    get the project change in core message
    11 Posts 0 Posters 769 Views
      On 27/01/2014 at 13:27, xxxxxxxx wrote:
      Hey i try to get the Message that the project change
      the question is what is the right id
      def CoreMessage(self, id, bc) :
      		if id == xx: #chang projekt
        On 27/01/2014 at 13:28, xxxxxxxx wrote:
        try c4d.EVENT_MSG
        Cheers, Seb
          On 27/01/2014 at 13:50, xxxxxxxx wrote:
          thx seb
          class stage_message(plugins.MessageData) :
          		if id == c4d.EVENT_MSG:
          AttributeError: 'module' object has no attribute 'EVENT_MSG'
            On 29/01/2014 at 12:55, xxxxxxxx wrote:
            do I understand the CoreMessage wrong ?
              On 29/01/2014 at 14:48, xxxxxxxx wrote:
              Try c4d.EVMSG_CHANGE
                On 29/01/2014 at 14:53, xxxxxxxx wrote:
                thx niklas
                the change message will call often - i need only the project change -
                  On 30/01/2014 at 02:21, xxxxxxxx wrote:
                  What do you understand under the term "project change"?
                    On 30/01/2014 at 03:39, xxxxxxxx wrote:
                    menu - window - switch between different projects
                      On 30/01/2014 at 03:42, xxxxxxxx wrote:
                      So you want to know when the user switched to another project? It sounded like you want to know when a project was changed , ie. modified.
                        On 30/01/2014 at 09:03, xxxxxxxx wrote:
                        This topic has been discussed several times in the forum. For example in this thread:
                        Notification on change of active document
                          On 31/01/2014 at 01:50, xxxxxxxx wrote:
                          thanks to all of you . got it
