    communication with C4D(recognize user interaction)
    2 Posts 0 Posters 260 Views
      On 13/12/2012 at 03:22, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Language(s) :     C++  ;   PYTHON  ;
      Hi all
      I do not know english well.
      Simply put, since Object data has been changed,
      How can I recognize quickly that BaseObject data whether changed or not
      (Matrix and Point's data)
      It is possible to quick check data whether changed or not?
      additional infomation.
      > I'm in the process of making some server & client.
      > Sever is getting data and serve data to all connected Client, like a chat server.
      > There are two kind of Client exist. admin and user.
      > server and user's Client is done while admin Client is in process.
      > If Admin Client has only one Object that sent by Admin Client to server
      > it is easy, just send all data(Matrix and Point structure).
      > but, If it has many Obejcts and Obejct has many points,
      > assume that initial Setting is done, Admin client move any Obejct's point or position.
      > then in order to send data to server,
      > Admin Client spend many time in getting all Obejcts data and
      > making binary that to send (Matrix, Points)
      > So to avoid sending unchaneged Obejct's data,
      > Have to pass unchaneged Obejcts while Admin Client send Obejct's data
        On 13/12/2012 at 04:41, xxxxxxxx wrote:
        The NodeData Message() method lets you respond to many things, including matrix, data, and attribute changes. ObjectData is a derived class of NodeData.  Since these messages are received as things change, you may need to keep track of which objects have changed since your last send to server.
