    SplineData.MakeLinearSplineLinear()
    12 Posts 0 Posters 966 Views
      On 28/01/2013 at 04:30, xxxxxxxx wrote:
      Hi guys.
      I am using MakeLinearSplineLinear() in PYTHON, but this function is only implemented since R13. What function should I look in R12?
      What I need to make, is in INIT stage I need to set 2 points on spline. Ho should this be done in R12?
      Thank you.
        On 28/01/2013 at 04:43, xxxxxxxx wrote:
        Hi Tomas,
        you can use the SplineData.SetKnot() method.
          On 28/01/2013 at 04:47, xxxxxxxx wrote:
          Isn't SplineData.SetKnot() implemented only since R13?
          http://chicagoc4d.com/C4DPythonSDK/modules/c4d/CustomDataType/SplineData/index.html#SplineData.SetKnot
            Hi Tomas,
            Yes, you should instead call SplineData.InsertKnots() and set the tension with SplineData.SetRound().
              You're right, my fault. 😊
                On 28/01/2013 at 05:33, xxxxxxxx wrote:
                Thanks guys:), InsertKnot() seems to be working.
                But maybe I am missing something else?
                I am getting four point on the spline now 😞
                self.sizeSpline = c4d.SplineData()
                            self.sizeSpline.SetRound(0)
                            self.sizeSpline.InsertKnot(0, 1)
                            self.sizeSpline.InsertKnot(1, 0)
                And it looks nothing as expected:)
                  On 28/01/2013 at 05:37, xxxxxxxx wrote:
                  Hi Tomas,
                  I'm sure you wanted to thank Yannick, he told you about the InsertKnot() method. 😉
                  _> >> I am getting four point on the spline now 😞 _
                  You probably need to remove the points that are there by default. Use the DeleteAllKnots()
                  method before inserting your knots.
                    On 28/01/2013 at 05:47, xxxxxxxx wrote:
                    yeap, sorry about that Yannick:)
                    WOW - I removed points and now it works. Wo-Hoooo. Thank you everybody.
                    In case someone will find this topic useful, here's a code
                    spline = c4d.SplineData()
                    spline.DeleteKnot(0)     #Delete Knot 0
                    spline.DeleteKnot(0)     #Delete Knot 1
                    spline.InsertKnot(0, 1) #Set the first knot's position
                    spline.InsertKnot(1, 0) #Set the second knot's position
                    print "Point Count: ", spline.GetKnotCount()
                      On 28/01/2013 at 05:53, xxxxxxxx wrote:
                      Hi Tomas,
                      Instead of using DeleteKnot() two times, you can just use DeleteAllKnots () to flush all knots
                      from the SplineData (as I suggested above). 😉
                        On 28/01/2013 at 06:12, xxxxxxxx wrote:
                        Strage, but I get error "AttributeError: 'c4d.SplineData' object has no attribute 'DeleteAllKnots'"
                        if I use this:
                        spline.DeleteAllKnots()
                          On 28/01/2013 at 06:21, xxxxxxxx wrote:
                          Hi Tomas,
                          I just tested it in R12 and I get the same error. The R12 documentation must be wrong then.
                          Alternatively, you can use this function:
                          def flush_splinedata(spl) :
                              count = spl.GetKnotCount()
                              for i in xrange(count) :
                                  spl.DeleteKnot(0)
                          spl = c4d.SplineData()
                            On 28/01/2013 at 06:23, xxxxxxxx wrote:
                            Niklas, you'r THE MAN!!!
                            Thank you.
