    rendersettings copy, activate, search, delete
    13 Posts 0 Posters 1.1k Views
      On 12/10/2012 at 02:21, xxxxxxxx wrote:
      Hi Folks,
      a while ago I tried to update my preview render script.
      to avoid the possible but unwanted effect of changed values if render is aborted. i would like to make the changes in a dublicated version of the original rendersettings.
      as I am (unfortunately) quite a newbe. and completely on my own to learn python and the c4d sdk i didnt even manage to copy a set of renderdata ;.(
      there are 3 things that I would like to do.
      - copy a active renderdata and rename it
      - search for renderdata by name and activate it
      - delete a activated renderdata
      I would be super glad if someone could help me out.
      thanks a lot
      Jops
        On 16/10/2012 at 03:08, xxxxxxxx wrote:
        ok maybe to many questions at once 🙂
        so lets start with copying existing renderdata
        this code doesnt work (unfortunately)
        from c4d import gui
            rd = doc.GetActiveRenderData()
            doc.InsertRenderDataLast(rd)
            c4d.EventAdd
        hints are highly welcome
        thanks
        Jops
          On 16/10/2012 at 03:52, xxxxxxxx wrote:
          To copy a render data you have to call:
          clone = rd.GetClone()
          You can then insert the cloned render data. You cannot insert twice the same render data in a document.
          To search the render datas you get the first render data with doc.GetFirstRenderData() and loop through them like objects in the document using GetNext(), GetDown() etc. Simply call rd.GetName() to get the name of a render data.
          And to select a render data you have to set its active bit:
          rd.SetBit(c4d.BIT_ACTIVERENDERDATA)
            On 16/10/2012 at 04:00, xxxxxxxx wrote:
            great Yannick, thanks a lot!!!!!!
              On 16/10/2012 at 05:07, xxxxxxxx wrote:
              ok so here some definitions:
              but I still strugle with deleting renderdata 😞
              def RDCopyToTemp() :
                  RDclone = rd.GetClone()
                  #print RDclone
                  RDclone.SetName("temp")
                  doc.InsertRenderDataLast(RDclone)
                  c4d.EventAdd
              def GetNextObject(op) :
                  if op==None: return None
                  if op.GetDown() : return op.GetDown()
                  while not op.GetNext() and op.GetUp() :
                      op = op.GetUp()
                  return op.GetNext()
              def RDFindAndActivate(name) : # needs GetNextObject
                  myRD = doc.GetFirstRenderData()
                  if myRD==None: return
                  while myRD:
                      if myRD.GetName() == name:
                          myRD.SetBit(c4d.BIT_ACTIVERENDERDATA)
                          c4d.EventAdd
                      myRD = GetNextObject(myRD)
                On 16/10/2012 at 05:54, xxxxxxxx wrote:
                To delete a render data you can call rd.Remove(). This method is defined in GeListNode (one of the parents class of RenderData).
                  On 16/10/2012 at 06:12, xxxxxxxx wrote:
                  thanks a lot... again 🙂
                  I know that starters can be nerve wrecking... sorry 😞
                  all the best
                  Jops
                    On 12/11/2012 at 06:09, xxxxxxxx wrote:
                    I#m sitting once again on this project... and unfortunately again got stuck 😞
                    I managed to copy the renderdata (see above) and I managed to activate it.
                    there are two ways it needs to be activated:
                    - the name should be orange to indicate that i can change the values in this settings
                    - and the square left of the name should be white to indicate that these are the rendersettings that get used.
                    the square can just be active with one rendersettings set at a time
                    but several names can be activated(orange) simutaniously.
                    my problem:
                    i managed to copy the renderdata and to activate the name and the square.
                    unfortunately the name of the "old renderdata" is also still active(orange) so the old settings get changed (first in list) instead of the new once.
                    I tryed:
                    old_rd.DelBit(c4d.BIT_ACTIVERENDERDATA)
                    old_rd.DelBit(c4d.BIT_ACTIVE)
                    but it didn#t work 😞
                    thanks for help
                    Jops
                      On 12/11/2012 at 07:35, xxxxxxxx wrote:
                      afaik using BaseDocument.SetActiveRenderData() automatically deactivates amy other renderdata.
                      Best,
                      Niklas
                        On 15/11/2012 at 06:36, xxxxxxxx wrote:
                        Hi Niklas,
                        well yes and no the activation dot, square or what ever you call it, that indicated the renderdata that get used is exclusiv. so there can only be one renderdata checked at a time.
                        but you can select mor then one renderdata to change values (indicated by the orange rendersettingsname in the list.
                        here is a bit of code that shows the problem:
                        old code (ugly)... I will change the naming... of the definitions and variables 🙂
                        from c4d import gui
                        def RDCopy(name) :
                            #print RDclone
                            RDclone.SetName(name)
                            c4d.EventAdd
                                op = op.GetUp()
                            return op.GetNext()
                            while myRD:
                                    doc.SetActiveRenderData(myRD)
                                    c4d.EventAdd
                            RDCopy("test")
                            RDFindAndActivate("test")
                        best regards
                        Jops
                          On 15/11/2012 at 08:42, xxxxxxxx wrote:
                          I see where's the problem. Even if we set the new active render data, the old active render data is still selected (its name is in orange color).
                          Here's how I changed your RDFindAndActivate() function:
                              while myRD:
                                  if myRD.GetName()==name:
                                      myRD.SetAllBits(2) # Reverse engineered with GetAllBits(), 2 is BIT_ACTIVE but we deactivate it so use the literal value
                          Also just a note, c4d.EventAdd() wasn't called because you just forgot the parenthesis to actually call the method.
                            On 17/11/2012 at 03:19, xxxxxxxx wrote:
                            Hi Yannick,
                            thanks that works great.
                            one (hopefully) last questiion
                            if I use the RDFindAndDelete funktion with renderdata that has a child renderdata
                                def GetNextRObject(obj) :
                                    if obj==None: return None
                                    if obj.GetDown() : return obj.GetDown()
                                    while not obj.GetNext() and obj.GetUp() :
                                        obj = obj.GetUp()
                                    return obj.GetNext()
                                def RDFindAndDelete(name) :
                                    while myRD:
                                           myRD.Remove()
                                        myRD = GetNextRObject(myRD)
                            I gett a error message: Reference error: the object 'c4d.documents.RenderData' is not alive.
                            but the script still works as intended (at least I think so 🙂
                            best regards
                            Jops
                              This is because you deleted a render data that has a child render data. If you remove a parent render data, the children still references it but it's not alive anymore.
                              Before deleting a render data you have to make sure it has no children, removing or moving them.
