    GetSplinePoint Instability
    11 Posts 0 Posters 990 Views
      On 23/04/2012 at 05:17, xxxxxxxx wrote:
      Any thoughts on this?
      Shawn
        On 23/04/2012 at 07:44, xxxxxxxx wrote:
        I've recently done something similar and used the SplineHelp class to do it. In my case I wanted to know the actual global position in the 3D world represented by a given percentage along a spline. The SplineHelp::GetPosition() function works fine for that.
        If you needed to know the nearest point in the spline to the percentage distance, you could try SplineHelp::GetPointIndex().
        Hope that helps a little.
        Steve
          On 23/04/2012 at 08:02, xxxxxxxx wrote:
          Thanks Steve!   I'll check those functions out when I get home. I wish I had a portable SDK on my iPhone. Lol
            On 23/04/2012 at 14:11, xxxxxxxx wrote:
            Hmmm..  well,  that works like it's supposed to just like GetSplinePoint() but I sitll get random flickers back to the beginning of the spline.  This is weird.  It must be earlier in the chain before I build the spline.  Back to the drawing board,.  😞
              On 23/04/2012 at 15:21, xxxxxxxx wrote:
              Is this a spline with more than one segment by any chance? I had trouble getting my code to work with segments other than the first one. Gave up in the end, it wasn't critical.
                On 23/04/2012 at 15:24, xxxxxxxx wrote:
                Yes it has more than one. Unfortunately it is critical in my setup. Lol
                Thanks again Steve.
                  On 23/04/2012 at 19:02, xxxxxxxx wrote:
                  Okay, when the object jumps back to the base of the spline, the console prints out the value of the vector created by SplineHelp::GetPosition() as
                  Vector(-1.#QO, -1.#QO, -1.#QO);
                  Any idea what that means?
                  Shawn
                    On 24/04/2012 at 00:55, xxxxxxxx wrote:
                    The problem is clearly the use of more than one sesgment. I couldn't fix this, maybe someone with more knowledge could show how to make it work?
                    That strange printout, I can only guess that it's a value incredibly close to zero without actually being zero - like you see sometimes in Visual Studio, it appears to give a really weird value for a Real but you realise that it's just an arithmetical rounding error and it's really zero.
                      On 24/04/2012 at 03:48, xxxxxxxx wrote:
                      I had some problems with SplineHelp, too, in the past. Therefore, I returned to using SplineObject::GetSplinePoint().
                        On 24/04/2012 at 03:50, xxxxxxxx wrote:
                        Hi Jack,
                        Interestingly I get the same results with GetSplinePoint(),  You had your object along the spline return to the start?  How did you resolve this?
                        Shawn
