    tangent of spline point
    17 Posts 0 Posters 2.9k Views
      On 02/05/2013 at 18:52, xxxxxxxx wrote:
      I'm having a hard time understanding exactly what you want too.
      Here's an example of creating a spline. And setting all of the tangents to a specific Y value.
      If you only want one/or certain tangents to be set instead of all of them. Then use a conditional statement with an array index value inside of the loop. Instead of using "i" for setting all of them:
      //This is an example of creating a spline and setting it's points and tangent handles
        SplineObject *sp = SplineObject::Alloc(3, SPLINETYPE_BEZIER); //Create a bezier spline with 3 points
        if(!sp) return NULL;
        doc->InsertObject(sp, NULL, NULL, 0);  //Add it to the OM
        Vector *gp = sp->GetPointW();          //Assign the array of spline points to a variable
        gp[0] = Vector(10,0,-100);             //Place the first spline point here
        gp[1] = Vector(0,0,0);                 //Place the second spline point here
        gp[2] = Vector(-10,0,100);             //Place the third spline point here
        Tangent *tangents = sp->GetTangentW(); //Assign the array of tangents to a variable
        //Loop through all of the tangents
        for (LONG i = 0; i < sp->GetTangentCount(); i++)
            tangents[i].vl.y = 200;           //Set each spline point's left tangent to this position
            tangents[i].vr.y = -200;          //Set each spline point's right tangent to this position
        sp->Message(MSG_UPDATE);              //Update the spline's changes
        On 05/05/2013 at 10:55, xxxxxxxx wrote:
        thank you. i didnt try GetTangentW, because in the sdk it says that it returns the first element. now i get the tangents. however, i had the hope to use the tangents to create a correctly offset position for the points. but, in liniear splines there are no tangents. how can i calculate the direction for the offset so that positive values go into one direction, and negative values go to the opposite direction? (see image)
        i did it like this:
        Vector winkel = VectorToHPB(p2-p1);
        Matrix richtung = HPBToMatrix(winkel, ROTATIONORDER_DEFAULT);
        however, that resulted in point offsets to unwanted directions, like if you changed the green and red for only some of the points in the image. thats why i thought using the tangents could help..
        maybe there is another solution?
        Ello
          On 05/05/2013 at 11:57, xxxxxxxx wrote:
          If I wanted to move the points of a spline.
          This is the way I'd do it:
          #include "lib_splinehelp.h"
            BaseDocument *doc = GetActiveDocument();
            BaseObject *spline = doc->SearchObject("Spline");
            PointObject *sp = ToPoint(spline);
            AutoAlloc<SplineHelp> sh;
            if(!sh) return FALSE;
            sh->InitSpline(sp);
            if(!sh->Exists()) return FALSE;
            Vector *spPnts = sp->GetPointW();           //Get all the points in the spline
            Real offsetX = 100.0;
            Real offsetY = 100.0;                       //Some offset values that can be bound to GUI gizmos
            Real offsetZ = 100.0;
            LONG pntCnt = sh->GetPointCount();
            for(LONG i=0; i<pntCnt; i++)
                spPnts[i].x += offsetX;
                spPnts[i].y += offsetY;                 //Move all the points in the spline by this offset amount
                spPnts[i].z += offsetZ;
            sp->Message(MSG_UPDATE);                    //Update the changes made to the spline
            On 06/05/2013 at 00:15, xxxxxxxx wrote:
            yes, i know how to move points, but how do i get the direction when there is no tangent and when  i need to take care that the points need to move all relatively to the right or left side of the spline.. thats the main problem i have here
              On 06/05/2013 at 03:07, xxxxxxxx wrote:
              You can get the bisecting vector of a point by calculating the arithmetic middle of the adjacent points.
                On 06/05/2013 at 04:26, xxxxxxxx wrote:
                i guess you mean something like
                tRot = Vector((getAngle(points[i-1],points[i]).x+getAngle(points[i+1],points[i]).x)/2,0,0);
                Matrix richtung = HPBToMatrix(tRot, ROTATIONORDER_DEFAULT);
                tPos += Vector(0,0,_ipOffset)*richtung;
                this still makes some objects move to the one direction end others to the opposite direction...
