    DESC_HIDE and DESC_EDITABLE
    9 Posts 0 Posters 1.1k Views
      On 17/07/2012 at 23:24, xxxxxxxx wrote:
      Hi everybody,
      I'm asking me which elements from lib_description.h are implemented in python at the moment.
      In this forum there's a lot stuff dealing with hide/disable datafields, and it's a little confusing me.
      After looking for a method to disable some fields of my tag-plugin I found an example that shows how to hide single userdata-fields. And it works great.
      from c4d import documents
        obj = doc.SearchObject("Null")
        #v1 = obj[c4d.ID_USERDATA,1]
        #v2 = obj[c4d.ID_USERDATA,2]
        allUserdatas = obj.GetUserDataContainer()
        for descId, container in allUserdatas:
            id = descId[1].id
            if id == 2:
                container[15] = False
                obj.SetUserDataContainer(descId, container)
      The id 15 = DESC_HIDE and it works as expected. But when I try to use DESC_EDITABLE (to grey the field out/disable it) by using the id 26 nothing happens.
      I guess not all id's are implemented yet?
      And does anybody know a method how to access not only the userdata?
      I've tried the same with GetDataInstance() but as expected it doesn't work.
        obj = doc.SearchObject("Scheibe")
        allData = obj.GetDataInstance()
        for descId, container in allData:
            id = descId[1].id   #doesn't work, cause int is unsubscriptable
            if descId == 1161:
                container[15] = True    #doesn't work, cause float does not support item assignment
      Does anybody has an idea?
      Sven
        On 18/07/2012 at 01:52, xxxxxxxx wrote:
        Hi Sven,
        It's currently only possible to access the description of an object's user data.
        DESC_EDITABLE is used to disable "Edit Entry" in the popupmenu (DESC_REMOVEABLE for "Remove Entry"). This is only useful with object parameters.
        EDIT: Are you trying to edit the description of your own TagData plugin?
          On 18/07/2012 at 03:36, xxxxxxxx wrote:
          Hi Yannik,
          that's right. It's like the 'alignToSpline'-Tag where the PRIM_AXIS is only a accessible when tangential is set to true.
          So it's even not possible by using GetDEnabling?
            On 18/07/2012 at 05:48, xxxxxxxx wrote:
            Yes it's possible overriding GetDEnabling(). You return True when the requested id enabling is PRIM_AXIS.
              On 18/07/2012 at 05:49, xxxxxxxx wrote:
              You can grey-out elements with GetDEnabling(). That's IMHO the better version for "not-so-complex-guis". It's less distracting than elements that suddenly disappear.
                On 18/07/2012 at 05:55, xxxxxxxx wrote:
                Hi Niklas,
                you're right. For the user it is very confusing when single elements suddenly appear/disappear.
                Then I'll try this "GetDEnabling()-Thing". 😉
                Seems a little bit weird after all I've read about it in this forum.
                Thank you Niklas.
                  On 18/07/2012 at 06:23, xxxxxxxx wrote:
                  All great.
                  Works like it done never anything else. 😉
                  Thank you both.
                  Now I've only to deal with the 'argument 5'-error thrown form the super-call.
                  It's really an interesting error - when it would not be so disgusting. 😉
                  return super(AlignOnMultiSpline, self).GetDEnabling(self, node, id, t_data, flags, itemdesc)
                  throws "TypeError: function takes at most 5 arguments (6 given)".
                  return super(AlignOnMultiSpline, self).GetDEnabling(node, id, t_data, flags, itemdesc)
                  throws "TypeError: argument 5".
                  Nice. 😉
                    On 18/07/2012 at 10:02, xxxxxxxx wrote:
                    The latter call is correct. But it seems to be a bug in the SDK. See here.
                    -Nik
                      On 18/07/2012 at 22:34, xxxxxxxx wrote:
                      Ok, I can see it.
                      Thx for your great help. You saved my day.
                      Sven
                      Edit: Fxxx, I've forgot the
                      op.InsertUnder(op)
                      statement. 😉
