    whats stopping render
    3 Posts 0 Posters 376 Views
      On 23/03/2012 at 04:04, xxxxxxxx wrote:
      Put this in a generator
      turn off cache
      drop in poly object
      results in spline
      but you then can't render in viewport?
      from c4d import utils
          output = None
          obj = op.GetDown()
          if not obj: return None
          if obj:
              if not obj.CheckType(c4d.Opolygon) : return None
              if obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] != 1:
                  obj.Edit()
                  doc.SetMode(c4d.Medges)
              source = obj.GetClone()
              obj[c4d.ID_BASEOBJECT_VISIBILITY_EDITOR] = 1
              obj[c4d.ID_BASEOBJECT_VISIBILITY_RENDER] = 1
              utils.SendModelingCommand(c4d.MCOMMAND_SELECTALL, list = [obj], mode = c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc = c4d.BaseContainer(), doc = doc)
              if c4d.utils.SendModelingCommand(c4d.MCOMMAND_EDGE_TO_SPLINE, [source]) :
                  output = source.GetDown().GetClone()
                  source.DelBit(c4d.BIT_AOBJ)
          return output
        On 23/03/2012 at 14:42, xxxxxxxx wrote:
        I'm pretty sure that you have to manually check for Dirty in your code if you turn of the cache option like that.
        Otherwise the generator keeps running in an infinite loop and prevents it from rendering.
        Here's a different approach to making the child of a generator a spline object:
          sweep = None    #Error handling if no object is a child of the generator
          obj = op.GetDown()
          if obj is not None and obj.CheckType(c4d.Opolygon) :
                  spline = source.GetDown().GetClone() #Return a clone of the selected splines
              circle = c4d.BaseObject(c4d.Osplinecircle) #Create the sweep profile object
              circle[c4d.PRIM_CIRCLE_RADIUS] = 2
              sweep = c4d.BaseObject(c4d.Osweep) #Create a sweepNURBS object
              spline.InsertUnder(sweep)          #Put the source object under the sweep object
              circle.InsertUnder(sweep)          #Put the circle object under the sweep object
          return sweep
          On 25/03/2012 at 03:55, xxxxxxxx wrote:
          Thanks Scott - as ever, appreciate the input.
          Really want just the spline.
          Can't see any way to get dirty data - no explanation of generate cache
          Wish there were more info an the generator, its limitations, how to's etc
