    Implementing a simple list
    23 Posts 0 Posters 15.9k Views
      On 28/05/2013 at 06:04, xxxxxxxx wrote:
      Littledevil, that would only work for combo boxes or popup buttons 😞
      Yes, that is what I need, Scott. But, how do I define it in the resource file?
      Thank you both for the reply.
        As you did refer to a 'list' and not a 'listview' I thought a combobox would also do it. The link
        Scott posted seems to be a Qt example, so has nothing to do with c4d. As he already pointed
        out the c4d gadget SimpleListView is not wrapped for python, so you can define it in the res
        file but you won't be able to use it / read its content.
        Alternatives to a ComboBox would be the QuickTabGui which is wrapped for python. It does
        resemble in some qualities to a ListView and would allow dynamic content. The most flexible
        route would be a UserArea of course. It should  not be too complicated to implement a ListView,
        I also think Nikklas has done this once and provided his results as Open Source.
        Happy rendering,
          On 28/05/2013 at 07:33, xxxxxxxx wrote:
          Thank you for the reply, littledevil.
          I have found no references to any QuickTabGui in the python SDK 😞
          I never thought it would be so complicated to create a list (listview) in python, using resources.
          So, what should I search for, to find that implementation by Nikklas?
          Rui Batista
            It probably won't do you any good to create it if there's nothing in the python SDK to use it.
            But I'll post how to create it anyway so you at least know how to create it.
            ###### This is the code for the ListView gizmo in the .res file ######
              GROUP LIST_GROUP
              LISTVIEW MY_LISTBOX  {ALIGN_TOP; ALIGN_LEFT; SIZE 150, 50;}
            ###### This is the code that goes in the plugin's .pyp file ######
            CUSTOMGUI_LISTVIEW = 1018398    #The text Id for the ListView gizmo is not set up yet. So do it manually
            MY_LISTBOX = 10001
            #The CreateLayout method
              def CreateLayout(self) :
                  res = self.LoadDialogResource(ResBasedMenu)                        #Loads GUI stuff from the .res file
                  self.listbox = self.FindCustomGui(MY_LISTBOX, CUSTOMGUI_LISTVIEW)  #Creates the ListView gizmo
                  return res
            -Scott
              On 28/05/2013 at 08:05, xxxxxxxx wrote:
              Thank you.
              So, we can create it but we cant add anything to it, right?
                On 28/05/2013 at 08:20, xxxxxxxx wrote:
                And, shouldn't it be AddCustomGui instead of FindCustomGui?
                  On 28/05/2013 at 08:27, xxxxxxxx wrote:
                  So, it all indicates that I need to create a SCROLLGROUP with a USERAREA inside it an implement a LISTVIEW manually.
                  Am I correct into assuming this?
                  Rui Batista
                    On 28/05/2013 at 08:39, xxxxxxxx wrote:
                    1. The QuickTabGui is documented under c4d.gui.BaseCustomGui.QuickTabGui
                    2. You have to call FindCustomGui to get hold of the CustomGui class providing methods
                        to interact with the gadget. It will return the helper class for the CustomGui at that id.
                        For a ListView it will be None, as there is no such class in python.
                    3. I am not sure if you did understand the difference between the definition of a CustomGui
                        in a resource file and its wrapping class. Defining a ListView is no problem, it will show
                        up in your gui, but you won't be able to read or write data to it, as there is no wrapping
                        CustomGui class in python providing methods like SetItem() or GetItem() to change the
                        the items in your ListView.
                    4. Not sure where to search. I just know that he once wrote it. Just start a google search
                        for Nikklas Rosenstein ListView.
                      AddCustomGui returns an error when used with CustomGui. Don't ask me why.
                      If you want to see a working example of this. Use CUSTOMGUI_LINKBOX instead of CUSTOMGUI_LISTVIEW.
                      The custom .res based LinkBox gizmo seems to be supported....Or it works by accident.
                      And using FindCustomGui is the only way it works for me.
                      That's one possible option. But it sounds like a fairly ugly proposal to me.
                      Another option is switching to C++ so you stop running into things that are not supported in Python. 😉
                        On 28/05/2013 at 09:17, xxxxxxxx wrote:
                        I don't intend to switch to C++ soon as it is much more complex than python and, also, requires different compilation for Mac an Windows.
                        I may have to create my own implementation of a LIST_VIEW 😞
                          On 28/05/2013 at 09:26, xxxxxxxx wrote:
                          ^Yeah. I know. I was just kidding you about that. Tongue
                            On 28/05/2013 at 11:40, xxxxxxxx wrote:
                            Hi Rui,
                            this is a very very old implementation of a simple ListView of mine. I've used it in Description Editor
                            plugin. Works relatively fine, very basic. Please don't judge my coding style, this snippet is about 2
                            years old. 🙂
                            Maybe you can use it.
