    A better Scriptmanager would be nice.
    12 Posts 0 Posters 2.6k Views
      On 03/06/2011 at 16:05, xxxxxxxx wrote:
      My main intention is to open ASYNC Dialogs within the Script Manager.
      Unfortunately this is not possible and asynchronous dialogs are not intended to be opened from the script manager.
        On 03/06/2011 at 16:34, xxxxxxxx wrote:
        Test my Extended SM, and you'll see, it is possible. 😉
        /edit:
        Ok. I am confused. This works great in my Plugin:
        http://pastebin.com/Ay29Li2Z
        But putting the last 2 lines into a function, it does not work. Any idea ?
        PS: Dlg taken from the Memory Viewr example
          A plugin that does not crash is no garantuee for a proper implementation. For sure, there are workarounds, which might work somehow. The lifetime of a script is limited and this fact makes it not possible.
          Same as https://developers.maxon.net/forum/topic/5755/5803_elements-need-to-be-in-callersdictionary-
            On 04/06/2011 at 04:58, xxxxxxxx wrote:
            You are right.
            But it is possible in Coffee.
            Thanks Sebastian.
            PS: I'm interested in how you check for the syntax in the Script Manager. I found a way to do this, but it is a strange workaround and I am sure there is a better way.
              On 04/06/2011 at 09:21, xxxxxxxx wrote:
              ... and, please implement Ctrl-Z for undo ... and automatic indenting. These two would make a big difference already 😉
              maxx
                On 04/06/2011 at 09:40, xxxxxxxx wrote:
                If you need a customizable programming environment I recommend these both articles:
                http://www.smart-page.net/blog/2011/05/29/debugging-cinema-4d-python-plugins-with-pydev/
                http://www.smart-page.net/blog/2011/05/09/advanced-python-plugin-coding-for-cinema-4d/
                  On 04/06/2011 at 10:26, xxxxxxxx wrote:
                  Thanx for the info, handy tutorials !
                  maxx
                    On 04/06/2011 at 11:17, xxxxxxxx wrote:
                    Thank you !
                      On 06/06/2011 at 02:28, xxxxxxxx wrote:
                      maxx
                      at least undo!
                        On 08/06/2011 at 03:54, xxxxxxxx wrote:
                        I like writing in Notepad++, so I write my code in N++ even I'm only testing in the scriptmanager.
                        If there won't be an undo, you may want to do it like this, too, deepshade. 😉
                          On 08/06/2011 at 11:35, xxxxxxxx wrote:
                          ... clever it would be. It happend to me already many times, that I wanted to delete a line but more was selected ... and code is gone for good, devnulled, nirvanized 😉
                          maxx
