    SendModelingCommand, MCData result array question
    25 Posts 0 Posters 16.8k Views
      On 15/04/2012 at 01:09, xxxxxxxx wrote:
      Well for your questions 1 and 3:
      Q1. The SDK tells you. For example, under MCOMMAND_JOIN it says 'returns object'. If it doesn't say that, it shouldn't return a new object.
      Q3. It's empty because it isn't returning a new object. Your input object is just changed. (Though the SDK does say that if you input multiple objects, which uses the arr parameter, the changed objects are returned in result. But I've never tried that.)
      Don't know about Q2. I've always used the MCOMMAND_ series, never used ID_MODELING_. I'd like to know the answer to this, too.
      Oh, and be aware that SendModelingCommand is a pig. It never works the way you think it should.
      Steve
        On 15/04/2012 at 04:32, xxxxxxxx wrote:
        hey,
        thanks for your answer, as the code seemed to have no effect on my object i was desperately
        trying to get the result array to work, ignoring that the problem obviously lies somewhere else.
        i should have done this before, but MCOMMAND_SUBDIVIDE is working as expected. which leads
        me to a question, i also always had for python.
        how are we supposed to use modellingtools which require some sort of editor highlighting, like
        loops or the knifetool ? i found MDATA_KNIFE_ as a mysterious value in toolknife.h, MDATA_KNIFE_
        doesn't appear in the res file. is it holding the live selection informations ?
        edit : btw i found this here
        First, ID_MODELING_MELT_COMMAND is meant to be used with CallCommand() and MCOMMAND_MELT with SendModelingCommand().
        ok i found MDATA_OPTIONS, but what the heck is a cid ?
        cid MDATA_Options
          Real MDATA_SPLINE_FREEHANDTOLERANCE;
          Real MDATA_SPLINE_OUTLINE;
          LONG MDATA_SPLINE_PROJECTMODE;
          LONG MDATA_SPLINE_ADDPOINTSEGMENT;
          Real MDATA_SPLINE_ADDPOINTPOSITION;
          Bool MDATA_SPLINE_ADDPOINTSELECT;
          Bool MDATA_SPLINE_OUTLINESEPARATE;
          Bool MDATA_DISCONNECT_PRESERVEGROUPS;
          Bool MDATA_MIRROR_SNAPPOINTS;
          Bool MDATA_MIRROR_DUPLICATE;
          Bool MDATA_MIRROR_WELD;
          Real MDATA_MIRROR_TOLERANCE;
          LONG MDATA_MIRROR_SYSTEM;
          LONG MDATA_MIRROR_PLANE;
          Real MDATA_MIRROR_VALUE;
          Vector MDATA_MIRROR_POINT;
          Vector MDATA_MIRROR_VECTOR;
          Bool MDATA_MIRROR_SELECTIONS;
          Bool MDATA_MIRROR_ONPLANE;
          Real MDATA_OPTIMIZE_TOLERANCE;
          Bool MDATA_OPTIMIZE_POINTS;
          Bool MDATA_OPTIMIZE_POLYGONS;
          Bool MDATA_OPTIMIZE_UNUSEDPOINTS;
          Real MDATA_CROSSSECTION_ANGLE;
          Bool MDATA_SUBDIVIDE_HYPER;
          Real MDATA_SUBDIVIDE_ANGLE;
          LONG MDATA_SUBDIVIDE_SPLINESUB;
          LONG MDATA_SUBDIVIDE_SUB;
          Vector MDATA_KNIFE_P1;
          Vector MDATA_KNIFE_V1;
          Vector MDATA_KNIFE_P2;
          Vector MDATA_KNIFE_V2;
          Real MDATA_KNIFE_ANGLE;
          Bool MDATA_UNTRIANGULATE_ANGLE;
          Bool MDATA_UNTRIANGULATE_NGONS;
          Real MDATA_UNTRIANGULATE_ANGLE_RAD;
          LONG MDATA_CONVERTSELECTION_LEFT;
          LONG MDATA_CONVERTSELECTION_RIGHT;
          Bool MDATA_CONVERTSELECTION_TOLERANT;
          Bool MDATA_CURRENTSTATETOOBJECT_INHERITANCE;
          Bool MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION;
          Bool MDATA_CURRENTSTATETOOBJECT_NOGENERATE;
          Bool MDATA_ROTATECAMERA;
          LONG MDATA_RING_EDGE;
          LONG MDATA_RING_SELECTION;
          LONG MDATA_RING_SKIP;
          LONG MDATA_FILLSEL_START_POLY;
          LONG MDATA_FILLSEL_SELECTION;
          LONG MDATA_OUTLINESEL_START_POLY;
          LONG MDATA_OUTLINESEL_SELECTION;
          Bool MDATA_RESETSYSTEM_COMPENSATE;
          Bool MDATA_RESETSYSTEM_RECURSIVE;
          Bool MDATA_JOIN_MERGE_SELTAGS;
          Real MDATA_SETVERTEX_VALUE;
          LONG MDATA_SETVERTEX_MODE;
        it appears quite often in the sdk, but i cannot find any explanation ho to use it.
