maxon::BaseArray allocation?
On 21/05/2014 at 20:51, xxxxxxxx wrote:
Cinema 4D Version: R15
Platform: Windows ; Mac OSX ;
Language(s) : C++ ;---------
Hello Forum,
Is there a method to test if a maxon::BaseArray has been allocated.maxon::BaseArray<Int32> map; if (!map) return false; // does not compile
Or is it safe to assume that the BaseArray is always allocated?
Thanks for your help,
Joe
On 22/05/2014 at 00:06, xxxxxxxx wrote:
<ADDRESS>
Platform: Windows ;
Mac OSX ;
Language(s) :
C++ ;---------
</ADDRESS> Hello Forum,
Is there a method to test if a maxon::BaseArray has been allocated.[/DIV][DIV]maxon::BaseArray<Int32> map;[/DIV][DIV]if (!map) return false; // does not compile[/DIV][DIV]
JoeYou don't have to check this as the object is just created in the current scope, but no memory is allocated yet for the array.
You've to check either
- the return value of Append(), Insert() to see if the operation which triggered a memory allocation was successful
- or the return value of Resize() which triggers memory allocations/releases tooBest regards,
Wilfried
On 22/05/2014 at 00:26, xxxxxxxx wrote:
Wilfried,
You have answered my question. I now see in the docs that BaseArray.Append() returns a pointer and BaseArray.Resize() returns Bool.
Thank you,
Joe
