    Getting Description information
    16 Posts 0 Posters 2.2k Views
      On 16/07/2013 at 08:00, xxxxxxxx wrote:
      Hi niklas,
      this did not help
      LONG usedUnit = bc->GetLong(DESC_UNIT);
      because now I either get 0 or 1717856114
      from the lib_description.h
      	DESC_UNIT	= 12,	// LONG: one of the following values DESC_UNIT_xxx for DTYPE_REAL/DTYPE_VECTOR
      	DESC_UNIT_REAL			= 'frea',		//FORMAT_REAL,
      	DESC_UNIT_LONG			= 'flng',		//FORMAT_LONG,
      	DESC_UNIT_PERCENT		= 'fpct',		//FORMAT_PERCENT,
      	DESC_UNIT_DEGREE		= 'fdgr',		//FORMAT_DEGREE,
      	DESC_UNIT_METER			= 'fmet',		//FORMAT_METER,
      	DESC_UNIT_TIME			= 'ffrm',		//FORMAT_FRAMES,
      I still have no idea how to find out it the element has a UNIT DEGREE attribute.
        On 16/07/2013 at 09:25, xxxxxxxx wrote:
        Hi Ingvar,
        enumerations are always integers. 'fdgr' is a so-called multi-character constant.
        http://coliru.stacked-crooked.com/view?id=4ca282541e2f80a136b5b08bcb70dd9b-a618d2239b73732723b7a95695ce0794
        1717856114 == 'fdgr' == DESC_UNIT_DEGREE
          I don't have an answer for you, but I've posted this code before that you might find useful...
          static String VecToString(const Vector& vec)
            return String(RealToString(vec.x)+" "+RealToString(vec.y)+" "+RealToString(vec.z));
          static void DumpMatrix(Matrix xform)
            GePrint("===================");
            GePrint("v1  = " + VecToString(xform.v1));
            GePrint("v2  = " + VecToString(xform.v2));
            GePrint("v3  = " + VecToString(xform.v3));
            GePrint("off = " + VecToString(xform.off));
          void container_dump(BaseContainer *pBc, LONG tab=0)
            if(!pBc)    return;
            LONG id, j, i=0;
            String tabStr;
            for(j=0; j<tab; j++)
                tabStr += "____";
            while (TRUE)
                id = pBc->GetIndexId(i++);
                if (id==NOTOK) break;
                BaseContainer *pSubc = NULL;
                GeData data = pBc->GetData(id);
                switch(data.GetType())
                    case DA_NIL:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_NIL");                                                    break;
                    case DA_VOID:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_VOID");                                                    break;
                    case DA_LONG:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_LONG ("+LongToString(data.GetLong())+")");                break;
                    case DA_REAL:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_REAL ("+RealToString(data.GetReal())+")");                break;
                    case DA_TIME:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_TIME ("+RealToString(data.GetTime().GetNumerator())+" / "+RealToString(data.GetTime().GetDenominator())+")");    break;
                    case DA_VECTOR:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_VECTOR ("+VecToString(data.GetVector())+")");            break;
                    case DA_MATRIX:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_MATRIX...");    DumpMatrix(data.GetMatrix());            break;
                    case DA_LLONG:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_LLONG ("+LLongToString(data.GetLLong())+")");            break;
                    case DA_BYTEARRAY:        GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_BYTEARRAY");                                            break;
                    case DA_STRING:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_STRING (\""+data.GetString()+"\")");                    break;
                    case DA_FILENAME:        GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_FILENAME (\""+data.GetFilename().GetString()+"\")");    break;
                    case DA_CONTAINER:        GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_CONTAINER");    pSubc = data.GetContainer();    container_dump(pSubc, tab+1);    break;
                    case DA_ALIASLINK:        GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_ALIASLINK");                                            break;
                    case DA_MARKER:            GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_MARKER");                                                break;
                    case DA_MISSINGPLUG:    GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_MISSINGPLUG");                                            break;
                    case DA_CUSTOMDATATYPE:    GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - DA_CUSTOMDATATYPE");                                        break;
                    default:                GePrint(tabStr+LongToString(i)+"| id: "+LongToString(id)+" - unknown");                                                    break;
          ...try dumping out some containers to see if you can figure out what you're looking for.
          Cheers.
            On 16/07/2013 at 10:46, xxxxxxxx wrote:
            Hi Niklas,
            I have to say this: 😂 plus this: 😊
            I never thought that this huge number had any meaning, as long as the other constants are so low. So I had the answer there after all, I just overlooked it! I am a C++ beginner, indeed. I wonder why Maxon uses multi-character constants, what purpose they serve. Nevertheless, I got what I wished for and will experiment further.
            Thanks a lot!!
            And thanks to Giblet too, very useful code you posted!
