    Implementing a simple list
    23 Posts 0 Posters 14.2k Views
      On 27/05/2013 at 15:38, xxxxxxxx wrote:
      I need to implement a simple list of items. I have to be able to fill it with items through code and also be able to update it (re-populate it with new items, if needed).
      It should have a vertical scroll bar when the number of items is too long to be able to be displayed in the window.
      And the window layout is defined by a resource.
      If I had created my layout with code, I may have used a SCROLLGROUP.
      But, since it is defined by a resource, what is the best way to define a list box and how can I access it through code?
      Thank you very much in advance for any reply.
      Rui Batista
        On 27/05/2013 at 16:08, xxxxxxxx wrote:
        Are you talking about dialgos or descriptions ? For dialogs there are tons of options. The
        most obvious way would be GeDialog.AddChildren. It does not matter if the dialog is
        loaded from a file or not. Here an example for a file based dialog with a dynamically filled
        combobox.
        def fillComboBox(self, select = srCon.ID_PRESETIDOFFSET) :
                self.FreeChildren(srCon.IDC_PRESET_COMBOBOX)
                # start layout change
                self.LayoutFlushGroup(srCon.IDC_PRESET_COMBOBOX)
                lastIndex = 0
                for index, value in self.Presets:
                    self.AddChild(srCon.IDC_PRESET_COMBOBOX , index, value.GetString(srCon.IDC_PRESETNAME))
                    if (index == srCon.ID_PRESETIDOFFSET) :
                        self.AddChild(srCon.IDC_PRESET_COMBOBOX , srCon.IDC_SEPERATOR, "")
                    lastIndex = index
                self.LayoutChanged(srCon.IDC_PRESET_COMBOBOX)
                # end layout change
                if(select == -1) :
                    self.SetLong(srCon.IDC_PRESET_COMBOBOX, lastIndex)
                    self.SetLong(srCon.IDC_PRESET_COMBOBOX, select)
        For descriptions the only solution we could use in python would be InExclude list. Create
        some dummy nulls and place it in the InEx. Messy but it works.
        Happy rendering,
          On 27/05/2013 at 20:48, xxxxxxxx wrote:
          If this is what you want:http://gambasdoc.org/help/comp/gb.qt/listview?view
          Then what you're looking for is probably the CUSTOMGUI_LISTVIEW gizmo.
          This is not documented in the Python docs. Which might mean it's not officially supported.
          I've been able to create the gizmo so it shows up in the dialog. But I do not know how to fill and delete the entries in it.
          There's a class in C++ that handles that stuff using functions like SetLayout(), SetItem, etc. which I don't see listed in the Python docs.
            On 28/05/2013 at 06:04, xxxxxxxx wrote:
            Littledevil, that would only work for combo boxes or popup buttons 😞
            Yes, that is what I need, Scott. But, how do I define it in the resource file?
            Thank you both for the reply.
              As you did refer to a 'list' and not a 'listview' I thought a combobox would also do it. The link
              Scott posted seems to be a Qt example, so has nothing to do with c4d. As he already pointed
              out the c4d gadget SimpleListView is not wrapped for python, so you can define it in the res
              file but you won't be able to use it / read its content.
              Alternatives to a ComboBox would be the QuickTabGui which is wrapped for python. It does
              resemble in some qualities to a ListView and would allow dynamic content. The most flexible
              route would be a UserArea of course. It should  not be too complicated to implement a ListView,
              I also think Nikklas has done this once and provided his results as Open Source.
              Happy rendering,
                On 28/05/2013 at 07:33, xxxxxxxx wrote:
                Thank you for the reply, littledevil.
                I have found no references to any QuickTabGui in the python SDK 😞
                I never thought it would be so complicated to create a list (listview) in python, using resources.
                So, what should I search for, to find that implementation by Nikklas?
                Rui Batista
                  It probably won't do you any good to create it if there's nothing in the python SDK to use it.
                  But I'll post how to create it anyway so you at least know how to create it.