          On 15/04/2012 at 08:06, xxxxxxxx wrote:
          tried this,
          BaseContainer toolbc, mdatabc;
          ModelingCommandData cd;
          mdatabc.SetVector( MDATA_KNIFE_P1, Vector(0,0,0) );
          mdatabc.SetVector( MDATA_KNIFE_P2, Vector(1,0,0) );
          toolbc.SetBool(MDATA_KNIFE_RESTRICT, FALSE);
          toolbc.SetLong(MDATA_KNIFE_MODE, MDATA_KNIFE_MODE_PLANE);
          toolbc.SetLong(MDATA_KNIFE_PLANE, MDATA_KNIFE_PLANE_YZ);
          toolbc.SetBool(MDATA_KNIFE_PLANE_SLICING, TRUE);
          toolbc.SetLong(MDATA_KNIFE_PLANE_CUTS, 4);
          toolbc.SetContainer(MDATA_KNIFE_, mdatabc);
          cd.doc = GetActiveDocument();
          cd.bc = &toolbc;
          cd.mode = MODELINGCOMMANDMODE_POLYGONSELECTION;
          cd.op = result;
          if (SendModelingCommand(MCOMMAND_KNIFE, cd)) GePrint("Beep");
          return result;
          but it doesn't work *scratch head*
          edit : to be more specific, it compiles and runs, but my object isn't cut.
            On 15/04/2012 at 10:51, xxxxxxxx wrote:
            The first thing you should know is that the SMC is riddled with bugs. And you're probably beating a dead horse using the SMC for this.
            Try the same code you used. But put something like: ID_MODELING_EXTRUDE_INNER_TOOL in there instead. And it should work just fine for you.
            I've reported SMC bugs in the past. For example the old mirror tool only moves points in the Z direction. Regardless of what the settings are in the code.
            And then there's things that just don't work at all. Like this:https://developers.maxon.net/forum/topic/5863/5930_tool-doesnt-execute-until-view-is-selected&KW=tool&PID=24928#24928
            Here is a possible alternative to using the SMC:
                doc->SetAction(ID_MODELING_KNIFE_TOOL); //Executes the knife tool
              LONG tool_id = doc->GetAction();
              BasePlugin *tool = NULL;
              tool = FindPlugin(tool_id, PLUGINTYPE_TOOL);
              if (!tool) return FALSE;
              tool->SetParameter(DescID(MDATA_KNIFE_RESTRICT), FALSE, DESCFLAGS_SET_0);       //Turns off the restrict option
              tool->SetParameter(DescID(MDATA_KNIFE_CONSTRAIN_THETA), .65, DESCFLAGS_SET_0);  //Sets the value to 37.242°
              tool->SetParameter(DescID(MDATA_KNIFE_MODE), MDATA_KNIFE_MODE_LOOP, DESCFLAGS_SET_0);//<--CRASHES C4D!!!
            This seems to work for changing everything in the knife tool. Except the mode option.
            I've tried a bunch of different things. But it either crashes, or doesn't do anything.
            I've also tried changing the knife mode using the tools container. But all I can manage to do is change it in memory. The AM refuses to update for me.
              On 15/04/2012 at 11:58, xxxxxxxx wrote:
              thanks for your reply and the work you put into this. i am aware of the posts that point onto
              numerous smc bugs. despite this fact i would really like to know how this is intended to be used.
              the class cid MDATA_Options is there for some reason and it is obvious that tool knife won't work
              without the vectors (you cannot finish the tool within c4d without hoovering a polygon).
              however MDATA_KNIFE_ doesn't seem to be used within c4d. did some quick tests in python :
              from c4d import documents, utils
                  cube = doc.SearchObject("Cube")
                  toolbc = c4d.BaseContainer()
                  tool = doc.GetActiveToolData()
                  toolbc[c4d.MDATA_KNIFE_RESTRICT] = False
                  toolbc[c4d.MDATA_KNIFE_MODE] = c4d.MDATA_KNIFE_MODE_PLANE
                  toolbc[c4d.MDATA_KNIFE_PLANE] = c4d.MDATA_KNIFE_PLANE_YZ
                  toolbc[c4d.MDATA_KNIFE_PLANE_SLICING] = 1
                  toolbc[c4d.MDATA_KNIFE_PLANE_CUTS] = 4
                  toolbc[c4d.MDATA_KNIFE_P1] = c4d.Vector(0,-1000,0)
                  toolbc[c4d.MDATA_KNIFE_P2] = c4d.Vector(0,1000,0)
                  res = utils.SendModelingCommand(c4d.MCOMMAND_KNIFE, [cube],
                  c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, toolbc, doc)
                  tool[c4d.MDATA_KNIFE_MODE] = c4d.MDATA_KNIFE_MODE_PLANE
                  for index, value in tool:
                      print '{0} ==> {1}'.format(index, value)
              it would be really nice, if the support could explain how we are meant to use MDATA_Options.
