    Just can't get GetPixelInfoPoint to work :-(
    41 Posts 0 Posters 37.7k Views
      On 17/06/2014 at 15:26, xxxxxxxx wrote:
      That's strange.
      I'm getting the object, and the object's point index#s from it just fine in R13.
          //Loop through the pixels in the screen in a matrix like fashion
        //By getting the pixels using Rows & Columns using 2 for loops
        for (LONG i = x1; i <= x2; i++)
            for (LONG j = y1; j <= y2; j++)
                Real rSqrDist = (i - mouseX)*(i - mouseX) + (j - mouseY)*(j - mouseY);
                if (rSqrDist > radSqr) continue;
                //Get the point of an object in the scene at this screen pixel location
                ViewportPixel *pPixel = vps->GetPixelInfoPoint(i, j);
                while (pPixel)
                    //If the point found belongs to our desired target object
                    if (pPixel->op == obj)
                        GePrint(pPixel->op->GetName());    //Prints the name of the object we're selecting points on
                        GePrint(LongToString(pPixel->i));  //Prints the point's index#
                        //This code will select the points on the object if they're within the radius range
                        BaseSelect *bs = obj->GetPointS();
                        bs->Select(pPixel->i);
                    pPixel = pPixel->next;
      I don't know why it's returning Null for you.
      If you want the plugin to play around with. Tell me where to e-mail it and I'll send it to you.
        On 17/06/2014 at 15:41, xxxxxxxx wrote:
        It is a real mystery 😞
        Well, I'm using R14 but it should work fine anyway.
        If you can, please send it over to: [email protected]
        I'm on a Mac, remember?
        Thank you in advance.
          On 17/06/2014 at 16:10, xxxxxxxx wrote:
          Oh yeah. I forgot you're on a Mac.
          Having the actual plugin won't help you any more than the code I posted.
          Have you looked at the "sculpting.cpp" example in the SDK examples?
          That one uses the GetPixelInfoPoint() function in it too.
            On 17/06/2014 at 16:17, xxxxxxxx wrote:
            Yes, I looked into it.
            And using the methods that are used there, I still get Null in the vps->GetPixelInfoPoint(x, y)
              On 17/06/2014 at 18:02, xxxxxxxx wrote:
              I just can't figure out why is this happening 😞
              // the code works fine until here. At this point, pPixel is NULL
                      while (pPixel)
                On 18/06/2014 at 04:52, xxxxxxxx wrote:
                I tried it with python and it works fine. I just can't make it work with C++
                This is driving me crazy!!! 😞
                  On 18/06/2014 at 05:49, xxxxxxxx wrote:
                  Howdy,
                  Have you looked at ViewportPixel::GetNearestPoint()?
                  That function may be easier to use because it has a radius parameter:
                  ViewportPixel *vp = vps->GetNearestPoint(op,x,y,rad);
                  Adios,
                  Cactus Dan
                    On 18/06/2014 at 06:49, xxxxxxxx wrote:
                    Even with GetNearestPoint I still get vp==NULL 😞
                      On 18/06/2014 at 07:46, xxxxxxxx wrote:
                      Howdy,
                      Try this sample code:
                      #include "c4d.h"
                      #include "c4d_symbols.h"
                      #include "lib_collider.h"
                      class TestTool : public ToolData
                      private:
                      	Real mx, my;
                      	Bool mDrag;
                      	virtual TOOLDRAW Draw(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, BaseDrawHelp* bh, BaseThread* bt, TOOLDRAWFLAGS flags);
                      	virtual Bool MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd, EditorWindow *win, const BaseContainer &msg);
                      TOOLDRAW TestTool::Draw(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, BaseDrawHelp* bh, BaseThread* bt, TOOLDRAWFLAGS flags)
                      	BaseObject	*op = doc->GetActiveObject(); if(!op) return TOOLDRAW_0;
                      	if(!(op->IsInstanceOf(Opoint) && ToPoint(op)->GetPointR())) return TOOLDRAW_0;
                      	Real rad = 10.0;
                      	if(mDrag)
                      		bd->SetPen(Vector(0,0,0));
                      		bd->DrawCircle2D(LONG(mx),LONG(my),rad);
                      	return TOOLDRAW_HANDLES|TOOLDRAW_AXIS|TOOLDRAW_HIGHLIGHTS;
                      Bool TestTool::MouseInput(BaseDocument *doc, BaseContainer &data, BaseDraw *bd,EditorWindow *win, const BaseContainer &msg)
                      	BaseObject	*op = doc->GetActiveObject(); if(!op) return false;
                      	if(!(op->IsInstanceOf(Opoint) && ToPoint(op)->GetPointR())) return false;
                      	mx = msg.GetReal(BFM_INPUT_X);
                      	my = msg.GetReal(BFM_INPUT_Y);
                      	LONG button;
                      	switch (msg.GetLong(BFM_INPUT_CHANNEL))
                      		case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break;
                      		case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break;
                      		default: return TRUE;
                      	Real rad = 10.0;
                      	Bool vOnly = true;
                      	AutoAlloc<ViewportSelect> vps; if(!vps) return false;
                      	LONG left, top, right, bottom, width, height;
                      	bd->GetFrame(&left, &top, &right, &bottom);
                      	width = right - left + 1;
                      	height = bottom - top + 1;
                      	vps->Init(width,height,bd,op,Mpoints,vOnly,VIEWPORTSELECTFLAGS_USE_HN|VIEWPORTSELECTFLAGS_USE_DEFORMERS);
                      	vps->SetBrushRadius(rad);
                      	Real dx, dy;
                      	mDrag = false;
                      	BaseContainer bc, device;
