RDATA_PATH problem with NetRender
On 24/10/2011 at 23:17, xxxxxxxx wrote:
Hi everybody,
I'am trying to set up a little helper script in order to manage all my cameras and rendersettings. When I'm trying the script in C4D R12 directly everything works fine.
But when I try to render the scene on our servers with NetRender the clients report the following problem:
File "<Python-Generator>", line19, in main
Attribute Error; 'module' object has no attribute 'RDATA_PATH'Isn't there any active renderdata when rendering with NetRender? That would be very astonishing.
Does anybody have an idea?Here's the code:
from c4d import documents
#Welcome to the world of Pythondef main() :
rd = doc.GetActiveRenderData()
rdName = rd.GetName()bd = doc.GetActiveBaseDraw()
rc = bd.GetSceneCamera(doc)
rcName = rc.GetName()
if rdName != rcName:
bd.SetSceneCamera(doc.SearchObject(rdName+"_kamera"))
rdOutputFilename = rd[c4d.RDATA_PATH]
newRdOutputFilename = rdName+"_"+doc.SearchObject("Namenszusatz")[c4d.ID_USERDATA, 1]+"___"
if rdOutputFilename != newRdOutputFilename:
rd[c4d.RDATA_PATH] = newRdOutputFilename
rd[c4d.RDATA_MULTIPASS_FILENAME] = newRdOutputFilename
print newRdOutputFilename
passGreetings,
blutsvente -
On 25/10/2011 at 00:43, xxxxxxxx wrote:
Ok, after updating...
The error message doesn't appear anymore.But it seem's that there is something strange in my code.
Because now the application on the clients shutdown without any error prompt and the server needs a few minutes to realize when the job was stopped.Is there something special I've to keep in mind when writing scripts with Python for NetRender?
Greetings,
blutsvente -
On 25/10/2011 at 04:23, xxxxxxxx wrote:
I've got it.
Setting cache optimizing to no solves the problem.
On 08/02/2012 at 06:22, xxxxxxxx wrote:
hey!
i have a similar problem - where do you set cache optimizing to no?
I keep getting - AttributeError: 'module' object has no attribute 'ID_USERDATA'
many thanks!
On 08/02/2012 at 07:01, xxxxxxxx wrote:
That seems to be a bug in NetRender, the identifiers are not loaded correctly.
However, we are still waiting for an official statement, maybe they know a workaround. The only that comes into my mind would be replacing the access to the constant identifiers with their actual value, but that will cause the script to loose platform and version independence. -
On 08/02/2012 at 07:11, xxxxxxxx wrote:
@mchaloner: Please install the latest update on the Netrender clients. Does the problem still occur?
On 08/02/2012 at 07:13, xxxxxxxx wrote:
I'm using the latest R12 NET Render Client, I think! (Build RC32293)
On 08/02/2012 at 08:00, xxxxxxxx wrote:
Made a work around that basically dumps all the helper python tags before calling the save project command...
included it if it helps anyone
import c4d from c4d import gui from c4d import documents from c4d import BaseTime from c4d import Vector from c4d import gui from c4d.gui import GeDialog def deletePythonTags(obj) : tagList = obj.GetTags() for t in tagList: if t.GetTypeName() == "Python": obj.KillTag(t.GetType()) return def main() : doc = documents.GetActiveDocument() objList = doc.GetObjects() camList = [] for obj in objList: #GET ALL CAMERAS if obj.GetTypeName() == "Camera": camList.append(obj) if obj.GetName() == "[Document Render Path]": #DELETE HELPER NULL doc.SetActiveObject(obj) c4d.CallCommand(12109) for cam in camList: #DELETE TAGS deletePythonTags(cam) c4d.CallCommand(12255) if __name__=='__main__': main()
On 08/02/2012 at 10:26, xxxxxxxx wrote:
@mchaloner: Can you please check if the client version is R12.048. Thx.
On 09/02/2012 at 02:24, xxxxxxxx wrote:
Weirdly the main app is 12.048 - but my net client is still 12.016.
I downloaded the update from the Maxon website and selected Manual Installation from the NET client...
and I get this
On 09/02/2012 at 08:23, xxxxxxxx wrote:
I tried to reproduce this but without any success. But I know the problem was fixed in one of the updates so maybe something is broken with your installation (just guessing).
