    A better Scriptmanager would be nice.
    12 Posts 0 Posters 2.2k Views
      On 03/06/2011 at 14:39, xxxxxxxx wrote:
      I'd like to have a better Scriptmanager. My main intention is to open ASYNC Dialogs within the Script Manager. And if I can create such with Python, MAXON should be able to do it, too. 😂
        Unfortunately this is not possible and asynchronous dialogs are not intended to be opened from the script manager.
          On 03/06/2011 at 16:34, xxxxxxxx wrote:
          Test my Extended SM, and you'll see, it is possible. 😉
          /edit:
          Ok. I am confused. This works great in my Plugin:
          http://pastebin.com/Ay29Li2Z
          But putting the last 2 lines into a function, it does not work. Any idea ?
          PS: Dlg taken from the Memory Viewr example
            A plugin that does not crash is no garantuee for a proper implementation. For sure, there are workarounds, which might work somehow. The lifetime of a script is limited and this fact makes it not possible.
            Same as https://developers.maxon.net/forum/topic/5755/5803_elements-need-to-be-in-callersdictionary-
              On 04/06/2011 at 04:58, xxxxxxxx wrote:
              You are right.
              But it is possible in Coffee.
              Thanks Sebastian.
              PS: I'm interested in how you check for the syntax in the Script Manager. I found a way to do this, but it is a strange workaround and I am sure there is a better way.
                On 04/06/2011 at 09:21, xxxxxxxx wrote:
                ... and, please implement Ctrl-Z for undo ... and automatic indenting. These two would make a big difference already 😉
                maxx
                  On 04/06/2011 at 09:40, xxxxxxxx wrote:
                  If you need a customizable programming environment I recommend these both articles:
                  http://www.smart-page.net/blog/2011/05/29/debugging-cinema-4d-python-plugins-with-pydev/
                  http://www.smart-page.net/blog/2011/05/09/advanced-python-plugin-coding-for-cinema-4d/
                    On 04/06/2011 at 10:26, xxxxxxxx wrote:
                    Thanx for the info, handy tutorials !
                    maxx
                      On 04/06/2011 at 11:17, xxxxxxxx wrote:
                      Thank you !
                        On 06/06/2011 at 02:28, xxxxxxxx wrote:
                        maxx
                        at least undo!
                          On 08/06/2011 at 03:54, xxxxxxxx wrote:
                          I like writing in Notepad++, so I write my code in N++ even I'm only testing in the scriptmanager.
                          If there won't be an undo, you may want to do it like this, too, deepshade. 😉
                            On 08/06/2011 at 11:35, xxxxxxxx wrote:
                            ... clever it would be. It happend to me already many times, that I wanted to delete a line but more was selected ... and code is gone for good, devnulled, nirvanized 😉
                            maxx