                            class ListView(GeUserArea) :
                                MOUSEWHEEL_MODE         = 1027215       # Registered at Plugincafe.com
                                SELECTEDROW_UP          = 1027216       # Registered at Plugincafe.com
                                SELECTEDROW_DOWN        = 1027217       # Registered at Plugincafe.com
                                SELECTEDROW_CHANGED     = 1027218       # Registered at Plugincafe.com
                                SELECTEDROW_PREVIOUS    = 1027219       # Registered at Plugincafe.com
                                colors             = {
                                    "background":       Vector(.2),
                                    "lighterRow":       Vector(.31),
                                    "darkerRow":        Vector(.29),
                                    "markedRow":        Vector(.38),
                                    "text":             Vector(.64705),
                                    "markedText":       Vector(1., .66, .024)
                                def __init__(
                                        self,
                                        parentDialog    = None,                 # The parent-dialog, can be None if the 'Command'-Method should not be invoked on an Input-Event
                                        initialData     = (()),                 # Data to display, must be 2 dimensional
                                        rowHeight       = 16,                   # Height of a row in the ListView
                                        columnWidths    = (100,),               # Widths of the columns in the ListView
                                        minSize         = (300, 100),           # Minimum size of the area. If second is None, it will be calculated.
                                    self.parentDialog       = parentDialog
                                    self.rowHeight          = rowHeight
                                    self.columnWidths       = tuple(columnWidths)
                                    self.data               = list(initialData)
                                    self.selectedRow        = -1
                                    self.minSize            = tuple(minSize)
                                # Overriden
                                def DrawMsg(self, x1, y1, x2, y2, msg) :
                                    """ Called when redrawing the UserArea """
                                    self.SetClippingRegion(x1, y1, x2, y2)
                                    self.DrawSetPen(self.colors["background"])  # Set Background Color
                                    self.DrawRectangle(x1, y1, x2, y2)          # Fill Background
                                    Draw lighter rows
                                    self.DrawSetPen(self.colors["lighterRow"])
                                    for i in xrange(0,len(self.data), 2) :           # Iterate the  specified rows
                                        Rectangle       = {
                                            'x1':               0,
                                            'x2':               x2,
                                            'y1':               self.rowHeight * i,
                                            'y2':               self.rowHeight * (i + 1)
                                        # If the selected Row is about to be drawn
                                        if i == self.selectedRow and self.colors["markedRow"]:
                                            self.DrawSetPen(self.colors["markedRow"])
                                            self.DrawRectangle(**Rectangle)
                                    Draw darker rows
                                    self.DrawSetPen(self.colors["darkerRow"])
                                    for i in xrange(1,len(self.data), 2) :           # Iterate the  specified rows
                                        Rectangle       = {
                                            'x1':               0,
                                            'x2':               x2,
                                    Draw data.
                                    self.DrawSetTextCol(self.colors["text"], c4d.COLOR_TRANS)
                                    for i in xrange(len(self.data)) :                # Iterate the  specified rows
                                        previousItemPosX    = x1 + 5
                                        for j in xrange(len(self.data[i])) :         # Iterate the datas columns
                                            if j >= len(self.columnWidths) :
                                                width       = self.columnWidths[-1]
                                                width       = self.columnWidths[j]
                                            textToDraw          = str(self.data[i][j])
                                            if i == self.selectedRow:
                                                self.DrawSetTextCol(self.colors["markedText"], c4d.COLOR_TRANS)
                                                self.DrawText(  txt     = textToDraw,
        x1      = x1 + previousItemPosX ,
        y1      = y1 + i *  self.rowHeight + self.rowHeight - 14,
                                            previousItemPosX   += width
                                def InputEvent(self, msg) :
                                    inputChannel            = msg[c4d.BFM_INPUT_CHANNEL]
                                    # Left or Right Mousebutton
                                    if inputChannel in (c4d.BFM_INPUT_MOUSELEFT, c4d.BFM_INPUT_MOUSERIGHT, c4d.BFM_INPUT_MOUSEMIDDLE) :
                                        positionInDialog    = self.Global2Local()
                                        mousePosX           = msg[c4d.BFM_INPUT_X] + positionInDialog["x"]
                                        mousePosY           = msg[c4d.BFM_INPUT_Y] + positionInDialog["y"]
                                        clickedRow          = int(mousePosY/self.rowHeight)
                                        msg[self.SELECTEDROW_PREVIOUS]  = self.selectedRow
                                        if clickedRow > len(self.data) - 1:
                                            self.selectedRow    = clickedRow
                                        self.Redraw()
                                    # MouseWheel switching of elements
                                    elif inputChannel == c4d.BFM_INPUT_MOUSEWHEEL:
                                        inputValue      = msg[c4d.BFM_INPUT_VALUE]
                                        selectedRow     = self.selectedRow
                                        # Go up (in visual), means to go back in the list
                                        if inputValue > 0:
                                            # Do not if data-begin is reached
                                            if selectedRow > 0:
                                                if self.parentDialog:
                                                    bc         = c4d.BaseContainer()
                                                    bc[self.MOUSEWHEEL_MODE]        = self.SELECTEDROW_UP
                                                    bc[self.SELECTEDROW_CHANGED]    = -1    # Selected row + SELECTEDROW_CHANGED = newSelectedRow
                                                    self.parentDialog.Command(self.GetId(), bc)
                                                self.selectedRow   -= 1
                                        # Go down (in visual), means to go further in the list
                                        elif inputValue < 0:
                                            # Do not if data-end is reached
