    RDATA_PATH problem with NetRender
    11 Posts 0 Posters 1.2k Views
      On 24/10/2011 at 23:17, xxxxxxxx wrote:
      Hi everybody,
      I'am trying to set up a little helper script in order to manage all my cameras and rendersettings. When I'm trying the script in C4D R12 directly everything works fine.
      But when I try to render the scene on our servers with NetRender the clients report the following problem:
      File "<Python-Generator>", line19, in main
      Attribute Error; 'module' object has no attribute 'RDATA_PATH'
      Isn't there any active renderdata when rendering with NetRender? That would be very astonishing.
      Does anybody have an idea?
      Here's the code:
      from c4d import documents
        rd = doc.GetActiveRenderData()
        rdName = rd.GetName()
      bd = doc.GetActiveBaseDraw()
        rc = bd.GetSceneCamera(doc)
        rcName = rc.GetName()
        if rdName != rcName:
            bd.SetSceneCamera(doc.SearchObject(rdName+"_kamera"))
        rdOutputFilename = rd[c4d.RDATA_PATH]
        newRdOutputFilename = rdName+"_"+doc.SearchObject("Namenszusatz")[c4d.ID_USERDATA, 1]+"___"
        if rdOutputFilename != newRdOutputFilename:
            rd[c4d.RDATA_PATH] = newRdOutputFilename
            rd[c4d.RDATA_MULTIPASS_FILENAME] = newRdOutputFilename
        print newRdOutputFilename
        pass
      Greetings,
      blutsvente
        On 25/10/2011 at 00:43, xxxxxxxx wrote:
        Ok, after updating...
        The error message doesn't appear anymore.
        But it seem's that there is something strange in my code.
        Because now the application on the clients shutdown without any error prompt and the server needs a few minutes to realize when the job was stopped.
        Is there something special I've to keep in mind when writing scripts with Python for NetRender?
        Greetings,
        blutsvente
          On 25/10/2011 at 04:23, xxxxxxxx wrote:
          I've got it.
          Setting cache optimizing to no solves the problem.
            On 08/02/2012 at 06:22, xxxxxxxx wrote:
            hey!
            i have a similar problem - where do you set cache optimizing to no?
            I keep getting - AttributeError: 'module' object has no attribute 'ID_USERDATA'
            many thanks!
              On 08/02/2012 at 07:01, xxxxxxxx wrote:
              That seems to be a bug in NetRender, the identifiers are not loaded correctly.
              However, we are still waiting for an official statement, maybe they know a workaround. The only that comes into my mind would be replacing the access to the constant identifiers with their actual value, but that will cause the script to loose platform and version independence.
                On 08/02/2012 at 07:11, xxxxxxxx wrote:
                @mchaloner: Please install the latest update on the Netrender clients. Does the problem still occur?
                  On 08/02/2012 at 07:13, xxxxxxxx wrote:
                  I'm using the latest R12 NET Render Client, I think! (Build RC32293)
                    On 08/02/2012 at 08:00, xxxxxxxx wrote:
                    Made a work around that basically dumps all the helper python tags before calling the save project command...
                    included it if it helps anyone
                    from c4d         import gui
                    from c4d         import BaseTime
                    from c4d         import Vector
                    from c4d         import gui
                    from c4d.gui     import GeDialog
                    def deletePythonTags(obj) :
                      tagList = obj.GetTags()
                      for t in tagList:
                         if t.GetTypeName() == "Python":
                             obj.KillTag(t.GetType())
                      objList = doc.GetObjects()
                      camList = []
                      for obj in objList:
                          #GET ALL CAMERAS
                          if obj.GetTypeName() == "Camera":
                              camList.append(obj)
                          if obj.GetName() == "[Document Render Path]":
                              #DELETE HELPER NULL
                              doc.SetActiveObject(obj)
                              c4d.CallCommand(12109)
                      for cam in camList:
                          #DELETE TAGS
                          deletePythonTags(cam)
                      c4d.CallCommand(12255)
                      On 08/02/2012 at 10:26, xxxxxxxx wrote:
                      @mchaloner: Can you please check if the client version is R12.048. Thx.
                        On 09/02/2012 at 02:24, xxxxxxxx wrote:
                        Weirdly the main app is 12.048 - but my net client is still 12.016.
                        I downloaded the update from the Maxon website and selected Manual Installation from the NET client...
                        and I get this
                          On 09/02/2012 at 08:23, xxxxxxxx wrote:
                          I tried to reproduce this but without any success. But I know the problem was fixed in one of the updates so maybe something is broken with your installation (just guessing).
