    popup like alert("...");
    3 Posts 0 Posters 699 Views
      On 11/10/2013 at 14:21, xxxxxxxx wrote:
      Cinema 4D Version:   r14
      Hi there,
      i am wondering if and how it is possible to add a simple dialog box to an object plugin. just a window with a message and an "ok"-button.
      any input highly appreciated 🙂
      thanks in advance,
      Ello
        On 11/10/2013 at 15:13, xxxxxxxx wrote:
        Hi ello,
        you can catch the press of a button on your object's description (parameters in the AM) by
        overriding NodeData::Message() and catching the MSG_DESCRIPTION_COMMAND message.
        > Bool MyObjectPlugin::Message(GeListNode* node, LONG type, void* p_data) {
        > if (type == MSG_DESCRIPTION_COMMAND) {
        > DescriptionCommand* data = reinterpret_cast<DescriptionCommand*>(p_data);
        > if (data && data->id == MYOBJECTPLUGIN_BUTTON) {
        > MessageDialog("My Button was pressed!");
        > return SUPER::Message(node, type, p_data);
        Messages are sent from the main thread. You can safely perform GUI operations.
        Best,
        -Niklas
          On 11/10/2013 at 15:29, xxxxxxxx wrote:
          thank you very much!
          • mikeudinM mikeudin referenced this topic on
