    make UserData in C++
    11 Posts 0 Posters 1.1k Views
      On 02/09/2013 at 21:14, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Platform:    Mac  ;
      Hi
      Is it possible to add User Data (as in the User Data tab of the Attributes window) to an object that is created in my code? I guess you use GetDynamicDescription to access existing User Data.
      Peter
        On 03/09/2013 at 01:02, xxxxxxxx wrote:
        Exactly. You can use DynamicDescription::Alloc(), passing the user-data's description as a
        BaseContainer, to append a new user-data parameter. The description ID of the new parameter
        will be returned.
          On 04/09/2013 at 13:34, xxxxxxxx wrote:
          Thanks NiklasR
          I am currently trying to find example code and wading through the docs to find how to actually do this.
          My understanding is a bit nebulous at this point.
          Peter
            On 04/09/2013 at 13:50, xxxxxxxx wrote:
            Bool AddShaderField(BaseObject* op) {
                String name = GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDEFAULTNAME);
                Bool success = RenameDialog(&name);
            // Break if the rename dialog was canceled.
                if (!success) {
            // Create a cusotm datatype container.
                BaseContainer container = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
                container.SetString(DESC_NAME, name);
                container.SetString(DESC_SHORT_NAME, name);
                container.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_TEXBOX);
            // Obtain the object's user-data description.
                DynamicDescription* desc = op->GetDynamicDescription();
                if (!desc) {
                    MessageDialog(GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDDERROR, __FILE__, LongToString(__LINE__)));
                    return FALSE;
            // Create a new UserData entry.
                desc->Alloc(container);
              On 04/09/2013 at 16:56, xxxxxxxx wrote:
              Thanks. That made it much clearer. The ways of the SDK are often very mysterious to me.
              Peter
                On 04/09/2013 at 21:16, xxxxxxxx wrote:
                And  promptly a new question pops up.
                How can I create groups? Or, actually I did create a group like this:
                                    bc = GetCustomDataTypeDefault(DTYPE_GROUP);
                                    bc.SetString(DESC_NAME, "General");
                                    bc.SetString(DESC_SHORT_NAME, "General");
                                    bc.SetBool(DESC_GUIOPEN, TRUE);
                                    bc.SetBool(DESC_TITLEBAR, TRUE);
                                    desc->Alloc(bc);
                But how to I move my other data into the group?
                Do you use DESC_PARENTGROUP, DESC_PARENTID?
                  On 05/09/2013 at 07:59, xxxxxxxx wrote:
                  Small example without any error checking stuff:
                  //This example creates a group UserData item
                  //Then it creates a Real type userData item as a child of the group
                    BaseDocument *doc = GetActiveDocument();
                    BaseObject *obj = doc->GetActiveObject();
                    DynamicDescription* dd = obj->GetDynamicDescription();
                    BaseContainer groupContainer;
                    dd->FillDefaultContainer(groupContainer, DTYPE_GROUP, "New Group");
                    DescID groupID = dd->Alloc(groupContainer);
                    dd->Set(groupID, groupContainer, obj);
                    BaseContainer realContainer;
                    dd->FillDefaultContainer(realContainer, DTYPE_REAL, "New Real");
                    GeData dataID;
                    dataID.SetCustomDataType(CUSTOMDATATYPE_DESCID, groupID);
                    realContainer.SetData(DESC_PARENTGROUP, dataID);
                    DescID realID = dd->Alloc(realContainer);
                    dd->Set(realID, realContainer, obj);
                    On 06/09/2013 at 13:56, xxxxxxxx wrote:
                    Great. That works although I am not sure I would have come up with it. In retrospect it looks logical.
                    Peter
                      On 09/09/2013 at 15:38, xxxxxxxx wrote:
                      And here we go again. I find DynamicDescription dramatically confusing because references to it are all over the place in the documentation. I understand groups now but I am stuck at how to implement a Popup menu. I suppose you use DTYPE_POPUP to make a container for the menu and use DESC_CYCLE to populate it?
                        On 10/09/2013 at 01:30, xxxxxxxx wrote:
                        With "Popup menu", do you mean a Cycle field? The elements in a Cycle field are described using a
                        BaseContainer. Take a look at the documentation of the Description class, all IDs are listed up there
                        with quite good description.
                        BaseContainer cycle;
                        cycle.SetString(0, "Cycle Value 0");
                        cycle.SetString(1, "Cycle Value 1");
                        itemdesc->SetContainer(DESC_CYCLE, cycle);
                        Best,
                        -Niklas
                          On 10/09/2013 at 08:19, xxxxxxxx wrote:
                          The popup button doesn't seem to work like the ComboButton Nik.
                          It's either broken. Or the the way we populate it with entries is different.
                          Example that adds a UD ComboButton to the active object:
                            if (!obj) return FALSE;
                            //Create a list of ComboButton values
                            BaseContainer names;
                            names.SetString(0,"Scott");
                            names.SetString(1,"Nicklas");
                            BaseContainer bc = NULL;
                            bc.SetString(DESC_NAME, "My Combo");
                            bc.SetString(DESC_SHORT_NAME, "My Combo");
                            bc.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_CYCLEBUTTON);  //<--- put CUSTOMGUI_POPUP here and it no longer works!!!
                            bc.SetContainer(DESC_CYCLE, names);
                            //Get the object's master UD container that holds all the UserData entries
                            DynamicDescription *dd = obj->GetDynamicDescription();
                            if(!dd) return FALSE;
                            //Create a new UserData entry using the container values above
                            dd->Alloc(bc);
                            SendCoreMessage(COREMSG_CINEMA, BaseContainer(COREMSG_CINEMA_FORCE_AM_UPDATE)); //Refresh the AM to see the changes in real time
                            EventAdd();