                  ###### This is the code for the ListView gizmo in the .res file ######
                    GROUP LIST_GROUP
                    LISTVIEW MY_LISTBOX  {ALIGN_TOP; ALIGN_LEFT; SIZE 150, 50;}
                  ###### This is the code that goes in the plugin's .pyp file ######
                  CUSTOMGUI_LISTVIEW = 1018398    #The text Id for the ListView gizmo is not set up yet. So do it manually
                  MY_LISTBOX = 10001
                  #The CreateLayout method
                    def CreateLayout(self) :
                        res = self.LoadDialogResource(ResBasedMenu)                        #Loads GUI stuff from the .res file
                        self.listbox = self.FindCustomGui(MY_LISTBOX, CUSTOMGUI_LISTVIEW)  #Creates the ListView gizmo
                        return res
                  -Scott
                    On 28/05/2013 at 08:05, xxxxxxxx wrote:
                    Thank you.
                    So, we can create it but we cant add anything to it, right?
                      On 28/05/2013 at 08:20, xxxxxxxx wrote:
                      And, shouldn't it be AddCustomGui instead of FindCustomGui?
                        On 28/05/2013 at 08:27, xxxxxxxx wrote:
                        So, it all indicates that I need to create a SCROLLGROUP with a USERAREA inside it an implement a LISTVIEW manually.
                        Am I correct into assuming this?
                        Rui Batista
                          On 28/05/2013 at 08:39, xxxxxxxx wrote:
                          1. The QuickTabGui is documented under c4d.gui.BaseCustomGui.QuickTabGui
                          2. You have to call FindCustomGui to get hold of the CustomGui class providing methods
                              to interact with the gadget. It will return the helper class for the CustomGui at that id.
                              For a ListView it will be None, as there is no such class in python.
                          3. I am not sure if you did understand the difference between the definition of a CustomGui
                              in a resource file and its wrapping class. Defining a ListView is no problem, it will show
                              up in your gui, but you won't be able to read or write data to it, as there is no wrapping
                              CustomGui class in python providing methods like SetItem() or GetItem() to change the
                              the items in your ListView.
                          4. Not sure where to search. I just know that he once wrote it. Just start a google search
                              for Nikklas Rosenstein ListView.
                            AddCustomGui returns an error when used with CustomGui. Don't ask me why.
                            If you want to see a working example of this. Use CUSTOMGUI_LINKBOX instead of CUSTOMGUI_LISTVIEW.
                            The custom .res based LinkBox gizmo seems to be supported....Or it works by accident.
                            And using FindCustomGui is the only way it works for me.
                            That's one possible option. But it sounds like a fairly ugly proposal to me.
                            Another option is switching to C++ so you stop running into things that are not supported in Python. 😉
                              On 28/05/2013 at 09:17, xxxxxxxx wrote:
                              I don't intend to switch to C++ soon as it is much more complex than python and, also, requires different compilation for Mac an Windows.
                              I may have to create my own implementation of a LIST_VIEW 😞
                                On 28/05/2013 at 09:26, xxxxxxxx wrote:
                                ^Yeah. I know. I was just kidding you about that. Tongue
                                  On 28/05/2013 at 11:40, xxxxxxxx wrote:
                                  Hi Rui,
                                  this is a very very old implementation of a simple ListView of mine. I've used it in Description Editor
                                  plugin. Works relatively fine, very basic. Please don't judge my coding style, this snippet is about 2
                                  years old. 🙂
                                  Maybe you can use it.
                                  class ListView(GeUserArea) :
                                      MOUSEWHEEL_MODE         = 1027215       # Registered at Plugincafe.com
                                      SELECTEDROW_UP          = 1027216       # Registered at Plugincafe.com
                                      SELECTEDROW_DOWN        = 1027217       # Registered at Plugincafe.com
                                      SELECTEDROW_CHANGED     = 1027218       # Registered at Plugincafe.com
                                      SELECTEDROW_PREVIOUS    = 1027219       # Registered at Plugincafe.com
                                      colors             = {
                                          "background":       Vector(.2),
                                          "lighterRow":       Vector(.31),
                                          "darkerRow":        Vector(.29),
                                          "markedRow":        Vector(.38),
                                          "text":             Vector(.64705),
                                          "markedText":       Vector(1., .66, .024)
                                      def __init__(
                                              self,
                                              parentDialog    = None,                 # The parent-dialog, can be None if the 'Command'-Method should not be invoked on an Input-Event
                                              initialData     = (()),                 # Data to display, must be 2 dimensional
                                              rowHeight       = 16,                   # Height of a row in the ListView
                                              columnWidths    = (100,),               # Widths of the columns in the ListView
                                              minSize         = (300, 100),           # Minimum size of the area. If second is None, it will be calculated.
