    get selection poligon vertex and perform a scaling
    2 Posts 0 Posters 228 Views
      On 26/08/2011 at 03:09, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I'm using c.o.f.f.e.e. (no pytohon, no c++) i'm in polygon mode i would to do these things:
      1. enable menu plugin if the user is in polygon mode and has selected a poligon
      2. get all the list of polygon selected
      3. then perform a scaling but only for the X axis
        very big thanks!
        On 30/08/2011 at 09:42, xxxxxxxx wrote:
        The state of the menu entry is controled via the MenuPlugin::GetState method. Override it for your own plugins. The other points are explained in my example.
        class MPPlugin : MenuPlugin
              MPPlugin();
              GetID();
              GetName();
              GetState();
              GetHelp();
              Execute(doc);
        MPPlugin::MPPlugin()
          super();
        MPPlugin::GetID()
          return 1001150;
        MPPlugin::GetState()
          var doc = GetActiveDocument();
          if (!doc) return 0;
          // is polygon mode checked
          if (!IsCommandChecked(12187)) return 0;
          // is there an selected object and is it a polygon object
          var op = doc->GetActiveObject();
          if (!op || op->GetType() != Opolygon) return 0;
          // is at least one polyogn selected
          var sel = op->GetPolygonSelection();
          if (sel->GetCount() == 0) return 0;
          return CMD_ENABLED;
        MPPlugin::GetName()
          return "Scale Test";
        MPPlugin::GetHelp()
        MPPlugin::Execute(doc)
          if (sel->GetCount() == 0) return;
          var fcnt = op->GetPolygonCount();
          var vcnt = op->GetPointCount();
          // create a vertex index array to store selection states for vertices of selected polygons
          var vidx = new(array,vcnt);
          if (!vidx) return;
          var i = 0;
          // initialize the array
          for (i=0; i<vcnt; i++)
              vidx[i] = FALSE;
          // converts polygon selection into point selection
          for (i=0; i<fcnt; i++)
              if (sel->IsSelected(i))
                  var poly = op->GetPolygon(i);
                  vidx[poly->a] = TRUE;
                  vidx[poly->b] = TRUE;
                  vidx[poly->c] = TRUE;
                  vidx[poly->d] = TRUE;        }
          // go through the vertices and do something (e.g scale)
              if (vidx[i])
                  var vertex = op->GetPoint(i);
                  // do something with vertex
                  vertex.x *= 5.0;
                  //vertex.y *= 2.0;
                  //vertex.z *= 3.0;
                  op->SetPoint(i, vertex);
          // must be called for object and editor update
          op->Message(MSG_UPDATE);
          EventAdd();
          Register(MPPlugin);
