    passing arrays as parameters
    26 Posts 0 Posters 15.5k Views
      On 30/03/2012 at 09:55, xxxxxxxx wrote:
      You can't do that within the parantheses.
      http://codepad.org/eTZ9drKy
        On 30/03/2012 at 10:27, xxxxxxxx wrote:
        using the new operator or a smart pointer would probably work but it really doesn't make much sense (or create a mem leak), Niklas is right. Why don't you declare it outside littledevil?
          On 30/03/2012 at 11:07, xxxxxxxx wrote:
          well, i am declaring it outside right now, however i am used to this feature from c# and it is not life
          saving important but a handy feature. i have asked this question on german speaking c++ forum too
          and they came up with these solutions and some pages of tech gibberish :
          1. this pointer thing samir suggested ( i still don't fully understand althought i am aware of the
          pointer nature of arrays).
          2. using c++ 11
          3. extrernal libs
          so i am booking this under *not possible in c++*. i am often just baffled how heavy-handed c++ is
          compared to modern languages like c#.
          edit : here is the link (i hope this is okay, as linking other forums sometimes is considered as a nogo)
          http://www.c-plusplus.de/forum/301582
            On 30/03/2012 at 15:47, xxxxxxxx wrote:
            C++ doesn't have automated memory handling (i.e.: garbage collection) like some more modern programming languages.  Therefore, all memory management is in the hands of the programmer.  I know, scary! 😉
            Pointers aren't just for arrays.  Pointers are just variable notation that stores the memory address of another variable (whether it is an array, class, or built-in type).  It is a way to pass along larger chunks of memory without passing the entire chunk through the cpu registers.
            The problem with allocating memory in the arguments of a function/method for C++ are that there is no path to free (deallocate) that memory.  Arguments are placed on the stack (preallocated memory for the application) while allocations are typically created in the heap (general memory space available to the application).
            Might I suggest either using Python (since it has garbage collection) or reading "Memory as a Programming Concept in C and C++" by Frantisek Franek.  The C4D Python API isn't as powerful and extensive as the C++ API currently.  The book is only a couple hundred pages but provides a very good introduction, explanation, and advantageous uses of C++ memory management.
              On 31/03/2012 at 04:34, xxxxxxxx wrote:
              1. this pointer thing samir suggested ( i still don't fully understand althought i am aware of the pointer nature of arrays).
              2. using c++ 11
              3. external libs
              1. This is the clean way to do it 🙂 And it's also super simple. Declare the array in your code before using the function, allocate it and call your function later and after you're done with the array, don't forget to free it.
              Bool foo (LONG *myarray, LONG count)
              if (!myarray || count == 0) return FALSE;
              // As an example: Fill the array with numbers
              LONG i;
              for (i = 0; i < count; i++)
                  myarray[i] = i*i;
              Bool PrintArray(LONG *myarray, LONG count)
              LONG i;
                  GePrint("Array[" + LongToString(i) + "] = " + LongToString(myarray[i]));
              void main()
              const LONG count = 100;
              // Allocate array
              LONG *arr = GeAllocType(LONG, count);
              if (!arr)
                  GePrint("Error allocating the array");
                  return;
              // Fill the array
              if (!foo(arr, count))
                  GePrint("Filing the array didn't work out.");
              else
                  GePrint("Array filled succesfully");
              // Do something with the filled array
              if (!PrintArray(arr, count))
                  GePrint("Could not print out array.");
              // Free memory
              if (arr) GeFree(arr);
              You could also allocate the array in the same function where it's being filled with values and then return the new array:
              LONG* foo (LONG count)
              if (count == 0) return NULL;
              LONG* myarray = GeAllocType(LONG, count);
              if (!myarray) return NULL;
              LONG i;
                  myarray[i] = i*i;
              return myarray;
              void main()
              // Allocate array
              LONG *arr = foo(count);
              if (!arr)
                  GePrint("Error allocating and filling the array");
                  return;
              // Free memory
              2. The C4D API is currently not compatible with C++ 11 standard. Enabling C++ 11 in your compiler might lead to problems with the API code.
              3. External libs might create extra hassle for you when compiling them for different platforms. As - quite frankly - you seem to be a beginner with C++, I would not recommend to use them.