                On 15/04/2012 at 14:00, xxxxxxxx wrote:
                GetActiveToolData() get's the tool's container. So that can be used without needing to create a brand new container in your python example.
                I'm also not sure why you're trying to execute the knife tool with SMC after you've asked for the active tool. That seems backwards to me.
                Example:
                  c4d.CallCommand(1016030)        #Execute the Knife tool first
                  tool = doc.GetActiveToolData()    #Then ask for the active tool's container data
                  tool[c4d.MDATA_KNIFE_RESTRICT] = False
                  tool[c4d.MDATA_KNIFE_PLANE] = c4d.MDATA_KNIFE_PLANE_YZ
                  tool[c4d.MDATA_KNIFE_PLANE_SLICING] = 1
                  tool[c4d.MDATA_KNIFE_PLANE_CUTS] = 4
                  tool[c4d.MDATA_KNIFE_P1] = c4d.Vector(0,-1000,0)
                  tool[c4d.MDATA_KNIFE_P2] = c4d.Vector(0,1000,0)
                From the recent Python forum thread about executing buttons:
                Yannick wrote: " MDATA_TRANSFER_ marks the end of MDATA_TRANSFER's container entry enumeration; it's not a valid ID. "
                If maxon is consistent. Then that means MDATA_KNIFE_ is also not a valid ID to use with SMC.
                If you are attempting to execute the knife tool without the user hovering the mouse over the object. It's not possible.
                It's been discussed in the archives.
                  On 15/04/2012 at 14:26, xxxxxxxx wrote:
                  thanks for your reply,
                  i am aware of that, the script was meant to do 2 things, check if SMC behaves differently in
                  python and for loping through the tooldata bc of the active tool (the knife tool). the
                  GetActiveToolData() & bc loop has nothing to do whit the smc part.
                  If you are attempting to execute the knife tool without the user hovering the mouse over the object. It's not possible. It's been discussed in the archives.
                  yes i am trying to run the knife tool without hoovering. i couldn't find any threads on the knife
                  tool & smc. could you provide a link ? what i still don't understand why there is is MDATA_Options
                  and what it is used for.
                  ok this makes sense, however a better naming would clearify things alot, olight ends with
                  LIGHT_END_, much better imho.
                    On 15/04/2012 at 14:38, xxxxxxxx wrote:
                    Here's one thread. But I think remember seeing more than just this one. This is just the first one I picked after doing a search for "knife tool" :
                     https://developers.maxon.net/forum/topic/2694/2066_knife-tool-in-version-9&KW=Knife+Tool&PID=7950#7950
                    FYI:
                    Just in case you don't already know this. Use the advanced search. And set the "Find Posts" option to "Any Date" to see all the really old archived threads.
                    I would really like to know how to change the knife tool's mode in C++ myself.
                    I can't understand why my SetParameter() code isn't working.
                      You should use a GeData and its Set*() method:
                      GeData data;
                      data.SetLong(MDATA_KNIFE_MODE_LOOP);
                      tool->SetParameter(DescID(MDATA_KNIFE_MODE), data, DESCFLAGS_SET_0);
                        On 16/04/2012 at 07:08, xxxxxxxx wrote:
                        so it still applies, that we cannot use smc knifetool without mouse input, we are not able to set
                        the knife vectors with MData_Options somehow ?
                          On 16/04/2012 at 08:37, xxxxxxxx wrote:
                          Thanks Yannick,
                          That code works if the knife tool is already open. But it still crashes C4D when used like this:
                            if (tool)
                            GeData data;
                            tool->SetParameter(DescID(MDATA_KNIFE_MODE), data, DESCFLAGS_SET_0); //<---CRASHES!!
                          I'm not positive about this. But it seems like the knife tool is still loading(or the open dialog plugin doesn't see it as loaded yet) when SetParamerter() kicks in. So it crashes.
                          Is there a better way to execute the knife code like this?