                                          self.parentDialog       = parentDialog
                                          self.rowHeight          = rowHeight
                                          self.columnWidths       = tuple(columnWidths)
                                          self.data               = list(initialData)
                                          self.selectedRow        = -1
                                          self.minSize            = tuple(minSize)
                                      # Overriden
                                      def DrawMsg(self, x1, y1, x2, y2, msg) :
                                          """ Called when redrawing the UserArea """
                                          self.SetClippingRegion(x1, y1, x2, y2)
                                          self.DrawSetPen(self.colors["background"])  # Set Background Color
                                          self.DrawRectangle(x1, y1, x2, y2)          # Fill Background
                                          Draw lighter rows
                                          self.DrawSetPen(self.colors["lighterRow"])
                                          for i in xrange(0,len(self.data), 2) :           # Iterate the  specified rows
                                              Rectangle       = {
                                                  'x1':               0,
                                                  'x2':               x2,
                                                  'y1':               self.rowHeight * i,
                                                  'y2':               self.rowHeight * (i + 1)
                                              # If the selected Row is about to be drawn
                                              if i == self.selectedRow and self.colors["markedRow"]:
                                                  self.DrawSetPen(self.colors["markedRow"])
                                                  self.DrawRectangle(**Rectangle)
                                          Draw darker rows
                                          self.DrawSetPen(self.colors["darkerRow"])
                                          for i in xrange(1,len(self.data), 2) :           # Iterate the  specified rows
                                              Rectangle       = {
                                                  'x1':               0,
                                                  'x2':               x2,
                                          Draw data.
                                          self.DrawSetTextCol(self.colors["text"], c4d.COLOR_TRANS)
                                          for i in xrange(len(self.data)) :                # Iterate the  specified rows
                                              previousItemPosX    = x1 + 5
                                              for j in xrange(len(self.data[i])) :         # Iterate the datas columns
                                                  if j >= len(self.columnWidths) :
                                                      width       = self.columnWidths[-1]
                                                      width       = self.columnWidths[j]
                                                  textToDraw          = str(self.data[i][j])
                                                  if i == self.selectedRow:
                                                      self.DrawSetTextCol(self.colors["markedText"], c4d.COLOR_TRANS)
                                                      self.DrawText(  txt     = textToDraw,
        x1      = x1 + previousItemPosX ,
        y1      = y1 + i *  self.rowHeight + self.rowHeight - 14,
                                                  previousItemPosX   += width
                                      def InputEvent(self, msg) :
                                          inputChannel            = msg[c4d.BFM_INPUT_CHANNEL]
                                          # Left or Right Mousebutton
                                          if inputChannel in (c4d.BFM_INPUT_MOUSELEFT, c4d.BFM_INPUT_MOUSERIGHT, c4d.BFM_INPUT_MOUSEMIDDLE) :
                                              positionInDialog    = self.Global2Local()
                                              mousePosX           = msg[c4d.BFM_INPUT_X] + positionInDialog["x"]
                                              mousePosY           = msg[c4d.BFM_INPUT_Y] + positionInDialog["y"]
                                              clickedRow          = int(mousePosY/self.rowHeight)
                                              msg[self.SELECTEDROW_PREVIOUS]  = self.selectedRow
                                              if clickedRow > len(self.data) - 1:
                                                  self.selectedRow    = clickedRow
                                              self.Redraw()
                                          # MouseWheel switching of elements
                                          elif inputChannel == c4d.BFM_INPUT_MOUSEWHEEL:
                                              inputValue      = msg[c4d.BFM_INPUT_VALUE]
                                              selectedRow     = self.selectedRow
                                              # Go up (in visual), means to go back in the list
                                              if inputValue > 0:
                                                  # Do not if data-begin is reached
                                                  if selectedRow > 0:
                                                      if self.parentDialog:
                                                          bc         = c4d.BaseContainer()
                                                          bc[self.MOUSEWHEEL_MODE]        = self.SELECTEDROW_UP
                                                          bc[self.SELECTEDROW_CHANGED]    = -1    # Selected row + SELECTEDROW_CHANGED = newSelectedRow
                                                          self.parentDialog.Command(self.GetId(), bc)
                                                      self.selectedRow   -= 1
                                              # Go down (in visual), means to go further in the list
                                              elif inputValue < 0:
                                                  # Do not if data-end is reached