              Also, try to use the types defined in the C4D API (e.g. LONG instead of int), that will keep you from running into problems with 32 bit vs. 64 bit, different platforms and single precision vs. double precision.
                On 31/03/2012 at 05:58, xxxxxxxx wrote:
                thank you for your extensive code example, it is very much appreciated. just as a sidenote, i am
                aware of point 2-3 and yes i am a beginner :).
                  On 31/03/2012 at 08:38, xxxxxxxx wrote:
                  @jack: Just a note, returning allocated memory from a function is considered bad. It's also some kind of confusing (imho).
                  -Niklas
                    On 31/03/2012 at 08:42, xxxxxxxx wrote:
                    Returning memory from a method is okay as long as you are cognizant that your are 'passing' ownership from the method to somewhere else so that it can be freed properly by the new owner.  The scope may be lost when returning from the method but as long as you have assigned a pointer to the new allocation that has more lasting scope, you should be okay.
                    Edit to add:
                    The conditional is not necessary.  If 'arr' is NULL then GeFree doesn't do anything (and it won't crash).  You've already checked that arr isn't NULL so it should be doubly okay.  One case to remember is that if you free memory and the execution continues you should set the pointer to it equal to NULL.   So, this is better:
                    GeFree(arr);
                    arr = NULL;  // Make sure that it doesn't point to memory that it no longer owns!
                    Any subsequent GeFree() calls (such as in a destructor) will do the appropriate thing.  Otherwise, you risk trying to free the same memory twice - and crash.
                      If it was considered bad, I don't think we would have any Alloc() functions in the API...
                      BaseObject *op = BaseObject::Alloc(Onull);
                      In fact, even the memory allocation is done by a function:
                      And yes, it might be confusing. But programming is a confusing thing if one does not take care 😉 Therefore, we wouldn't call this function "foo" but rather something with "Alloc".
                      if (arr) GeFree(arr);The conditional is not necessary. If 'arr' is NULL then GeFree doesn't do anything (and it won't crash). You've already checked that arr isn't NULL so it should be doubly okay.
                      Right, in this example it was obvious. But it'S better to have double and triple checks than to run into some surprising case (in more complex code) and have it crash on the user's machine.
                      With GeFree and also with the static Free methods of the C4D API classes, that is not necessary. They set your pointer to NULL automatically (pointer reference (void*& p)). Same with the gDelete and bDelete macros.
                      But generally, of course, one should take care to set the pointer to NULL when any other method of memory freeing is used.
                        Sorry didn't add that. We have Free() functions according to them, which is not considered bad. 🙂
                        -Niklas
                          On 02/04/2012 at 00:43, xxxxxxxx wrote:
                          i have got another question. i am still messing with my objectdata plugin. it basicly returns
                          different geometry types based on data entered by the user (disc,plane,sphere...). as they
                          extend some of basic capeabilities of c4ds baseobjects i thought it would be smart to
                          outsource their allocation.
                          currently it is something like this :
                          BaseObject *Opolylight::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh)
                          	return GetPlane(op);
                          static BaseObject *Opolylight::GetPlane(BaseObject *op)
                          	BaseObject *result = NULL;
                          	result = BaseObject::Alloc(Oplane);
                          	BaseContainer *outbc = result->GetDataInstance();
                          	BaseContainer *inbc = op->GetDataInstance();
                          	return result;
                          i am roughly following the SDK ATOM sample. but while the atom sample is just outsourcing into
                          one other method form GetVirtualObjects, in my case it would make sense to have one method
                          for each objecttype (GetPlane, GetDisc ...).
                          my question is now : when the user changes the ouput from plane to disc the allocated mem from
                          GetPlane still remains alltough it isn't used anymore. by defining the method as static i prevent
                          the code from creating multiple instances, but my addon will still carry a bunch of data for each
                          shape the user has choosen once.
                          is this considered as a memory leak / bad ?
                            On 02/04/2012 at 01:48, xxxxxxxx wrote:
                            Do you mean, the function itself still exists and redundant when not used anymore?
