    Adding programmatically options
    6 Posts 0 Posters 492 Views
      On 03/11/2011 at 05:06, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      let's say that I have a description for a container item:
      LONG MY_ITEM
               CYCLE
                       OPTION1;
                       OPTION2;
      Now, let's say that instead of the description above, I have only
      LONG MY_ITEM {}
      BUT would like to add the CYCLE options programmatically.
      How can I do this?
      Thank you!
        On 03/11/2011 at 05:52, xxxxxxxx wrote:
        Haven't ever used it, but the GetDDescription Method (whatever class, I think its the NodeData class) should be what you need.
          On 03/11/2011 at 07:07, xxxxxxxx wrote:
          But in which way?
            On 03/11/2011 at 07:52, xxxxxxxx wrote:
            NodeData::GetDDescription() is called to let you add your own parameters to the description of a node (please refer to the documentation for details).
            You can also take a look at the NodeData::GetDDescription() implementation in LookAtCamera example.
              On 04/11/2011 at 04:50, xxxxxxxx wrote:
              Great, thank you very much!
                On 01/12/2011 at 10:02, xxxxxxxx wrote:
                So how you solved it?
                I'm trying something similar