                                                  if selectedRow <= len(self.data) -2:
                                                          bc[self.MOUSEWHEEL_MODE]        = self.SELECTEDROW_DOWN
                                                          bc[self.SELECTEDROW_CHANGED]    = 1     # Selected row + SELECTEDROW_CHANGED = newSelectedRow
                                                      self.selectedRow   += 1
                                              self.Redraw()
                                          # if parentDialog is defined, send Command-Message
                                              self.parentDialog.Command(self.GetId(), msg)
                                      def GetMinSize(self) :
                                          """ Returns the minimum size of the area. """
                                          return tuple(self.minSize)
                                      # Getters
                                      def GetMinHeight(self) :
                                          return self.minSize[1]
                                      def GetSelectedRow(self) :
                                          return self.selectedRow
                                      def GetRowHeight(self) :
                                          return self.rowHeight
                                      def GetColumnWidths(self) :
                                          return self.columnWidths
                                      def GetParentDialog(self) :
                                          return self.parentDialog
                                      # Setters
                                      def SetColors(self, **kwargs) :
                                          for k, v in kwargs.iteritems() :
                                              if k in self.colors.keys() :
                                                  self.colors[k]  = v
                                      def SetData(self, data) :
                                          self.data   = data
                                      def SetRowHeight(self, height) :
                                          self.rowHeight      = height
                                          self.minSize[1]     = self.rowHeight * len(self.data)
                                      def SetColumnWidths(self, columnWidths) :
                                          self.columnWidths   = columnWidths
                                      def SetSelectedRow(self, index) :
                                          if index >= len(self.data) :
                                              return False
                                              self.selectedRow    = index
                                      def SetParentDialog(self, parent) :
                                      # Adders
                                      def AppendData(self, data) :
                                          self.data.append(data)
                                      def InsertData_AtIndex(self, data, index) :
                                          if index > len( self.data ) :
                                              return False
                                              self.data.insert(index, data)
                                      # Removers
                                      def RemoveData(self, subData) :
                                          if subData in self.data:
                                              del self.data[ self.data.index(subData) ]
                                              return False
                                      def RemoveData_ByIndex(self, index) :
                                              return False
                                              del self.data[index]
                                      # Update
                                      pass
                                  -Nik
                                    On 29/05/2013 at 09:06, xxxxxxxx wrote:
                                    Thank you very muck, Nikklas.
                                    I will check it out, to see if I can use it.
                                    This creates color bars, right?
                                    I want to create a list of text items. Should not be too complicated to change this to my needs 🙂
                                    Rui Batista
                                      On 29/05/2013 at 09:25, xxxxxxxx wrote:
                                      Yep, it looks like this:
                                      The data it uses to display must be a two dimensional list with each row having the same number of columns! A selected item can be moved up and down by scrolling the mouse-wheel. But scrolling the view is not implemented in this user area.
                                        On 29/05/2013 at 15:38, xxxxxxxx wrote:
                                        It is working fine, Nikklas 🙂
                                        However, if I add more than a certain number of items, they just disappear down the bottom.
                                        Is there any way to implement a vertical scroll bar?
                                          On 30/05/2013 at 01:57, xxxxxxxx wrote:
                                          Sure. I think the easiest way would be to implement GetMinSize() and call LayoutChange() on the
                                          dialog when the elements in the list have changed and put the user area into a scroll-group.
                                          -Nik
                                            On 30/05/2013 at 02:14, xxxxxxxx wrote:
                                            You code already has a GetMinSize() and the user area it already inside a SCROLLGROUP, like this:
                                            SCROLLGROUP DC_SCRIPT_CONTAINER
                                                 SCALE_V;
                                                 SCALE_H;
                                                 SCROLL_V;
                                                 SCROLL_BORDER;
                                            USERAREA DC_SCRIPT_LIST { SCALE_V; SCALE_H; }
                                            In my main code, I already filled the data with many, many items, just to test if a vertical scroll bar would appear. But it doesn't. Even if I change the size of my plugin window 😞
