    definitions for spline deformer
    9 Posts 0 Posters 929 Views
      On 01/11/2013 at 11:32, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      i can't find the definitions for the spline deformer object. can someone point me to them?
      MGSPLINEWRAPDEFORMER_AXIS for example
      thanks in advance,
      Ello
        On 01/11/2013 at 11:42, xxxxxxxx wrote:
        C4D/modules/mograph/res/description/omograph_splinewrap.h
        Best,
        -Niklas
          so, this is something that is not always available in cinema, right?
            On 01/11/2013 at 12:00, xxxxxxxx wrote:
            ah, ok. i see. it is now part of the core. but where is Omograph_splinewrap defined?
            i've included omograph_splinewrap.h but get an error for an undeclared inentifier 'Omograph_splinewrap'
            any ideas?
              On 01/11/2013 at 12:12, xxxxxxxx wrote:
              It isn't defined. Grab a Spline Wrap deformer, ask for its type and add the definition in your source code.
              > #include <c4d.h>
              > #include <omograph_splinewrap.h>
              > enum {
              >     Omograph_splinewrap = 1019221,
              Best,
              -Niklas
                On 01/11/2013 at 12:16, xxxxxxxx wrote:
                thank you very much
                  On 26/06/2014 at 08:02, xxxxxxxx wrote:
                  > #include <c4d.h>
                  > enum {
                  Best,
                  -Niklas
                  Niklas can i ask you a couple of questions about the above:
                  How does the #include <omograph_splinewrap.h> know where to find it?  Would that imply setting the mograph folder up as an Additional Include Directory inside the Properties in VisualStudio?  Or am i missing something obvious?
                  Why are u using these brackets <> around the include as opposed to "" is there any difference?
                  Thanks..
                    On 26/06/2014 at 09:40, xxxxxxxx wrote:
                    Hi Eclektrik,
                    most paths that contain resource description files are already added to the Include Directories of the
                    _api or cinema4dsdk project files. You can manually add the path to the Mograph description resource
                    directory.
                    When using "", the compiler will first take a look into the parent folder of the current file and then
                    search all other specified paths. <> will only search those paths but also built-in headers which must
                    not necessarily exist as files.
                    See http://stackoverflow.com/questions/1367316/include-and-include
                    Best,
                    -Niklas
                      On 27/06/2014 at 03:35, xxxxxxxx wrote:
                      Thanks for the replies Niklas much appreciated.
