    GetSplinePoint Instability
    11 Posts 0 Posters 852 Views
      On 21/04/2012 at 11:19, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      Platform:   Windows  ; Mac  ;
      Hey everyone,
      I am having some weird results using GetSplinePoint()
      Basically I fill a Vector with:
      Real dist = bc->GetReal(MY_DIST_PERCENTAGE);
       Vector spos = spline->GetSplinePoint(dist, 0, NULL);
      I then set the position of objects to spos so that they will move along a certain percentage of the spline.
      when I increase or decrease the dist percentage, I get random spurts of GetSplinePoint() returning Vector(0,0,0);    which makes my objects jump randomly back to the start of the spline .  Is this a known issue with GetSplinePoint() or am I doing something wrong?
      Shawn
        On 23/04/2012 at 05:17, xxxxxxxx wrote:
        Any thoughts on this?
        Shawn
          On 23/04/2012 at 07:44, xxxxxxxx wrote:
          I've recently done something similar and used the SplineHelp class to do it. In my case I wanted to know the actual global position in the 3D world represented by a given percentage along a spline. The SplineHelp::GetPosition() function works fine for that.
          If you needed to know the nearest point in the spline to the percentage distance, you could try SplineHelp::GetPointIndex().
          Hope that helps a little.
          Steve
            On 23/04/2012 at 08:02, xxxxxxxx wrote:
            Thanks Steve!   I'll check those functions out when I get home. I wish I had a portable SDK on my iPhone. Lol
              On 23/04/2012 at 14:11, xxxxxxxx wrote:
              Hmmm..  well,  that works like it's supposed to just like GetSplinePoint() but I sitll get random flickers back to the beginning of the spline.  This is weird.  It must be earlier in the chain before I build the spline.  Back to the drawing board,.  😞
                On 23/04/2012 at 15:21, xxxxxxxx wrote:
                Is this a spline with more than one segment by any chance? I had trouble getting my code to work with segments other than the first one. Gave up in the end, it wasn't critical.
                  On 23/04/2012 at 15:24, xxxxxxxx wrote:
                  Yes it has more than one. Unfortunately it is critical in my setup. Lol
                  Thanks again Steve.
                    On 23/04/2012 at 19:02, xxxxxxxx wrote:
                    Okay, when the object jumps back to the base of the spline, the console prints out the value of the vector created by SplineHelp::GetPosition() as
                    Vector(-1.#QO, -1.#QO, -1.#QO);
                    Any idea what that means?
                    Shawn
                      On 24/04/2012 at 00:55, xxxxxxxx wrote:
                      The problem is clearly the use of more than one sesgment. I couldn't fix this, maybe someone with more knowledge could show how to make it work?
                      That strange printout, I can only guess that it's a value incredibly close to zero without actually being zero - like you see sometimes in Visual Studio, it appears to give a really weird value for a Real but you realise that it's just an arithmetical rounding error and it's really zero.
                        On 24/04/2012 at 03:48, xxxxxxxx wrote:
                        I had some problems with SplineHelp, too, in the past. Therefore, I returned to using SplineObject::GetSplinePoint().
                          On 24/04/2012 at 03:50, xxxxxxxx wrote:
                          Hi Jack,
                          Interestingly I get the same results with GetSplinePoint(),  You had your object along the spline return to the start?  How did you resolve this?
                          Shawn