                              On 02/04/2012 at 01:56, xxxxxxxx wrote:
                              the function is a pointer pointing on a baseobject, but somewhere this chain of pointer madness
                              has to end, in my example it ends at result = BaseObject::Alloc(Oplane);. i thought it works this
                              way :
                              1. GetVirtualObjects is called
                              2. GetVirtualObjects calls GetPlane
                              3. GetPlane allocates some memory at adress xyz and creates a BaseObject there
                              4. GetPlane returns xyz
                              5. GetVirtualObjects is called again
                              6. GetVirtualObjects calls GetSphere
                              what happens with the BaseObject @ memory adress xyz ?
                              i guess i am geting something wrong again 😪
                                On 02/04/2012 at 02:21, xxxxxxxx wrote:
                                In the SDK are often notes that say "Cinema 4D owns the pointed/returned object." which means Cinema will manage the memory of the object. I can't find such a note in the ObjectData::GetVirtualObjects() documentation. They either forgot to add it or you have to manage that on your own, i.e. cache the object and free it on the next call to GetVirtualObjects(). I haven't written a C++ plugin yet, (as I said, I refuse to use VC. 😉 ).
                                -Niklas
                                  On 02/04/2012 at 02:37, xxxxxxxx wrote:
                                  uh i made a mis take in my example, when i shortend the code, it has to be
                                  static BaseObject * ~~Opolylight::~~ GetPlane(BaseObject *op)
                                      	return result;
                                  of course.
                                  @ nikklas
                                  i am not talking about GetVirtualObjects, it is called on each update and there are examples in
                                  the sdk how to treat cases in which GetVirtualObject fails to produce a propper output (free
                                  the memory).
                                  but i have firgured it out somehow i guess, i have just to create some kind of garbagecollector
                                  method which clears all the unused static pointer method adresses. i'll report back when i fail again :)
                                  ps : refusing to praise & and use microsoft products is considered to be a mortal sin by the spanish
                                  inquisition.
                                    On 02/04/2012 at 05:27, xxxxxxxx wrote:
                                    Whatever object you return in GetVirtualObjects(), don't care about its memory anymore. Cinema takes over the ownership.
                                    If you allocate an object but don't return it at the end of GetVirtualObjects(), you have to free it yourself of course.
                                      On 02/04/2012 at 08:44, xxxxxxxx wrote:
                                      and here i am again, i tried to check my code so i placed a c4d_debug.txt in my c4d folder.
                                      first i started c4d from the desktop and the console window said meh, debugger not present
                                      so i started c4d from vs using my project (which compiles and runs fine atm), c4d crashes again
                                      with the exception floating point division by zero. so i tried the sdk_examples with the 32 bit debug
                                      platform. it starts without any errors, but the console doesn't show up, not while debugging, not after.
                                      i am on vista 64 bit, c4d demo 32 bit and VS 8.0.5
                                      has someone experience with this odd behaviour ?
                                      sorry, for throwing random questions at you 😄
                                        On 02/04/2012 at 22:05, xxxxxxxx wrote:
                                        for the Console to show up you need to set the startup directory in VS to the c4d folder (project properties -> debugging). Else it won't find the c4d_debug.txt
                                        or you put the c4d_debug.txt in the plugin's folder
                                          Already said, that text file better goes into your plugin's folder. Otherwise, Cinema will do the memory trace everytime your start it, and that is usually not desired.
                                          That's the right way to do. Create a Debug build in VS and use the "Play" button to start Cinema in the VS Debugger.
                                          c4d crashes again with the exception floating point division by zero.
                                          Then the DivByZero is definitely a bug in your code 😉 ALWAYS check for zero before doing any division (or take care that zero will never occur).
                                          That's OK, but I really think you should open separate threads for separate questions. That way, it will be much easier for other people to find your questions and the answers.
                                            On 26/04/2012 at 18:40, xxxxxxxx wrote:
                                            Yes, I already said this.  An argument will be put into a CPU register if available otherwise it goes onto the stack.  This is why four or less arguments for a method are faster.  As someone with nearly 30 years of programming and most of that using C/C++, I definitely know what the hell I'm talking about.
                                            http://msdn.microsoft.com/en-us/library/zthk2dkh%28v=vs.80%29.aspx