                            On 16/04/2012 at 09:57, xxxxxxxx wrote:
                            The safest way to change a tool settings is to access its data container calling GetToolData() :
                            BaseContainer* data = GetToolData(doc, ID_MODELING_KNIFE_TOOL);
                            data->SetLong(MDATA_KNIFE_MODE, MDATA_KNIFE_MODE_LOOP);
                            This way it works if the tool is open or not.
                              On 16/04/2012 at 11:07, xxxxxxxx wrote:
                              OK thanks.
                              This advice contradicts the sticky posted here about always using Get&Set parameter() instead of BaseContainers. So I try not to use BaseContainers as much as possible.
                              But I realize in programming there are no absolutes. And sometimes you have no choice.
                              Still. I suppose this could maybe confuse some people.
                                On 18/04/2012 at 04:27, xxxxxxxx wrote:
                                i have replaced the smc with my own code , so i do not need this specific example anymore,
                                but i still would really like to know, how we are supposed to use MDATA_Options.
                                  On 18/04/2012 at 07:11, xxxxxxxx wrote:
                                  MDATA_Options doesn't exist in the SDK. It's just a group of all container IDs for modeling commands.
                                  In the documentation IDs are grouped for better indexing.
                                    On 18/04/2012 at 08:06, xxxxxxxx wrote:
                                    so, we have to write the ids from MData_Options into the bc of the respective tool to
                                    use them or aren't we allowed to use the ids at all ? sorry, i still don't get it.
                                      Yes you can use the IDs listed in MData_Options. For example MDATA_CURRENTSTATETOOBJECT_INHERITANCE, MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION and MDATA_CURRENTSTATETOOBJECT_NOGENERATE for MCOMMAND_CURRENTSTATETOOBJECT.
                                      And the IDs from MData_Options are placed under their related command in SendModelingCommand() documentation.
                                        On 19/04/2012 at 03:34, xxxxxxxx wrote:
                                        thanks for the clarification. that i wasn't able to set the vectors for the knife tool is just a limitation
                                        of the knifetool  ?(i am aware that my orginal apporach to write these vectors into a seperate bc,
                                        which i tried to write into the id MDATA_KNIFE_ was wrong, i also tried to write these values directly
                                        into the ModellingCommandData bc.)
                                          of the knifetool ?
                                          I contacted the developers on this.
                                            On 29/01/2013 at 07:23, xxxxxxxx wrote:
                                            A recent thread made me remember that I got some months ago an interesting code snippet from the developers that was showing how to send a knife modeling command.
                                            What's most important to understand is: MDATA_KNIFE_P1, MDATA_KNIFE_P2, MDATA_KNIFE_V1 and MDATA_KNIFE_V2 have to be given in world space.
                                            For this purpose we can use the handy conversion methods of BaseView (parent class of BaseDraw). In the example we call BaseView.SW() to convert screen space coordinates to world space.
                                            v1 and v2 are basically vectors showing away from the camera (and going through p1/p2). v1 % v2 build the normal of the cutting plane.
                                            The following example will show how to cut the selected spline just in the middle of the view:
                                            from c4d import utils
                                            def SplineCutter(doc, op, bd, x1, y1, x2, y2, bSelect) :
                                                p1 = bd.SW(c4d.Vector(x1, y1, 0.0))
                                                v1 = bd.SW(c4d.Vector(x1, y1, 100.0)) - p1
                                                p2 = bd.SW(c4d.Vector(x2, y2, 0.0))
                                                v2 = bd.SW(c4d.Vector(x2, y2, 100.0)) - p2
                                                bc.SetVector(c4d.MDATA_KNIFE_P1, p1)
                                                bc.SetVector(c4d.MDATA_KNIFE_P2, p2)
                                                bc.SetVector(c4d.MDATA_KNIFE_V1, v1)
                                                bc.SetVector(c4d.MDATA_KNIFE_V2, v2)
                                                bc.SetBool(c4d.MDATA_KNIFE_RESTRICT, False)
                                                bc.SetBool(c4d.MDATA_KNIFE_SELECTCUTS, bSelect)
                                                if op is not None and op.CheckType(c4d.Ospline) :
                                                    utils.SendModelingCommand(command = c4d.MCOMMAND_KNIFE,
        list = [op],
        bc = bc,
        doc = doc,
        flags = c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)
                                                bd = doc.GetActiveBaseDraw()
                                                frame = bd.GetFrame()
                                                middleX = (frame['cr']-frame['cl'])/2
                                                SplineCutter(doc, op, bd, middleX, frame['ct'], middleX, frame['cb'], True)
                                            You can then modify the call to SplineCutter() in main() to use other coordinates from the mouse, a tool etc. You can also 'play' with others MDATA_KNIFE_ options.
                                            EDIT: Fixed the code.
