    User Area Image
    2 Posts 0 Posters 285 Views
      On 16/12/2013 at 12:36, xxxxxxxx wrote:
      I want to add a user area with an image to a dialogue like this:
      GROUP_ID1=1000
      USERAREA=1010
      class Dialog1(gui.GeDialog) :
        class DialogUserArea(c4d.gui.GeUserArea) :
            def GetMinSize(self) :
               self.width = 200
               self.height = 50
               return (self.width, self.height)
            def DrawMsg(self, x1, y1, x2, y2, msg) :
                path = os.path.join(dir, "res", "test.tif")
                result = bmp.InitWith(path)
                result, ismovie = bmp.InitWith(path)
                if result == c4d.IMAGERESULT_OK:
                    print("load ok!")
                    self.DrawBitmap(bmp, 0, 0, bmp.GetBw(), bmp.GetBh(), 0, 0, bmp.GetBw(), bmp.GetBh(), c4d.BMP_NORMALSCALED)
            def Redraw(self) :
                    print("load ok!")
        def CreateLayout(self) :
            self.GroupBegin(GROUP_ID1, c4d.BFH_LEFT, 1, 1)
            self.AddUserArea(USERAREA, flags = c4d.BFH_LEFT, initw=200, inith=50)
            self.GroupEnd()
            ua = Dialog1.DialogUserArea()
            self.AttachUserArea(ua, USERAREA)
            self.LayoutChanged(GROUP_ID1)
            ua.Redraw()
            print XXXXXX # provoke error
      class do_command(c4d.plugins.CommandData) :
        def Execute(self, doc) :
            menu = Dialog1()
            menu.Open(c4d.DLG_TYPE_MODAL, defaultw=215, defaulth=100)
      If I provoke an error message in create layout like print XXXXX the image is there, if CreateLayout returns True there is no image!?
      Probably something stupid, it´s the first time I work with user areas.
      Edited Topic Title
        On 17/12/2013 at 04:38, xxxxxxxx wrote:
        Don´t worry, used a Custom Gui Bitmapbutton for that.
