    Move polygon along normal
    6 Posts 0 Posters 655 Views
      On 28/03/2013 at 11:26, xxxxxxxx wrote:
      I want to move a polygon along its normal (normal move).
      So I calculate the cross vector of the polygon using two sides as vector.
      However, when I compare my result with the result of the Xpresso' polygon node - polygon normal' it is different. But the point normal from the Point node is the same as the cross vector I calculate.
      Strange?
      Is the point normal different then the polygon normal?
      Also when I start moving the polygon, my calculation seems to go wrong.
      I expect that my calculation of the cross vector is wrong.
      I get all the polygon points, normalize them and use them to calculate the vectors.
      This might be wrong, because I do not include the starting point?
      Note: There is only one polygon in my polygon object.
      I do not want to use the cinema 4d 'move normal' command.
      from c4d import utils
      import random
      # move polygon along its normal
        polyobject = doc.SearchObject("MyObject")
        polys = polyobject.GetAllPolygons()
        p1 = polyobject.GetPoint(polys[0].a)
        p2 = polyobject.GetPoint(polys[0].b)
        p3 = polyobject.GetPoint(polys[0].c)
        p4 = polyobject.GetPoint(polys[0].d)
        print p1,p2,p3,p4
        np1 = p1.GetNormalized()
        np2 = p2.GetNormalized()
        np3 = p3.GetNormalized()
        np4 = p4.GetNormalized()
        p1p2 = (np2-np1)
        p1p3 = (np3-np1)
        pcross = p1p2.Cross(p1p3)
        pcross = pcross.GetNormalized()
        print "cross: ", pcross
        On 28/03/2013 at 11:37, xxxxxxxx wrote:
        cpoly = polygonObject.GetPolygon(id)
        nrm = ((cpoly.a - cpoly.b) % (cpoly.a - cpoly.d)).GetNormalized()
          On 28/03/2013 at 11:44, xxxxxxxx wrote:
          For a cube, I get Vector(0, 0, -1) which is correct. Btw, a bit shorter:
              p = op.GetPolygon(0)
              points = op.GetAllPoints()
              p1, p2, p4 = points[p.a], points[p.b], points[p.d]
              print (p2 - p1).Cross(p4 - p1).GetNormalized()
          Note that you need to take the forth point into account instead of the third, which might
          be the cause why you get "wrong values".
            On 28/03/2013 at 11:47, xxxxxxxx wrote:
            lol, i forgot to access the vectors, cpolys just contains the ids , doh, i am a it dizzy, just
            follow nikklas 🙂
              On 28/03/2013 at 11:49, xxxxxxxx wrote:
              I just checked the polygon-node in XPresso and it gives the same result.
              @Ferdinand: You also computed the inversed normal. 🙂 It's (B - A) cross (D - A) to compute
              the correct normal.
              Ehrm wait, I thought that it would be.. but it isn't? Just checked.. Gonna think about that 😂
                On 28/03/2013 at 13:49, xxxxxxxx wrote:
                Brilliant again, thanks.
                Indeed using p4, I do not get 'wrong values'.
                Here the code to get the polygon moving along the normal.
                Just add it to all the points of the polygon and do an update.
                Note: the calculated cross is now the same as the Xpresso one and Xpresso point normal is the same as the  polygon normal.
                import random
                  frame = doc.GetTime().GetFrame(doc.GetFps())
                  if (frame >= 5) :
                      p = polyobject.GetPolygon(0)        #get polygon
                      points = polyobject.GetAllPoints()  #get all points
                      p1, p2, p3, p4 = points[p.a], points[p.b], points[p.c], points[p.d]
                      pcross = (p2 - p1).Cross(p4 - p1).GetNormalized()
                      print pcross
                      p1 = p1 + pcross
                      p2 = p2 + pcross
                      p3 = p3 + pcross
                      p4 = p4 + pcross
                      #print p1,p2,p3,p4
                      p1 = polyobject.SetPoint(p.a,p1)
                      p2 = polyobject.SetPoint(p.b,p2)
                      p3 = polyobject.SetPoint(p.c,p3)
                      p4 = polyobject.SetPoint(p.d,p4)
                      polyobject.Message (c4d.MSG_UPDATE)
