Set data doesn't work for Texture name?
On 04/01/2012 at 13:46, xxxxxxxx wrote:
Just curious why setting the name of a selection tag is different from setting the name of a material tag
see WORKS - DOESNT WRK Comment
(Python conversion of Script by Steve Pedler - to take the name of a material and apply it to the selection and name of associated selection tag)
import c4d from c4d.documents import GetActiveDocument from c4d import BaseContainer from c4d.gui import GeDialog def main() : c4d.CallCommand(13957); doc = GetActiveDocument() if doc is None: return False op = doc.GetActiveObject() if op is None: print 'No Object Selected' return False tag = op.GetFirstTag() while tag: bc = tag.GetDataInstance() if tag.CheckType(c4d.Ttexture) : matselname = bc.GetData(c4d.TEXTURETAG_RESTRICTION) matname = tag[c4d.TEXTURETAG_MATERIAL].GetName() seltag = op.GetFirstTag() while seltag: bc2 = seltag.GetDataInstance() if seltag.GetName() == matselname: bc.SetData(c4d.TEXTURETAG_RESTRICTION, matname) seltag[c4d.ID_BASELIST_NAME] = matname # WORKS # bc2.SetData(c4d.ID_BASELIST_NAME, matname) DOESNT!!!! #seltag.SetName(matname) WORKS seltag = seltag.GetNext() tag = tag.GetNext() c4d.EventAdd() return True main()
On 05/01/2012 at 02:02, xxxxxxxx wrote:
Anyone?
On 05/01/2012 at 06:09, xxxxxxxx wrote:
or is this a better way ie. NOT using Get Data Instance?
import c4d from c4d.documents import GetActiveDocument from c4d import BaseContainer from c4d.gui import GeDialog def main() : c4d.CallCommand(13957); doc = GetActiveDocument() if doc is None: return False op = doc.GetActiveObject() if op is None: print 'No Object Selected' return False tag = op.GetFirstTag() while tag: if tag.CheckType(c4d.Ttexture) : matname = tag[c4d.TEXTURETAG_MATERIAL].GetName() matselname = tag[c4d.TEXTURETAG_RESTRICTION] seltag = op.GetFirstTag() while seltag: if seltag.GetName() == matselname: tag[c4d.TEXTURETAG_RESTRICTION] = matname seltag[c4d.ID_BASELIST_NAME] = matname # WORKS seltag = seltag.GetNext() tag = tag.GetNext() c4d.EventAdd() return True main()
On 06/01/2012 at 05:45, xxxxxxxx wrote:
Another one resolved with the help of Scott on the CGSociety Forum
