    make UserData in C++
    11 Posts 0 Posters 947 Views
      On 03/09/2013 at 01:02, xxxxxxxx wrote:
      Exactly. You can use DynamicDescription::Alloc(), passing the user-data's description as a
      BaseContainer, to append a new user-data parameter. The description ID of the new parameter
      will be returned.
        On 04/09/2013 at 13:34, xxxxxxxx wrote:
        Thanks NiklasR
        I am currently trying to find example code and wading through the docs to find how to actually do this.
        My understanding is a bit nebulous at this point.
        Peter
          On 04/09/2013 at 13:50, xxxxxxxx wrote:
          Bool AddShaderField(BaseObject* op) {
              String name = GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDEFAULTNAME);
              Bool success = RenameDialog(&name);
          // Break if the rename dialog was canceled.
              if (!success) {
          // Create a cusotm datatype container.
              BaseContainer container = GetCustomDataTypeDefault(DTYPE_BASELISTLINK);
              container.SetString(DESC_NAME, name);
              container.SetString(DESC_SHORT_NAME, name);
              container.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_TEXBOX);
          // Obtain the object's user-data description.
              DynamicDescription* desc = op->GetDynamicDescription();
              if (!desc) {
                  MessageDialog(GeLoadString(IDS_SHADERCOLLECTION_ADDSHADERDDERROR, __FILE__, LongToString(__LINE__)));
                  return FALSE;
          // Create a new UserData entry.
              desc->Alloc(container);
            On 04/09/2013 at 16:56, xxxxxxxx wrote:
            Thanks. That made it much clearer. The ways of the SDK are often very mysterious to me.
            Peter
              On 04/09/2013 at 21:16, xxxxxxxx wrote:
              And  promptly a new question pops up.
              How can I create groups? Or, actually I did create a group like this:
                                  bc = GetCustomDataTypeDefault(DTYPE_GROUP);
                                  bc.SetString(DESC_NAME, "General");
                                  bc.SetString(DESC_SHORT_NAME, "General");
                                  bc.SetBool(DESC_GUIOPEN, TRUE);
                                  bc.SetBool(DESC_TITLEBAR, TRUE);
                                  desc->Alloc(bc);
              But how to I move my other data into the group?
              Do you use DESC_PARENTGROUP, DESC_PARENTID?
                On 05/09/2013 at 07:59, xxxxxxxx wrote:
                Small example without any error checking stuff:
                //This example creates a group UserData item
                //Then it creates a Real type userData item as a child of the group
                  BaseDocument *doc = GetActiveDocument();
                  BaseObject *obj = doc->GetActiveObject();
                  DynamicDescription* dd = obj->GetDynamicDescription();
                  BaseContainer groupContainer;
                  dd->FillDefaultContainer(groupContainer, DTYPE_GROUP, "New Group");
                  DescID groupID = dd->Alloc(groupContainer);
                  dd->Set(groupID, groupContainer, obj);
                  BaseContainer realContainer;
                  dd->FillDefaultContainer(realContainer, DTYPE_REAL, "New Real");
                  GeData dataID;
                  dataID.SetCustomDataType(CUSTOMDATATYPE_DESCID, groupID);
                  realContainer.SetData(DESC_PARENTGROUP, dataID);
                  DescID realID = dd->Alloc(realContainer);
                  dd->Set(realID, realContainer, obj);
                  On 06/09/2013 at 13:56, xxxxxxxx wrote:
                  Great. That works although I am not sure I would have come up with it. In retrospect it looks logical.
                  Peter
                    On 09/09/2013 at 15:38, xxxxxxxx wrote:
                    And here we go again. I find DynamicDescription dramatically confusing because references to it are all over the place in the documentation. I understand groups now but I am stuck at how to implement a Popup menu. I suppose you use DTYPE_POPUP to make a container for the menu and use DESC_CYCLE to populate it?
                      On 10/09/2013 at 01:30, xxxxxxxx wrote:
                      With "Popup menu", do you mean a Cycle field? The elements in a Cycle field are described using a
                      BaseContainer. Take a look at the documentation of the Description class, all IDs are listed up there
                      with quite good description.
                      BaseContainer cycle;
                      cycle.SetString(0, "Cycle Value 0");
                      cycle.SetString(1, "Cycle Value 1");
                      itemdesc->SetContainer(DESC_CYCLE, cycle);
                      Best,
                      -Niklas
                        On 10/09/2013 at 08:19, xxxxxxxx wrote:
                        The popup button doesn't seem to work like the ComboButton Nik.
                        It's either broken. Or the the way we populate it with entries is different.
                        Example that adds a UD ComboButton to the active object:
                          if (!obj) return FALSE;
                          //Create a list of ComboButton values
                          BaseContainer names;
                          names.SetString(0,"Scott");
                          names.SetString(1,"Nicklas");
                          BaseContainer bc = NULL;
                          bc.SetString(DESC_NAME, "My Combo");
                          bc.SetString(DESC_SHORT_NAME, "My Combo");
                          bc.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_CYCLEBUTTON);  //<--- put CUSTOMGUI_POPUP here and it no longer works!!!
                          bc.SetContainer(DESC_CYCLE, names);
                          //Get the object's master UD container that holds all the UserData entries
                          DynamicDescription *dd = obj->GetDynamicDescription();
                          if(!dd) return FALSE;
                          //Create a new UserData entry using the container values above
                          dd->Alloc(bc);
                          SendCoreMessage(COREMSG_CINEMA, BaseContainer(COREMSG_CINEMA_FORCE_AM_UPDATE)); //Refresh the AM to see the changes in real time
                          EventAdd();
