    Trouble with SendMessage "conflict".
    13 Posts 0 Posters 1.1k Views
      On 05/05/2011 at 12:58, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hi
      After really crazy experiance with thread and dialog in a recent post, I'm trying to use SendMessage to set the GeDialog properties. If I try to call SendMessage like this:
      SendMessage(DLG_BTN_UP, BaseContainer(BFM_ENABLE));
      I receive the compile error:
      error C2660: 'SendMessageA' : function does not take 2 arguments
      This happens in any part of the program I try to call this method. My c4d includes are:
      #include "c4d.h"
      #include "c4d_gui.h"
      #include "c4d_symbols.h"
      #include "c4d_general.h"
      #include "c4d_baseplugin.h"
      #include "C4D_Thread.h"
      With the VS intellisense I see that the method called is one in winuser.h which is not in my includes. The prototype is:
      LRESULT SendMessageA(HWND hwnd, UINT msg, WPARAM wParam, LPARAM lParam);
      I don't understand which is the problem...why this conflict?
      Thanks for any help.
      Bye.
        On 05/05/2011 at 14:51, xxxxxxxx wrote:
        I'm not sure what you're trying to do. Do you want to enable/disable controls in the GeDialog? If so, just use the Enable(LONG id, Bool TRUE/FALSE) function. Much easier than sending a message, even if that's possible.
          On 06/05/2011 at 02:39, xxxxxxxx wrote:
          Hi spedler, thanks for your reply.
          Unfortunatly, is not so simple. As described here:
          https://developers.maxon.net/forum/topic/5664/5700_manipulate-extended-gedialog-from-ext-methods
          I'm interested to call the "Enable" method on GeDialog from Threading context. This is not allowed. So, I have to to try with SendMessage sdk routine to achieve my goal but I have the described problem.
          Many thanks for any ideas.
          Bye
            On 06/05/2011 at 06:29, xxxxxxxx wrote:
            I don't think SendMessage will help in your case.
            What you probably can do is to send a custom message through SpecialEventAdd() from your thread. Then this message can be received in your dialog's overridden CoreMessage method.
            There is a small example in the docs for SpecialEventAdd().
              On 06/05/2011 at 07:51, xxxxxxxx wrote:
              Hi Matthias, thanks for your constants replies. I will try the SpecialEvent...I've already seen this method but I don't remember if I've already tested this solution. Tonight I try...this "problem" made me crazy...thanks again, I'll know if it works...
              bye
                On 06/05/2011 at 11:26, xxxxxxxx wrote:
                Definitively thanks, using SpecialEvent we can manipulate now the gedialog using threading context. Bye.
                  On 06/05/2011 at 12:49, xxxxxxxx wrote:
                  In any case, the SendMessage problem described stay...
                    And it will stay as long as you're calling the Windows-specific method (which you can't use in the context of Cinema's event system) instead of the GeDialog method...
                    Best regards,
                    Wilfried
                      On 06/05/2011 at 13:41, xxxxxxxx wrote:
                      Did I understand you right ? You want to to something in the dialog from another thread ?
                      I don't know about C++, but maybe this helps you:
                      When you want to send the message, don't send the message itself, instead create a variable the defines wether the message should be sent or not. Just some Pseudocode to clarify what I mean:
                      //Pseudocode, don't copy
                      class MyDialog extends GeDialog {
                          boolean sendEvent = FALSE;
                          void Set_SendMessageOnNextUpdate() {
                              sendEvent = TRUE;
                          void Do_SendMessage() {
                              SendMessage();
                              sendEvent = FALSE;
                          boolean CoreMessage(id,msg) {
                              if (sendEvent) {
                                  Do_SendMessage();
                      class MyThread extends Thread {
                          void doMyStuff(GeDialog *dlg) {
                              dlg.Set_SendMessageOnNextUpdate();
                      I'm not sure if this will really work as you wish, but maybe it helps you 🙂
                      Niklas
                        Best regards,
                        Wilfried
                        I don't call any windows specific method now...
                          Best regards,
                          Wilfried
                          [/QUOTE]
                          You do. The compiler's error message proofs it.
                          Best regards,
                          Wilfried
                            On 07/05/2011 at 13:07, xxxxxxxx wrote:
                            Bho....If I do, I don't know where I do...I've removed all "trash" includes, I've only:
                            #include "c4d.h"
                            #include <string>
                            #include <sys/stat.h>
                            I don't use any windows dependent method, the Thread is C4D Sdk based, but the message is:
                            error C2039: 'SendMessageA' : is not a member of 'C4DScenePlugin'
                            Now the prototype viewed with vs intellicode is correct but the error on define still stay...
                            Bho....
                            Best regards,
                            Wilfried
                            [/QUOTE]
                            Best regards,
                            Wilfried
                            [/QUOTE]
                              On 07/05/2011 at 13:26, xxxxxxxx wrote:
                              With a redefine of method name in my plugin now compile fine...very strange for me...
