    get the project change in core message
    11 Posts 0 Posters 900 Views
      On 27/01/2014 at 13:28, xxxxxxxx wrote:
      try c4d.EVENT_MSG
      Cheers, Seb
        On 27/01/2014 at 13:50, xxxxxxxx wrote:
        thx seb
        class stage_message(plugins.MessageData) :
        	def CoreMessage(self, id, bc) :
        		if id == c4d.EVENT_MSG:
        AttributeError: 'module' object has no attribute 'EVENT_MSG'
          On 29/01/2014 at 12:55, xxxxxxxx wrote:
          do I understand the CoreMessage wrong ?
            On 29/01/2014 at 14:48, xxxxxxxx wrote:
            Try c4d.EVMSG_CHANGE
              On 29/01/2014 at 14:53, xxxxxxxx wrote:
              thx niklas
              the change message will call often - i need only the project change -
                On 30/01/2014 at 02:21, xxxxxxxx wrote:
                What do you understand under the term "project change"?
                  On 30/01/2014 at 03:39, xxxxxxxx wrote:
                  menu - window - switch between different projects
                    On 30/01/2014 at 03:42, xxxxxxxx wrote:
                    So you want to know when the user switched to another project? It sounded like you want to know when a project was changed , ie. modified.
                      On 30/01/2014 at 09:03, xxxxxxxx wrote:
                      This topic has been discussed several times in the forum. For example in this thread:
                      Notification on change of active document
                        On 31/01/2014 at 01:50, xxxxxxxx wrote:
                        thanks to all of you . got it
