    Returning another class' function value
    61 Posts 0 Posters 61.4k Views
      On 18/02/2013 at 13:14, xxxxxxxx wrote:
      YourPluginClass stands for the class derived from NodeData (from which TagData, ObjectData, etc are dervied). In your example that would be StorageTag.
           tag = BaseTag::Alloc(TAG_PLUGIN_ID);
          StorageTag* MyTag = NULL;
          if(tag != NULL && tag->GetType() == TAG_PLUGIN_ID)
              MyTag = static_cast<StorageTag*>(tag->GetNodeData());
        On 18/02/2013 at 13:33, xxxxxxxx wrote:
        Ok thanks.
        Fixed that. But still running into undeclared errors.
        MyDialog::MyDialog()
          GeDialog();
          StorageTag* MyTag = NULL;          //<------------ undeclared identifier :-(
          On 18/02/2013 at 13:42, xxxxxxxx wrote:
          You've missed the forward-declaration, then.
            On 18/02/2013 at 13:47, xxxxxxxx wrote:
            Oh, you need to declare StorageTag first and MyDialog.
            So:
            #define DIALOG_PLUGIN_ID 1000001   //The GeDialog plugin's ID
            #define TAG_PLUGIN_ID     1000002   //The Tag plugin's ID
            //-------- The tag plugin -------------------------//
            class StorageTag : public TagData
            //-------- The GeDialog plugin --------------------//
            class MyDialog : public GeDialog
            The other option would be to move each classes declaration/definition into it's own h/cpp files and have them the MyDialog file include/forwards declare the StorageTag (don't forget "#pragma once"/include guards).
              On 18/02/2013 at 13:50, xxxxxxxx wrote:
              Forwards declaration will not work here unless he splits the class declaration and function definitions into h and cpp files (as the actual function definition is using the forwards declared class).
                On 18/02/2013 at 13:54, xxxxxxxx wrote:
                Moving the tag's class above the GeDialog class defeats the whole purpose of what I'm trying to do.🙂
                Sharing downwards is fairly simple.
                But sharing upwards is proving to be very, very difficult.
                  Moving the tag's class above the GeDialog class defeats the whole purpose of what I'm trying to do.🙂Sharing downwards is fairly simple.But sharing upwards is proving to be very, very difficult.-ScottA
                  edit: actually you *could* move MyDialog::MyDialog() below the declaration of StorageTag. Declare both classes first, then provide the implementations. But that would then sum up about all your available options.
                  No it's not, what you are trying is simply impossible with c++ 😉
                  Solution: One class, one .h and one .cpp file:
                  MyDialog.h:
                  #pragma once
                  #include <c4d.h>
                          MyDialog();
                          BaseTag* tag;
                          void doStuff()
                              LONG type = tag->GetType();
                              GePrint(LongToString(type));
                          //GeDialog Overrides
                          Bool CreateLayout();
                          Bool InitValues();
                          Bool Command(LONG id, const BaseContainer& data);
                          Bool CoreMessage(LONG id, const BaseContainer& data);
                  MyDialog.cpp:
                  #include "MyDialog.h"
                  #include "StorageTag.h" // Storage tag used, need to include
                  MyDialog::MyDialog() //The GeDialog's constructor
                      GeDialog();
                  //Register function here.
                  ... etc.
                  StorageTag.h:
                  #pragma once
                  #include <c4d.h>
                          static NodeData* Alloc();
                          LONG imagecount;        //<---I want to share this class member so I can use it inside the MyDialog class
                          //Overrides
                          StorageTag();
                          Bool Init(GeListNode* node);
                          void Free(GeListNode* node);
                          Bool Read(GeListNode* node, HyperFile* file, LONG level);
                          Bool Write(GeListNode* node, HyperFile* file);
                          Bool Message(GeListNode* node, LONG id, void* msgData);
                  StorageTag.cpp:
                  NodeData* StorageTag::Alloc()
                      return gNew StorageTag;
                  ...etc.
                    On 18/02/2013 at 14:31, xxxxxxxx wrote:
                    WickedP.
                    Do you still have questions about your code?
                    I've completely stolen your thread and I want to give it back to you.
                      On 18/02/2013 at 15:24, xxxxxxxx wrote:
                      lol
                        WickedP.
                        Ha 😃 That's no troubles at all Scott! I'm enjoying the conversation. I know next to nothing about C++ so it's all a learning experience from my perspective - it'll all help somewhere along the line I'm sure!