                      	win->MouseDragStart(button,mx,my,MOUSEDRAGFLAGS_DONTHIDEMOUSE|MOUSEDRAGFLAGS_NOMOVE);
                      	while (win->MouseDrag(&dx,&dy,&device)==MOUSEDRAGRESULT_CONTINUE)
                      		mx+=dx;
                      		my+=dy;
                      		mDrag = true;
                      		LONG x = mx, y = my;
                      		if(vp)
                      			GePrint(LongToString(vp->i));
                      		DrawViews(DRAWFLAGS_INDRAG|DRAWFLAGS_NO_REDUCTION|DRAWFLAGS_ONLY_ACTIVE_VIEW|DRAWFLAGS_NO_THREAD|DRAWFLAGS_NO_ANIMATION);
                      	mDrag = false;
                      	EventAdd(EVENT_FORCEREDRAW);
                      #define ID_TOOLDATA_TEST		1000007
                      Bool RegisterTestTool(void)
                      	return RegisterToolPlugin(ID_TOOLDATA_TEST,"Test Tool",0,AutoBitmap("Test.tif"),"Test Tool",gNew TestTool);
                      Adios,
                      Cactus Dan
                        On 18/06/2014 at 08:37, xxxxxxxx wrote:
                        I replaced all my code with your code and added the following:
                        ViewportPixel *vp = vps1->GetNearestPoint(op,x,y,rad);
                        if(vp)
                        else
                             GePrint("vp is NULL");
                        And all I got, as I dragged the cursor was "vp is NULL" in the Console 😞
                          On 18/06/2014 at 09:11, xxxxxxxx wrote:
                          Howdy,
                          OK, I added the line:
                          else GePrint("vp is NULL");
                          ... and it only prints that when the mouse is not over a point of the object and within the radius.
                          Adios,
                          Cactus Dan
                            On 18/06/2014 at 09:24, xxxxxxxx wrote:
                            If the code works in Python. Then It's not a code problem.
                            The simplest way to check it is to put this in the sculpting.cpp file's while loop: GePrint(pPixel->op->GetName());
                            If this returns NULL and not the name of the object. Then there's got to be something wrong with your SDK installation.
                              On 18/06/2014 at 09:33, xxxxxxxx wrote:
                              So, why the hell is it not working for me?!?
                              Would you guys be willing to check out my code?
                              It is not much longer than the one posted above by Scott 😉
                                On 18/06/2014 at 09:38, xxxxxxxx wrote:
                                Howdy,
                                Hehe, at this point that may be your only option. If you want to keep your code confidential, feel free to pm or email it to one of us.
                                Adios,
                                Cactus Dan
                                  Scott, I did what you said and the sculpt tool works fine and prints out the name of the object.
                                    On 18/06/2014 at 09:44, xxxxxxxx wrote:
                                    Well, I will send it through pm just because I don't want to show my lame code to everyone 😉
                                    Thank you very much in advance.
                                      On 18/06/2014 at 09:50, xxxxxxxx wrote:
                                      I just sent you a PM with my code, Dan.
                                      I will only send it to Scott if he says it is OK to do so.
                                      Thank you very much in advance to both of you.
                                        On 18/06/2014 at 10:29, xxxxxxxx wrote:
                                        If Dan's willing to help you out. There's no need to send it to me Rui.
                                        He can probably help you better than I can.
                                        Plus, he's a Mac user. So you can send files to each other. And I can't do that.
                                          On 18/06/2014 at 10:33, xxxxxxxx wrote:
                                          Thank you very much for the help, anyway, Scott 🙂
                                          I guess I will be needing more help in the near future, now that I jumped on the C++ boat.
                                          I can compile for Mac and Windows and that is great. But I'm still a newbie.
                                            On 18/06/2014 at 10:53, xxxxxxxx wrote:
                                            Howdy,
                                            Well, I added your "CheckRadius" function to the test code that I posted, and it always prints "pPixel is NULL" the same as you're getting. So that function looks like it is the culprit.
                                            But if I change the code in that function to:
                                            LONG x = mouseX;
                                            LONG y = mouseY;
                                            ViewportPixel *pPixel = vps->GetNearestPoint(current_obj,x,y,radius);
                                            if(pPixel) GePrint(LongToString(pPixel->i));
                                            else GePrint("pPixel is NULL");
                                            ... then it works.
                                            What is the purpose of the code in CheckRadius()? I mean why the nested for() loops?
                                            Edit:
                                            I can see using the nested for() loops in the sculpting tool example in the sdk project, because that tool would need to affect the surrounding points along with the point under the mouse, therefore the use of:
                                            ... but for a painting tool, it just seems like the GetNearestPoint() function would be the easier.
                                            Adios,
                                            Cactus Dan
