lib));
                                      if (!success) return false;
                                      success = RegisterSceneHookPlugin(
                                        ID_SCENEHOOK_TEST, "Test Scene Hook", 0, TestSceneHookData::Alloc,
                                        0, 0, nullptr);
                                      return success;
                                    Best,
                                    -Niklas
                                      On 09/09/2014 at 12:52, xxxxxxxx wrote:
                                      Niklas, using a function layer taking the hook directly...thanks! So obvious but it was so hidden to me. 🙂 You made my day! Appreciate the help, this gets me going.
                                        On 09/09/2014 at 14:08, xxxxxxxx wrote:
                                        You're welcome. 🙂
                                        Btw, I think to make your original example work, you were indeed doing something
                                        wrong with calling the pointer-to-member function.
                                        Especially this looks strange to me:  lib->mHook.get_value()
                                        I think the right code would be something like this:
                                        class MyHookLib : public C4DLibrary
                                          int ( **SceneHookData** ::*get_value)() const;
                                        class MyHookMirror : public BaseSceneHook
                                            SceneHookData* data = static_cast<SceneHookData*>(GetNodeData());
                                            MyHookLib* lib = CheckLib(...);
                                            if (data && lib && lib->get_value)
                                              return **(data- >*lib->get_value)();**
                                            return -1;
                                        Note that it's using a pointer-to-member function of a SceneHookData class as your own
                                        SceneHookData subclass will not be visible to users of your library (and it should work
                                        though!).
                                        See also: http://www.parashift.com/c++-faq-lite/pointers-to-members.html
                                        Best,
                                        -Niklas
                                          On 09/09/2014 at 14:55, xxxxxxxx wrote:
                                          You're welcome. 🙂
                                          return (data- >*lib->get_value)();
                                          Thanks, but that was not my code but the changed code of Mohamed. My code is the one in the initial thread posting (and does already as you suggest) 🙂
                                            int ( SceneHookData ::*get_value)() const;
                                            though!).
                                            So you are saying that when I am using (MyHook::*get_value) instead of its base class it won't work? I will read up on this link tommorrow (unbelievably tired..), but that would be a bummer. (I mean it would be great if that was the issue, I am all for anything that fixes my problem..hehe)
                                            My thoughts were that I can forward declare the class to use for the pointer-to-member function declaration (just as it is done with the iMy1DVector taking the SDK example as refernce). imo that should work. Really must read up on that link. This feels strange (especially as get_value is not defined in SceneHookData).. 🙂 But I'll try it out.