                        I'm actually away on holiday at the moment so it can be a bit difficult at times to log on. I'm currently in Cambodia's south, heading to the north in half an hour or so. So I'm trying to do what I can in the spare moments I have. I'm quite excited about my plugin, hence why I bombared the forums a little at times. Just excited to try and push further with it and get it out there! Would love to show you guys what I have at some stage. It's not a world stopper but... I think it'll have some use. Certainly for myself it will.
                        RE: sharing a functions return downwards - I'm still having troubles getting anything other than an empty return. I had wondered about using multiple .h files - perhaps that's a better way for me at this stage? But haven't had a chance to try that yet. Will keep playing around.
                        Cheers all,
                        WP.
                          On 19/02/2013 at 10:10, xxxxxxxx wrote:
                          Going back to the examples you posted earlier.
                          I noticed that you are in the habit of using the type specifier on your class member variables when assigning values to them.
                          That will re-declare the variable in a different place. And make it a local variable that isn't globally available to your other methods like a class variable.
                          That's probably why you keep getting no return values.
                          Once you've declared a class member variable: String myString;
                          Don't use the "String" type specifier on it when you go and assign a value to it later on.
                          Just use the variable's name: myString = "HelloWorld".
                            On 20/02/2013 at 03:38, xxxxxxxx wrote:
                            Hi Scott,
                            I've just had a peek at my code and this particular string is declared without the type. It GePrints fine from the function if I run it from within the class, but when the bottom class runs it the prints (even when within the function itself) are empty.Not sure what else I can do.
                            WP.
                              Post compilable code that does not work for you, and some one here may be will find the solution 🙂
                                Wrong, it's simply class-construction.
                                String str = "outter";
                                /* new scope */ {
                                    str = String("inner");
                                GePrint(str);
                                /* new scope */ {
                                    String str = String("inner");
                                GePrint(str);
                                -Niklas
                                  On 20/02/2013 at 05:32, xxxxxxxx wrote:
                                  Firs example is a bit confusion.
                                  Why not use the same way to assign?
                                  But this is a more code style question.
                                  String str = String("outter");
                                  /* new scope */ {
                                  GePrint(str);
                                  Second is error-prone and should not be used!
                                    On 20/02/2013 at 05:45, xxxxxxxx wrote:
                                    _ >>> Why not use the same way to assign?_
                                    > I wanted to demonstrate that there is no difference because of the implementation of the String
                                    > class. 🙂 I don't know if the String class explicitly implements the assignment operator for char*, but
                                    > even if it does not, the constructor will be called and then assigned to the instance because the
                                    > constructor accepts a char*.
                                    > Agreed, it's very bad style.
                                    -N
                                      -Niklas
                                      No. I'm not wrong.
                                      When you create a class member variable. You do not then re-assign a new type specifier to it when you go to use it.
                                      @WickedP.
                                      I've also found problems with getting zero returns. Even when doing top down sharing.
                                      Apparently even top down class sharing in these plugins is not as simple as I thought.
                                      I've figured out how to solve the zero return problem by making one class a friend of the other.
                                      But so far I'm only getting the class member's initial constructor value.
                                      If I change the value of the top class member. I don't get the new changed in the bottom class.
                                      I need to work on it some more.
                                      @Remo:
                                      Using the Alloc() method proved to be a dead end for me because it only returns BaseList2D elements. It does not inclue any of the custom class members in the class.
                                      Using "friend class" seems to be the best method I've tried so far. The one that's produced the best results for me. But I'm still trying to flesh it all out and get updated values to work.
                                        On 20/02/2013 at 10:22, xxxxxxxx wrote:
                                        > >> No. I'm not wrong.
                                        _
                                        _
                                        Probably a misunderstanding. What I figured from your post, is that WP should use
                                        > String myString;
                                        > myString = "Hello";
                                        Instead of
                                        > String myString;
                                        > myString = String("Hello");
                                        .. because that would redeclare the variable. Is that what you said?
                                          On 20/02/2013 at 11:38, xxxxxxxx wrote:
                                          Yeah.
                                          I noticed he seemed to be in the habit of re-declaring a class variable when he shouldn't be.
                                            On 20/02/2013 at 12:15, xxxxxxxx wrote:
                                            But
                                            does not redeclare the variable. It creates a String object using the String constructor and assigns
                                            it to the local variable myString. If it would redeclare the variable, this would print 5, but it prints 10:
                                            > int main() {
                                            > int a = 5;
                                            > a = int(10);
                                            > std::cout << a;
                                            http://codepad.org/G8RsKyhD
                                            PS: More extended example: http://codepad.org/rGUgwY0j
                                            -Niklas
