    passing variable to plugin
    12 Posts 0 Posters 874 Views
      On 12/10/2013 at 01:04, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      I have been searching and trying for a while, now, but I can't get it to work to pass a variable from main (PluginStart) to my plugin, where I would like to read the value of that variable.
      can someone explain how things like this work?
      Ello
        On 12/10/2013 at 03:09, xxxxxxxx wrote:
        Hi, you could go with a global variable for PODs (int, float, char, ...) and use it wherever you want in your entire plugin.
        Int my_global_variable = 0; // allowed
        String my_global_string; // (* ) not allowed because internal pointer table to the constructor is not build yet
        String* my_global_string = nullptr; // correct!
        Bool PluginStart()
            my_global_string = NewObj(String);
            if (!my_global_string)
                return false;
            // your code
            return true;
        void PluginEnd()
            DeleteMem(my_global_string);
        (* ) If you want to use a c4d class you can use a global pointer like String* and allocate it in PluginStart and Free it in PluginEnd.
        Or you store some values in the global data container.
        Cheers, Seb
          On 12/10/2013 at 04:58, xxxxxxxx wrote:
          i guess i dont't understand. in my main.cpp i have declared a boolean:
          Bool test = false;
          now i want to check this boolean inside another file (myPlugin.cpp)
          BaseObject *myPlugin::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
          if (test) //do something
          of course test is undeclared here. so my question is how can i grab the variable test inside GetVirtualObjects
            On 12/10/2013 at 07:48, xxxxxxxx wrote:
            You can use the extern keyword. See How do I share a variable between source files in C?
            Best,
            -Niklas
              On 12/10/2013 at 08:56, xxxxxxxx wrote:
              thank you. i tried this but still i must do something wrong.
              in the main.cpp i have #include "myPlugin.h"
              and in myPlugin.h i have
              #ifndef _myPlugin_H_
              #define _myPlugin_H_
              extern int myTest;
              enum
              when i try to compile i get the following error:
              1>  Main.cpp
              1>  myPlugin.cpp
              1>     Creating library C:\Program Files\MAXON\CINEMA 4D R14\plugins\myPlugin\obj\myPlugin\x64_Debug\myPlugin.cdl64.lib and object C:\Program Files\MAXON\CINEMA 4D R14\plugins\myPlugin\obj\myPlugin\x64_Debug\myPlugin.cdl64.exp
              1>Main.obj : error LNK2001: unresolved external symbol "int myTest" (?isRegistered@@3HA)
              1>myPlugin.obj : error LNK2001: unresolved external symbol "int myTest" (?isRegistered@@3HA)
              1>C:\Program Files\MAXON\CINEMA 4D R14\plugins\myPlugin\myPlugin.cdl64 : fatal error LNK1120: 1 unresolved externals
              i found this thread http://stackoverflow.com/questions/7004031/c-unresolved-externals but i dont understand what i need to do now...
                On 12/10/2013 at 09:08, xxxxxxxx wrote:
                Howdy,
                Well, in everything I've read about c++ programming, there seems to be a consensus that global variables are frowned upon.
                What I'd suggest is to create a static variable in your main.cpp file, and create accessor functions like this:
                #include "MyPlugin.h"
                static bool test;
                bool PluginStart(void)
                     SetTest(false);
                     // rest of startup functions....
                void SetTest(bool t)
                     test = t;
                bool GetTest(void)
                     return test;
                Then in your main header file (MyPlugin.h or whatever your plugin is named) you prototype the accessor functions:
                void SetTest(bool t);
                bool GetTest(void);
                Then you simply include the main header file in each .cpp file where you need access to the "test" variable:
                if(GetTest())
                     // do something
                Adios,
                Cactus Dan
                  On 12/10/2013 at 09:29, xxxxxxxx wrote:
                  thank you very much for the input..
                  still get the following error message:
                  1>  myPlugin.cpp
                  1>myPlugin.obj : error LNK2001: unresolved external symbol "int __cdecl getTest(void)" (?getTest@@YAHXZ)
                  the thread i mentioned earlier said it is some problem with the linker. and since all those tests result in the same error i guess it must be some general setting i am missing??
                  EDIT: my fault. i mixed a uppercase letter 😉 now working. many thanks !
                    On 12/10/2013 at 09:36, xxxxxxxx wrote:
                    Howdy,
                    Did you forget to include the header?
                    Adios,
                    Cactus Dan
                      On 12/10/2013 at 09:37, xxxxxxxx wrote:
                      ..no, it was a typo... now working 😄
                        On 12/10/2013 at 09:45, xxxxxxxx wrote:
                        Howdy,
                        Ah! Glad it's working for you.
                        Adios,
                        Cactus Dan
                          On 12/10/2013 at 09:46, xxxxxxxx wrote:
                          i am happy, too, since this helped me solve the thing with my demo version of the plugin, too 🙂
                            On 14/10/2013 at 12:06, xxxxxxxx wrote:
                            It's quite easy as Niklas suggested.
                            In your main.cpp:
                            bool your_global_variable = false;
                            PluginStart()
                              your_global_variable = true;
                            In any other file (e.g. myPlugin.h) :
                            extern bool your_global_variable;
                            int any_function(int a, int b) //or anywhere else in this file
                              //do something with your_global_variable
                              return your_global_variable ? (a + b) : (a - b);
                            You don't need to include any file anywhere. You just need the declarations to make the scope see it.
                            extern int myTest;
                            enum
                            [quote]
                            1>  Main.cpp
                            1>  myPlugin.cpp
                            [/QUOTE]
