    maxon::BaseArray allocation?
    3 Posts 0 Posters 270 Views
      On 21/05/2014 at 20:51, xxxxxxxx wrote:
      Cinema 4D Version:   R15
      Hello Forum,
      Is there a method to test if a maxon::BaseArray has been allocated.
      maxon::BaseArray<Int32> map;
      if (!map) return false; // does not compile
      Or is it safe to assume that the BaseArray is always allocated?
      Thanks for your help,
      Joe
        On 22/05/2014 at 00:06, xxxxxxxx wrote:
        <ADDRESS>
        Mac OSX  ;
        Language(s) :
        C++  ;
        </ADDRESS> Hello Forum,
        [/DIV][DIV]maxon::BaseArray<Int32> map;[/DIV][DIV]if (!map) return false; // does not compile[/DIV][DIV]
        Joe
        You don't have to check this as the object is just created in the current scope, but no memory is allocated yet for the array.
        You've to check either
        - the return value of Append(), Insert() to see if the operation which triggered a memory allocation was successful
        - or the return value of Resize() which triggers memory allocations/releases too
        Best regards,
        Wilfried
          On 22/05/2014 at 00:26, xxxxxxxx wrote:
          Wilfried,
          You have answered my question.  I now see in the docs that BaseArray.Append() returns a pointer and BaseArray.Resize() returns Bool.
          Thank you,
          Joe