                                            if selectedRow <= len(self.data) -2:
                                                    bc[self.MOUSEWHEEL_MODE]        = self.SELECTEDROW_DOWN
                                                    bc[self.SELECTEDROW_CHANGED]    = 1     # Selected row + SELECTEDROW_CHANGED = newSelectedRow
                                                self.selectedRow   += 1
                                        self.Redraw()
                                    # if parentDialog is defined, send Command-Message
                                        self.parentDialog.Command(self.GetId(), msg)
                                def GetMinSize(self) :
                                    """ Returns the minimum size of the area. """
                                    return tuple(self.minSize)
                                # Getters
                                def GetMinHeight(self) :
                                    return self.minSize[1]
                                def GetSelectedRow(self) :
                                    return self.selectedRow
                                def GetRowHeight(self) :
                                    return self.rowHeight
                                def GetColumnWidths(self) :
                                    return self.columnWidths
                                def GetParentDialog(self) :
                                    return self.parentDialog
                                # Setters
                                def SetColors(self, **kwargs) :
                                    for k, v in kwargs.iteritems() :
                                        if k in self.colors.keys() :
                                            self.colors[k]  = v
                                def SetData(self, data) :
                                    self.data   = data
                                def SetRowHeight(self, height) :
                                    self.rowHeight      = height
                                    self.minSize[1]     = self.rowHeight * len(self.data)
                                def SetColumnWidths(self, columnWidths) :
                                    self.columnWidths   = columnWidths
                                def SetSelectedRow(self, index) :
                                    if index >= len(self.data) :
                                        return False
                                        self.selectedRow    = index
                                def SetParentDialog(self, parent) :
                                # Adders
                                def AppendData(self, data) :
                                    self.data.append(data)
                                def InsertData_AtIndex(self, data, index) :
                                    if index > len( self.data ) :
                                        return False
                                        self.data.insert(index, data)
                                # Removers
                                def RemoveData(self, subData) :
                                    if subData in self.data:
                                        del self.data[ self.data.index(subData) ]
                                        return False
                                def RemoveData_ByIndex(self, index) :
                                        return False
                                        del self.data[index]
                                # Update
                                pass
                            -Nik
                              On 29/05/2013 at 09:06, xxxxxxxx wrote:
                              Thank you very muck, Nikklas.
                              I will check it out, to see if I can use it.
                              This creates color bars, right?
                              I want to create a list of text items. Should not be too complicated to change this to my needs 🙂
                              Rui Batista
                                On 29/05/2013 at 09:25, xxxxxxxx wrote:
                                Yep, it looks like this:
                                The data it uses to display must be a two dimensional list with each row having the same number of columns! A selected item can be moved up and down by scrolling the mouse-wheel. But scrolling the view is not implemented in this user area.
                                  On 29/05/2013 at 15:38, xxxxxxxx wrote:
                                  It is working fine, Nikklas 🙂
                                  However, if I add more than a certain number of items, they just disappear down the bottom.
                                  Is there any way to implement a vertical scroll bar?
                                    On 30/05/2013 at 01:57, xxxxxxxx wrote:
                                    Sure. I think the easiest way would be to implement GetMinSize() and call LayoutChange() on the
                                    dialog when the elements in the list have changed and put the user area into a scroll-group.
                                    -Nik
                                      On 30/05/2013 at 02:14, xxxxxxxx wrote:
                                      You code already has a GetMinSize() and the user area it already inside a SCROLLGROUP, like this:
                                      SCROLLGROUP DC_SCRIPT_CONTAINER
                                           SCALE_V;
                                           SCALE_H;
                                           SCROLL_V;
                                           SCROLL_BORDER;
                                      USERAREA DC_SCRIPT_LIST { SCALE_V; SCALE_H; }
                                      In my main code, I already filled the data with many, many items, just to test if a vertical scroll bar would appear. But it doesn't. Even if I change the size of my plugin window 😞
                                        On 30/05/2013 at 02:42, xxxxxxxx wrote:
                                        But the current GetMinSize() implementation does not calculate the height based on the number
                                        of elements. 🙂
                                        http://pastebin.com/Jz2yPqK8
                                        But I see it is a bit buggy, I don't know why actually. While the background is drawn correctly, the
                                        text is not.. Not sure where this comes from, maybe you can figure it out.
                                        -Nik
                                          On 30/05/2013 at 03:29, xxxxxxxx wrote:
                                          Actually, it is working but the userarea is not refreshing correctly when I scroll down and back up again.
                                          I should be able to intercept a message that tells me that the scrollgroup changed and refresh the userarea when that happens.
                                          But I don't know how 😞
                                          Rui Batista
                                            On 30/05/2013 at 03:46, xxxxxxxx wrote:
                                            I'm trying to detect that the scrollgroup is being dragged with msg[c4d.BFM_ACTION_INDRAG]
                                            but when I use this code:
                                            def Message(self, msg, result) :
                                                dragging=msg[c4d.BFM_ACTION_INDRAG]
                                                return GeDialog.Message(self, msg, result)
                                            I get a crash while starting up Cinema4D.
