get selection poligon vertex and perform a scaling
On 26/08/2011 at 03:09, xxxxxxxx wrote:
Cinema 4D Version: 12
I'm using c.o.f.f.e.e. (no pytohon, no c++) i'm in polygon mode i would to do these things:- enable menu plugin if the user is in polygon mode and has selected a poligon
- get all the list of polygon selected
- then perform a scaling but only for the X axis
very big thanks!
On 30/08/2011 at 09:42, xxxxxxxx wrote:
The state of the menu entry is controled via the MenuPlugin::GetState method. Override it for your own plugins. The other points are explained in my example.
class MPPlugin : MenuPlugin { public: MPPlugin(); GetID(); GetName(); GetState(); GetHelp(); Execute(doc); } MPPlugin::MPPlugin() { super(); } MPPlugin::GetID() { return 1001150; } MPPlugin::GetState() { var doc = GetActiveDocument(); if (!doc) return 0; // is polygon mode checked if (!IsCommandChecked(12187)) return 0; // is there an selected object and is it a polygon object var op = doc->GetActiveObject(); if (!op || op->GetType() != Opolygon) return 0; // is at least one polyogn selected var sel = op->GetPolygonSelection(); if (sel->GetCount() == 0) return 0; return CMD_ENABLED; } MPPlugin::GetName() { return "Scale Test"; } MPPlugin::GetHelp() { return "Scale Test"; } MPPlugin::Execute(doc) { var op = doc->GetActiveObject(); if (!op || op->GetType() != Opolygon) return 0; var sel = op->GetPolygonSelection(); if (sel->GetCount() == 0) return; var fcnt = op->GetPolygonCount(); var vcnt = op->GetPointCount(); // create a vertex index array to store selection states for vertices of selected polygons var vidx = new(array,vcnt); if (!vidx) return; var i = 0; // initialize the array for (i=0; i<vcnt; i++) { vidx[i] = FALSE; } // converts polygon selection into point selection for (i=0; i<fcnt; i++) { if (sel->IsSelected(i)) { var poly = op->GetPolygon(i); vidx[poly->a] = TRUE; vidx[poly->b] = TRUE; vidx[poly->c] = TRUE; vidx[poly->d] = TRUE; } } // go through the vertices and do something (e.g scale) for (i=0; i<vcnt; i++) { if (vidx[i]) { var vertex = op->GetPoint(i); // do something with vertex vertex.x *= 5.0; //vertex.y *= 2.0; //vertex.z *= 3.0; op->SetPoint(i, vertex); } } // must be called for object and editor update op->Message(MSG_UPDATE); EventAdd(); } main() { Register(MPPlugin); }