                  On 06/05/2013 at 14:13, xxxxxxxx wrote:
                  double post, sorry.
                    On 06/05/2013 at 14:15, xxxxxxxx wrote:
                    Not exactly. But I expressed myself not 100% correct. You can get a point that lies on the bisecting
                    line this way:
                    p1 = points[i]
                    p2 = (points[i - 1] + points[i + 1]) * (1 / 2.0)   // I think division is not supported by the vector class
                    bv = (p2 - p1).GetNormalized()
                    Then again you can cross it with one of the adjacent lines and cross it
                    again and you have the tangent:
                    n = bv.Cross(points[i] - points[i - 1])
                    tangent = bv.Cross(n)
                    Best,
                    Niklas
                      On 06/05/2013 at 21:32, xxxxxxxx wrote:
                      thank you niklas. i'll try if this helps me solve my problem and report back...
                        On 07/05/2013 at 01:44, xxxxxxxx wrote:
                        hm, this still produces the wrong direction for some points. i have no idea how to get this working...
                          On 07/05/2013 at 03:18, xxxxxxxx wrote:
                          Hi ello,
                          here, some example code quickly plucked together.
                          class Tag(c4d.plugins.TagData) :
                              SIZE_SPHERE = c4d.Vector(10)
                              COLOR_SPHERE = c4d.Vector(1, 0.66, 0.02)
                              LENGTH_TANGENT = 20
                              COLOR_TANGENT = c4d.Vector(0.1, 0.95, 0.5)
                              def Draw(self, tag, op, bd, bh) :
                                  if not isinstance(op, c4d.SplineObject) :
                                  bd.SetMatrix_Matrix(op, op.GetMg())
                                  segments = [op.GetSegment(i) for i in xrange(op.GetSegmentCount())]
                                  if not segments:
                                      segments = [{'cnt': op.GetPointCount(), 'closed': op.IsClosed()}]
                                  pi = 0
                                  for segment in segments:
                                      cnt = segment['cnt']
                                      closed = segment['closed']
                                      start = pi
                                      end = pi + cnt
                                      i_start = start
                                      i_end = end
                                      if not closed:
                                          i_start += 1
                                          i_end -= 1
                                          bd.DrawSphere(op.GetPoint(pi), self.SIZE_SPHERE, self.COLOR_SPHERE, 0)
                                          bd.DrawSphere(op.GetPoint(pi + cnt - 1), self.SIZE_SPHERE, self.COLOR_SPHERE, 0)
                                      bd.SetPen(self.COLOR_TANGENT)
                                      if start < end:
                                          for i in xrange(i_start, i_end, 1) :
                                              left = i - 1
                                              right = i + 1
                                              if left < start:
                                                  left = end - 1
                                              if right >= end:
                                                  right = start
                                              print left, i, right
                                              pleft = op.GetPoint(left)
                                              pright = op.GetPoint(right)
                                              point = op.GetPoint(i)
                                              mid = (pleft + pright) * 0.5
                                              bv = point - mid
                                              n = bv.Cross(point - pleft)
                                              tangent = n.Cross(bv).GetNormalized() * self.LENGTH_TANGENT
                                              pmin = point - tangent
                                              pmax = point + tangent
                                              bd.DrawLine(pmin, pmax, 0)
                                      pi += cnt
                                  print "-------------------"
                              c4d.plugins.RegisterTagPlugin(100003, "Spline Tangents", c4d.TAG_VISIBLE, Tag, "Tsplinetangents", None)
                          Best,
                          -Niklas
                          http://www.file-upload.net/download-7562607/spline-tangents.zip.html
                            On 07/05/2013 at 03:20, xxxxxxxx wrote:
                            Uhm, I just see: The result in the image is correct. What else did you expect?
                            The only thing left would be to rotate them about 90° to get the actual tangent (see my example code).
                              On 07/05/2013 at 04:05, xxxxxxxx wrote:
                              thank you very much, but when i rotate the direction the problem still remains. it just doesnt move left/right but back and forward.. still some point to the opposite..
