    Object scaling
    13 Posts 0 Posters 1.4k Views
      On 02/05/2012 at 14:45, xxxxxxxx wrote:
      1. how can i scale my object using the "WORLD" coordinate system  in python ?
        i tested many many possibilities, but no success
      here an example of what i'm trying to do,
      #transform a 45° rotated cube into lozenge by making 200% scale on the X-axis
      obj = doc.GetActiveObject()
      obj_Mat = obj.GetMg()         #my cube matrix
      sc_vec = c4d.Vector(2,1,1)
      sc_mat = c4d.utils.MatrixScale(sc_vec)
      myObj.SetMg(obj_Mat.GetNormalized()*sc_mat)
      ##result : local x scaling
      1. how to change the size of my " Primitive" object without changing it's scale ?
      2. is it possible to add some informations to the HUD using python?
      thanks in advance
        On 02/05/2012 at 23:58, xxxxxxxx wrote:
        To do that you can access the object description. For example drag the cube's Size.x to the edittext in the console, you'll get:
        Cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_X]
        Now you can set the Size.x:
        Cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_X] *= 2
        1. is it possible to add some informations to the HUD using python?
        By HUD do you main GUI ? What kind of information do you want to ouput ?
          On 03/05/2012 at 06:06, xxxxxxxx wrote:
          Thank you Yannick 🙂
          1. ?
          let me be more precise, i agree with you, but i'm looking for something more 'general'. while this formula will work only with cubes ... i don't know if this is possible, thats why i'm asking 😉
          i mean tha same thing when you drag&drop any properties into the viewport, or by doing right click>> Add to the HUD.
          i want to display some integer values, or custom text.
          thank you again!
          cheers
            For all primitive objects you can scale them with ID_BASEOBJECT_REL_SCALE:
            Cube[c4d.ID_BASEOBJECT_REL_SCALE,c4d.VECTOR_X] = 2.0
            i mean the same thing when you drag&drop any properties into the viewport, or by doing right click>> Add to the HUD.
            I'm afraid, this isn't possible to do in Python.
              hmm ... ok!
              ..which means that is possible in c++?
              thank you!
              Best.
                In C++ neither.
                  On 05/05/2012 at 05:30, xxxxxxxx wrote:
                  you could draw your text with the basedraw class.
                    On 05/05/2012 at 07:42, xxxxxxxx wrote:
                    Concerning to what littledevil said, you may use the DrawHelper plugin to enhance your skills with
                    the BaseDraw class. 😉 It is similiar to the PyGenerator Object, but instead of generating Objects,
                    it enables you to do drawings into the Viewport.
                    Available gloabl variables are:
                    raw:       the ObjectData Instance of the DrawHelper object
                    op:        the BaseObject Instance (like in a PyGenerator)
                    drawpass:  the Drawpass
                    bd:        the BaseDraw Instance
                    bh:        the BaseDrawHelper Instance
                    Note: Take care that you don't have important scenes opened. I must admit that I have noticed several crashes when closing Cinema 4D and the DrawHelper object is present in your scene.
                      Yes, it is possible. By first drawing text into a bitmap with the GeClipMap class. Then drawing this bitmap with DrawTexture() into a view BaseDraw.
                        Very interresting plugin 👏! thank you NiklasR 😉
                        i'll test this, thnx 😄
                        actually, another problem disturbing me now, in fact i'm trying to make a plugin tool, and i'm trying to understand how to get some values (combobox value, and number) from the subDialog interface.
                        i tried to get them from the 'data' container (cf. mouseinput, draw, etc..)  but it seems empty :S
                        here an example that i did yesterday :
                        import c4d, os
                        IDP = 1000001
                        class myToolDialog(c4d.gui.SubDialog) :
                        	ID_COMBO	 = 10002
                        	ID_NBR	   = 10003
                        	def CreateLayout(self) :
                        		self.GroupBegin(10000, c4d.BFH_FIT, 3, 1)
                        		self.GroupBorderSpace(10, 10, 10, 10)
                        		self.AddStaticText(10001, c4d.BFH_LEFT,0,0," Value  ", c4d.BORDER_NONE)
                        		self.AddComboBox(self.ID_COMBO, c4d.BFH_SCALE | c4d.BFH_FIT, 0, 0, False)
                        		self.AddChild(self.ID_COMBO, 200, " Red ")
                        		self.AddChild(self.ID_COMBO, 201, " Blue ")
                        		self.AddEditNumberArrows(self.ID_NBR, c4d.BFH_FIT)
                        		self.GroupEnd()
                        	def InitValues(self) :
                        		self.SetLong(self.ID_COMBO, 200)
                        		self.SetReal(self.ID_NBR, 10)
                        class MyToolPlugin(c4d.plugins.ToolData) :
                        	def MouseInput(self, doc, data, bd, win, msg) :
                        		value   = self.dialog.GetLong(10002)
                        		nbr	 = self.dialog.GetReal(10003)
                        		#print 'On Click >>> Value : ', value, ' >>> Nbr : ', nbr
                        	def Draw(self, doc, data, bd, bh, bt, flags) :
                        		print 'Draw >>> Value : ', value, ' >>> Nbr : ', nbr
                        		if value == 200:
                        			color = c4d.Vector(1,0,0)
                        			color = c4d.Vector(0,0,1)
                        		bd.SetMatrix_Matrix(None, c4d.Matrix())
                        		bd.DrawSphere( c4d.Vector(0,0,0), c4d.Vector(nbr, nbr, nbr), color, 0 )
                        		return c4d.DRAWRESULT_OK
                        	def AllocSubDialog(self, bc) :
                        		self.dialog = myToolDialog()
                        		return self.dialog
                        if __name__ =='__main__':
                        	mypath, myfn = os.path.split(__file__)
                        	c4d.plugins.RegisterToolPlugin(id=IDP, str="Test", info=2,icon=None, help="TEst test", dat = MyToolPlugin())
                          On 07/05/2012 at 19:42, xxxxxxxx wrote:
                          any idea ?
                          i'm also trying to use external description resources, but the layout isn't loaded :S
                            any idea ?
                            Please have a look at Liquid Painter example to see how this could be done.
                              On 09/05/2012 at 13:57, xxxxxxxx wrote:
                              I'm not very good at dictionaries( because I don't use them very often). And I found the code in the LP plugin quite convoluted and hard to follow.
                              It was quite a frustrating experience for me.
                              I re-wrote my SplineDraw tool using a dictionary in a similar manner. And I think it's a lot simpler and easier to understand how it works the way I wrote it.
                              https://sites.google.com/site/scottayersmedia/SplineDraw_Python.zip
