    Set data doesn't work for Texture name?
    4 Posts 0 Posters 546 Views
      On 04/01/2012 at 13:46, xxxxxxxx wrote:
      Just curious why setting the name of a selection tag is different from setting the name of a material tag
      see WORKS  - DOESNT WRK Comment
      (Python conversion of Script by Steve Pedler - to take the name of a material and apply it to the selection and name of associated selection tag)
      import  c4d
      from c4d.documents import GetActiveDocument
      from c4d import BaseContainer
      from c4d.gui import GeDialog
      	c4d.CallCommand(13957);
      	doc = GetActiveDocument()
      	if doc is None:
      		return False
      	op      = doc.GetActiveObject()
      	if op is None:
      		print 'No Object Selected'
      		return False
      	tag = op.GetFirstTag()
      	while tag:
      		bc = tag.GetDataInstance()
      		if tag.CheckType(c4d.Ttexture) :
      			matselname = bc.GetData(c4d.TEXTURETAG_RESTRICTION)
      			matname = tag[c4d.TEXTURETAG_MATERIAL].GetName()
      			seltag = op.GetFirstTag()
      			while seltag:
      				bc2 = seltag.GetDataInstance()
      				if seltag.GetName() == matselname:
      					bc.SetData(c4d.TEXTURETAG_RESTRICTION, matname)
      					seltag[c4d.ID_BASELIST_NAME] = matname # WORKS
      					# bc2.SetData(c4d.ID_BASELIST_NAME, matname) DOESNT!!!!
      					#seltag.SetName(matname) WORKS
      				seltag = seltag.GetNext()
      		tag = tag.GetNext()
        On 05/01/2012 at 02:02, xxxxxxxx wrote:
        Anyone?
          On 05/01/2012 at 06:09, xxxxxxxx wrote:
          or is this a better way ie. NOT using Get Data Instance?
              if doc is None:
                  return False
              if op is None:
                  return False
              while tag:
                      matselname = tag[c4d.TEXTURETAG_RESTRICTION]
                      while seltag:
                              tag[c4d.TEXTURETAG_RESTRICTION] = matname
                  tag = tag.GetNext()
            On 06/01/2012 at 05:45, xxxxxxxx wrote:
            Another one resolved with the help of Scott on the CGSociety Forum
