    Object scaling
    13 Posts 0 Posters 1.7k Views
      On 02/05/2012 at 23:58, xxxxxxxx wrote:
      1. how to change the size of my " Primitive" object without changing it's scale ?
      To do that you can access the object description. For example drag the cube's Size.x to the edittext in the console, you'll get:
      Cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_X]
      Now you can set the Size.x:
      Cube[c4d.PRIM_CUBE_LEN,c4d.VECTOR_X] *= 2
      1. is it possible to add some informations to the HUD using python?
      By HUD do you main GUI ? What kind of information do you want to ouput ?
        On 03/05/2012 at 06:06, xxxxxxxx wrote:
        Thank you Yannick 🙂
        1. ?
        let me be more precise, i agree with you, but i'm looking for something more 'general'. while this formula will work only with cubes ... i don't know if this is possible, thats why i'm asking 😉
        i mean tha same thing when you drag&drop any properties into the viewport, or by doing right click>> Add to the HUD.
        i want to display some integer values, or custom text.
        thank you again!
        cheers
          For all primitive objects you can scale them with ID_BASEOBJECT_REL_SCALE:
          Cube[c4d.ID_BASEOBJECT_REL_SCALE,c4d.VECTOR_X] = 2.0
          i mean the same thing when you drag&drop any properties into the viewport, or by doing right click>> Add to the HUD.
          I'm afraid, this isn't possible to do in Python.
            hmm ... ok!
            ..which means that is possible in c++?
            thank you!
            Best.
              In C++ neither.
                On 05/05/2012 at 05:30, xxxxxxxx wrote:
                you could draw your text with the basedraw class.
                  On 05/05/2012 at 07:42, xxxxxxxx wrote:
                  Concerning to what littledevil said, you may use the DrawHelper plugin to enhance your skills with
                  the BaseDraw class. 😉 It is similiar to the PyGenerator Object, but instead of generating Objects,
                  it enables you to do drawings into the Viewport.
                  Available gloabl variables are:
                  raw:       the ObjectData Instance of the DrawHelper object
                  op:        the BaseObject Instance (like in a PyGenerator)
                  drawpass:  the Drawpass
                  bd:        the BaseDraw Instance
                  bh:        the BaseDrawHelper Instance
                  Note: Take care that you don't have important scenes opened. I must admit that I have noticed several crashes when closing Cinema 4D and the DrawHelper object is present in your scene.
                    Yes, it is possible. By first drawing text into a bitmap with the GeClipMap class. Then drawing this bitmap with DrawTexture() into a view BaseDraw.
                      Very interresting plugin 👏! thank you NiklasR 😉
                      i'll test this, thnx 😄
                      actually, another problem disturbing me now, in fact i'm trying to make a plugin tool, and i'm trying to understand how to get some values (combobox value, and number) from the subDialog interface.
                      i tried to get them from the 'data' container (cf. mouseinput, draw, etc..)  but it seems empty :S
                      here an example that i did yesterday :
                      import c4d, os
                      IDP = 1000001
                      class myToolDialog(c4d.gui.SubDialog) :
                      	ID_COMBO	 = 10002
                      	ID_NBR	   = 10003
                      	def CreateLayout(self) :
                      		self.GroupBegin(10000, c4d.BFH_FIT, 3, 1)
                      		self.GroupBorderSpace(10, 10, 10, 10)
                      		self.AddStaticText(10001, c4d.BFH_LEFT,0,0," Value  ", c4d.BORDER_NONE)
                      		self.AddComboBox(self.ID_COMBO, c4d.BFH_SCALE | c4d.BFH_FIT, 0, 0, False)
                      		self.AddChild(self.ID_COMBO, 200, " Red ")
                      		self.AddChild(self.ID_COMBO, 201, " Blue ")
                      		self.AddEditNumberArrows(self.ID_NBR, c4d.BFH_FIT)
                      		self.GroupEnd()
                      	def InitValues(self) :
                      		self.SetLong(self.ID_COMBO, 200)
                      		self.SetReal(self.ID_NBR, 10)
                      class MyToolPlugin(c4d.plugins.ToolData) :
                      	def MouseInput(self, doc, data, bd, win, msg) :
                      		value   = self.dialog.GetLong(10002)
                      		nbr	 = self.dialog.GetReal(10003)
                      		#print 'On Click >>> Value : ', value, ' >>> Nbr : ', nbr
                      	def Draw(self, doc, data, bd, bh, bt, flags) :
                      		print 'Draw >>> Value : ', value, ' >>> Nbr : ', nbr
                      		if value == 200:
                      			color = c4d.Vector(1,0,0)
                      			color = c4d.Vector(0,0,1)
                      		bd.SetMatrix_Matrix(None, c4d.Matrix())
                      		bd.DrawSphere( c4d.Vector(0,0,0), c4d.Vector(nbr, nbr, nbr), color, 0 )
                      		return c4d.DRAWRESULT_OK
                      	def AllocSubDialog(self, bc) :
                      		self.dialog = myToolDialog()
                      		return self.dialog
                      if __name__ =='__main__':
                      	mypath, myfn = os.path.split(__file__)
                      	c4d.plugins.RegisterToolPlugin(id=IDP, str="Test", info=2,icon=None, help="TEst test", dat = MyToolPlugin())
                        On 07/05/2012 at 19:42, xxxxxxxx wrote:
                        any idea ?
                        i'm also trying to use external description resources, but the layout isn't loaded :S
                          any idea ?
                          Please have a look at Liquid Painter example to see how this could be done.
                            On 09/05/2012 at 13:57, xxxxxxxx wrote:
                            I'm not very good at dictionaries( because I don't use them very often). And I found the code in the LP plugin quite convoluted and hard to follow.
                            It was quite a frustrating experience for me.
                            I re-wrote my SplineDraw tool using a dictionary in a similar manner. And I think it's a lot simpler and easier to understand how it works the way I wrote it.
                            https://sites.google.com/site/scottayersmedia/SplineDraw_Python.zip