              On 22/07/2013 at 06:01, xxxxxxxx wrote:
              Howdy,
              ... I wonder why Maxon uses multi-character constants, what purpose they serve...
              So you can do something like this:
              switch(bc->GetLong(DESC_UNIT)
              	case DESC_UNIT_REAL:
              		GePrint("Real");
              		break;
              	case DESC_UNIT_LONG:
              		GePrint("Long");
              		break;
              	case DESC_UNIT_PERCENT:
              		GePrint("Percent");
              		break;
              	case DESC_UNIT_DEGREE:
              		GePrint("Degree");
              		break;
              	case DESC_UNIT_METER:
              		GePrint("Meter");
              		break;
              	case DESC_UNIT_TIME:
              		GePrint("Time");
              		break;
              If any of the defined constant values are changed in the future, the above code would still work. 😉
              You really need not worry about what a defined constant's value is, because you can use the definition "DESC_UNIT_DEGREE" in your code (as in the above code). The use of the value of 'fdgr' may only be a convenience to the original programmer for debugging purposes or something.
              Adios,
              Cactus Dan
                On 22/07/2013 at 07:05, xxxxxxxx wrote:
                Hi Dan,
                thanks!
                I am not "worrying" about anything in particular, but I am, and have always been, very curious! I always want to open the lid, to watch inside. That slows me often down, with most of the things I do. Making things work, is not enough for me, I want to find out why and because  😉
                My plugins were mostly done, mostly working well, already in June. But I and diving into stuff all the time, do I see a yet another door, I just have to open it!
                  On 22/07/2013 at 11:01, xxxxxxxx wrote:
                  I think the question was more like "why multi character constants instead of any other integral numbers"?
                  Well, it's like choosing between octal, decimal and hexadecimal. 🙂
                    On 24/07/2013 at 06:54, xxxxxxxx wrote:
                    Howdy,
                    Well, your curiosity got my curiosity up, and I found this from a c++ forum:
                    Question:
                    I'm curious about this code:
                    cout << 'test'; // Note the single quotes.
                    gives me an output of 1952805748.
                    My question: Is the output an address in memory or something?
                    Answer:
                    No, it's not an address. It's the so-called multibyte character.
                    Typically, it's the ASCII values of the four characters combined.
                    't' == 0x74; 'e' == 0x65; 's' == 0x73; 't' == 0x74; So 0x74657374 is 1952805748.
                    According to Bjarne Stroustrup (the author of c++) in his book "The C++ Programming Language", the use of the ' operator declares a character literal and that character literals are mainly used to make programs more portable.
                    Adios,
                    Cactus Dan
                      On 25/07/2013 at 15:14, xxxxxxxx wrote:
                      Great Dan,
                      reminds me of the old days when I programmed in assembler. I used a decimal number to search for a four characters long string in a file.
                        On 25/07/2013 at 16:26, xxxxxxxx wrote:
                        Are they using mulichars in the ListView gizmo?
                        This is in the ge_prepass.h file:
                            LV_COLUMN_TEXT      = C4D_FOUR_BYTE(0,'t','x','t'),
                          LV_COLUMN_EDITTEXT  = C4D_FOUR_BYTE(0,'e','d','t'),
                          LV_COLUMN_BMP       = C4D_FOUR_BYTE(0,'b','m','p'),
                          LV_COLUMN_CHECKBOX  = C4D_FOUR_BYTE(0,'c','h','k'),
                          LV_COLUMN_BUTTON    = C4D_FOUR_BYTE(0,'b','t','n'),
                          LV_COLUMN_USERDRAW  = C4D_FOUR_BYTE(0,'u','s','r'),
                          LV_COLUMN_COLORVIEW = C4D_FOUR_BYTE(0,'c','l','v'),
                        Does this mean that each char inside of the parenthesis () is a hexidecimal representaion of an ID#?
                        The "C4D_FOUR_BYTE" code is very odd looking code to me too.
                          Does this mean that each char inside of the parenthesis () is a hexadecimal representation of an ID#?
                          Hi Scott,
                          C4D_FOUR_BYTE is used to define multi-character constants from 3 characters only because writing
                          LV_COLUMN_TEXT = 'txt'
                          won't give a valid and unique constant.
                          You can see that it's used in only one another place to define QUICKTAB_BAR:
                          #define QUICKTAB_BAR    C4D_FOUR_BYTE(0,'b','a','r')
                            On 26/07/2013 at 09:56, xxxxxxxx wrote:
                            Thanks for the answer Yannick.
                            Is it safe to use the C4D_FOUR_BYTE() function in our plugins if we wanted. Or is it something that we should not use?
                              Yes you can use the macro C4D_FOUR_BYTE in 3rd party plugins.
                                On 26/07/2013 at 10:41, xxxxxxxx wrote:
                                OK.
                                Thanks.
